Getting started with Apache Spark on Google Axion C4A (Arm Neoverse-V2)
How to create a Google Axion C4A Arm virtual machine on GCP
How to deploy Apache Spark on Google Axion C4A Arm virtual machines
Apache Spark baseline testing on Google Axion C4A Arm VM
Apache Spark performance benchmarks on Arm64 and x86_64 in Google Cloud
Apache Spark includes internal micro-benchmarks to evaluate the performance of core components like SQL execution, aggregation, joins, and data source reads. These benchmarks are helpful for comparing performance on x86_64 vs Arm64 platforms.
Follow the steps outlined to run Spark’s built-in SQL benchmarks using the SBT-based framework.
git clone https://github.com/apache/spark.git
This clones the full Spark source code including internal test suites and the benchmarking tools.
cd spark/ && git checkout v4.0.0
Switch to the stable Spark 4.0.0 release, which supports the latest internal benchmarking APIs.
./build/sbt -Pbenchmarks clean package
This compiles Spark and its dependencies, enabling the benchmarks build profile for performance testing.
./build/sbt -Pbenchmarks "sql/test:runMain org.apache.spark.sql.execution.benchmark.AggregateBenchmark"
This executes the AggregateBenchmark, which compares performance of SQL aggregation operations (e.g., SUM, STDDEV) with and without WholeStageCodegen. WholeStageCodegen is an optimization technique used by Spark SQL to improve the performance of query execution by generating Java bytecode for entire query stages instead of interpreting them step-by-step.
You should see output similar to:
[info] Running benchmark: agg w/o group
[info] Running case: agg w/o group wholestage off
[info] Stopped after 2 iterations, 66883 ms
[info] Running case: agg w/o group wholestage on
[info] Stopped after 5 iterations, 4283 ms
[info] OpenJDK 64-Bit Server VM 17.0.16+8-LTS on Linux 5.14.0-570.28.1.el9_6.aarch64
[info] 05:36:00.495 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] Unknown processor
[info] agg w/o group: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] ------------------------------------------------------------------------------------------------------------------------
[info] agg w/o group wholestage off 32967 33442 672 63.6 15.7 1.0X
[info] agg w/o group wholestage on 856 857 1 2451.2 0.4 38.5X
[info] Running benchmark: stddev
[info] Running case: stddev wholestage off
[info] Stopped after 2 iterations, 7538 ms
[info] Running case: stddev wholestage on
[info] Stopped after 5 iterations, 4357 ms
[info] 05:36:18.982 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] stddev: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] stddev wholestage off 3765 3769 5 27.8 35.9 1.0X
[info] stddev wholestage on 870 872 2 120.6 8.3 4.3X
[info] Running benchmark: kurtosis
[info] Running case: kurtosis wholestage off
[info] Stopped after 2 iterations, 38309 ms
[info] Running case: kurtosis wholestage on
[info] Stopped after 5 iterations, 4729 ms
[info] 05:37:24.198 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] kurtosis: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] kurtosis wholestage off 19114 19155 58 5.5 182.3 1.0X
[info] kurtosis wholestage on 943 946 3 111.2 9.0 20.3X
[info] Running benchmark: Aggregate w keys
[info] Running case: codegen = F
[info] Stopped after 2 iterations, 11018 ms
[info] Running case: codegen = T, hashmap = F
[info] Stopped after 3 iterations, 9331 ms
[info] Running case: codegen = T, row-based hashmap = T
[info] Stopped after 5 iterations, 5086 ms
[info] Running case: codegen = T, vectorized hashmap = T
[info] Stopped after 5 iterations, 3553 ms
[info] 05:38:06.612 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] Aggregate w keys: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] ----------------------------------------------------------------------------------------------------------------------- -
[info] codegen = F 5401 5509 154 15.5 64.4 1.0X
[info] codegen = T, hashmap = F 3103 3110 7 27.0 37.0 1.7X
[info] codegen = T, row-based hashmap = T 1004 1017 11 83.5 12.0 5.4X
[info] codegen = T, vectorized hashmap = T 707 711 3 118.7 8.4 7.6X
[info] Stopped after 2 iterations, 10796 ms
[info] Stopped after 3 iterations, 8988 ms
[info] Stopped after 5 iterations, 6483 ms
[info] Stopped after 5 iterations, 4909 ms
[info] 05:38:51.375 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] codegen = F 5374 5398 34 15.6 64.1 1.0X
[info] codegen = T, hashmap = F 2918 2996 68 28.7 34.8 1.8X
[info] codegen = T, row-based hashmap = T 1289 1297 8 65.1 15.4 4.2X
[info] codegen = T, vectorized hashmap = T 978 982 4 85.8 11.7 5.5X
[info] Running benchmark: Aggregate w string key
[info] Stopped after 2 iterations, 3882 ms
[info] Stopped after 3 iterations, 3624 ms
[info] Stopped after 5 iterations, 4145 ms
[info] Stopped after 5 iterations, 3779 ms
[info] 05:39:18.280 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] Aggregate w string key: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] codegen = F 1938 1941 4 10.8 92.4 1.0X
[info] codegen = T, hashmap = F 1208 1208 0 17.4 57.6 1.6X
[info] codegen = T, row-based hashmap = T 820 829 5 25.6 39.1 2.4X
[info] codegen = T, vectorized hashmap = T 756 756 0 27.8 36.0 2.6X
[info] Running benchmark: Aggregate w decimal key
[info] Stopped after 2 iterations, 3771 ms
[info] Stopped after 2 iterations, 2231 ms
[info] Stopped after 5 iterations, 2114 ms
[info] Stopped after 8 iterations, 2238 ms
[info] 05:39:39.289 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] Aggregate w decimal key: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] codegen = F 1878 1886 11 11.2 89.6 1.0X
[info] codegen = T, hashmap = F 1116 1116 0 18.8 53.2 1.7X
[info] codegen = T, row-based hashmap = T 411 423 11 51.0 19.6 4.6X
[info] codegen = T, vectorized hashmap = T 278 280 2 75.4 13.3 6.8X
[info] Running benchmark: Aggregate w multiple keys
[info] Stopped after 2 iterations, 6554 ms
[info] Stopped after 2 iterations, 3608 ms
[info] Stopped after 2 iterations, 2936 ms
[info] Stopped after 2 iterations, 2569 ms
[info] 05:40:06.514 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] Aggregate w multiple keys: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] codegen = F 3272 3277 8 6.4 156.0 1.0X
[info] codegen = T, hashmap = F 1802 1804 3 11.6 85.9 1.8X
[info] codegen = T, row-based hashmap = T 1461 1468 10 14.4 69.7 2.2X
[info] codegen = T, vectorized hashmap = T 1283 1285 3 16.4 61.2 2.6X
[info] Running benchmark: max function bytecode size
[info] Stopped after 8 iterations, 2146 ms
[info] Running case: codegen = T, hugeMethodLimit = 10000
[info] Stopped after 14 iterations, 2072 ms
[info] Running case: codegen = T, hugeMethodLimit = 1500
[info] Stopped after 16 iterations, 2112 ms
[info] 05:40:19.258 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] max function bytecode size: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] codegen = F 263 268 4 2.5 401.6 1.0X
[info] codegen = T, hugeMethodLimit = 10000 143 148 8 4.6 217.4 1.8X
[info] codegen = T, hugeMethodLimit = 1500 129 132 3 5.1 196.6 2.0X
[info] Running benchmark: cube
[info] Running case: cube wholestage off
[info] Stopped after 2 iterations, 3164 ms
[info] Running case: cube wholestage on
[info] Stopped after 5 iterations, 4215 ms
[info] 05:40:32.879 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] cube: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] cube wholestage off 1572 1582 14 3.3 299.9 1.0X
[info] cube wholestage on 841 843 2 6.2 160.4 1.9X
[info] Running benchmark: BytesToBytesMap
[info] Running case: UnsafeRowhash
[info] Stopped after 15 iterations, 2052 ms
[info] Running case: murmur3 hash
[info] Stopped after 42 iterations, 2003 ms
[info] Running case: fast hash
[info] Stopped after 48 iterations, 2016 ms
[info] Running case: arrayEqual
[info] Stopped after 29 iterations, 2064 ms
[info] Running case: Java HashMap (Long)
[info] Stopped after 8 iterations, 2209 ms
[info] Running case: Java HashMap (two ints)
[info] Stopped after 8 iterations, 2217 ms
[info] Running case: Java HashMap (UnsafeRow)
[info] Stopped after 4 iterations, 2039 ms
[info] Running case: LongToUnsafeRowMap (opt=false)
[info] Stopped after 9 iterations, 2144 ms
[info] Running case: LongToUnsafeRowMap (opt=true)
[info] Stopped after 26 iterations, 2005 ms
[info] Running case: BytesToBytesMap (off Heap)
[info] Stopped after 5 iterations, 2368 ms
[info] Running case: BytesToBytesMap (on Heap)
[info] Stopped after 4 iterations, 2023 ms
[info] Running case: Aggregate HashMap
[info] Stopped after 87 iterations, 2011 ms
[info] 05:41:23.750 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] BytesToBytesMap: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] UnsafeRowhash 137 137 0 153.6 6.5 1.0X
[info] murmur3 hash 48 48 0 440.6 2.3 2.9X
[info] fast hash 42 42 0 499.2 2.0 3.3X
[info] arrayEqual 71 71 0 296.8 3.4 1.9X
[info] Java HashMap (Long) 269 276 6 78.0 12.8 0.5X
[info] Java HashMap (two ints) 273 277 2 76.7 13.0 0.5X
[info] Java HashMap (UnsafeRow) 507 510 3 41.4 24.2 0.3X
[info] LongToUnsafeRowMap (opt=false) 237 238 0 88.3 11.3 0.6X
[info] LongToUnsafeRowMap (opt=true) 76 77 1 277.1 3.6 1.8X
[info] BytesToBytesMap (off Heap) 472 474 2 44.4 22.5 0.3X
[info] BytesToBytesMap (on Heap) 505 506 1 41.6 24.1 0.3X
[info] Aggregate HashMap 23 23 0 913.0 1.1 5.9X
[success] Total time: 669 s (11:09), completed Jul 24, 2025, 5:41:24 AM
The following benchmark results were collected by running the same benchmark on a c3-standard-4 (4 vCPU, 2 core, 16 GB Memory) x86_64 virtual machine in GCP, running RHEL 9.
| Benchmark Case | Sub-Case / Config | Best Time (ms) | Avg Time (ms) | Stdev (ms) | Rate (M/s) | Per Row (ns) | Relative |
| agg w/o group | wholestage off | 30044 | 32090 | 2892 | 69.8 | 14.3 | 1.0X |
| agg w/o group | wholestage on | 2728 | 2739 | 7 | 768.7 | 1.3 | 11.0X |
| stddev | wholestage off | 4097 | 4112 | 21 | 25.6 | 39.1 | 1.0X |
| stddev | wholestage on | 948 | 954 | 4 | 110.6 | 9.0 | 4.3X |
| kurtosis | wholestage off | 21658 | 21664 | 9 | 4.8 | 206.5 | 1.0X |
| kurtosis | wholestage on | 1327 | 1335 | 7 | 79.0 | 12.7 | 16.3X |
| Aggregate w keys | codegen = F | 7233 | 7234 | 1 | 11.6 | 86.2 | 1.0X |
| Aggregate w keys | codegen = T, hashmap = F | 4556 | 4570 | 21 | 18.4 | 54.3 | 1.6X |
| Aggregate w keys | codegen = T, row-based hashmap = T | 1201 | 1205 | 6 | 69.8 | 14.3 | 6.0X |
| Aggregate w keys | codegen = T, vectorized hashmap = T | 702 | 715 | 10 | 119.6 | 8.4 | 10.3X |
| Aggregate w keys | codegen = F | 6439 | 6524 | 119 | 13.0 | 76.8 | 1.0X |
| Aggregate w keys | codegen = T, hashmap = F | 4156 | 4170 | 12 | 20.2 | 49.5 | 1.5X |
| Aggregate w keys | codegen = T, row-based hashmap = T | 2113 | 2126 | 19 | 39.7 | 25.2 | 3.0X |
| Aggregate w keys | codegen = T, vectorized hashmap = T | 1310 | 1322 | 8 | 64.0 | 15.6 | 4.9X |
| Aggregate w string key | codegen = F | 2265 | 2268 | 4 | 9.3 | 108.0 | 1.0X |
| Aggregate w string key | codegen = T, hashmap = F | 1926 | 1941 | 20 | 10.9 | 91.8 | 1.2X |
| Aggregate w string key | codegen = T, row-based hashmap = T | 1280 | 1285 | 8 | 16.4 | 61.0 | 1.8X |
| Aggregate w string key | codegen = T, vectorized hashmap = T | 1118 | 1123 | 7 | 18.8 | 53.3 | 2.0X |
| Aggregate w decimal key | codegen = F | 2139 | 2167 | 40 | 9.8 | 102.0 | 1.0X |
| Aggregate w decimal key | codegen = T, hashmap = F | 1475 | 1488 | 18 | 14.2 | 70.3 | 1.5X |
| Aggregate w decimal key | codegen = T, row-based hashmap = T | 447 | 451 | 6 | 46.9 | 21.3 | 4.8X |
| Aggregate w decimal key | codegen = T, vectorized hashmap = T | 270 | 275 | 5 | 77.6 | 12.9 | 7.9X |
| Aggregate w multiple keys | codegen = F | 3788 | 3834 | 65 | 5.5 | 180.6 | 1.0X |
| Aggregate w multiple keys | codegen = T, hashmap = F | 2412 | 2423 | 16 | 8.7 | 115.0 | 1.6X |
| Aggregate w multiple keys | codegen = T, row-based hashmap = T | 1890 | 1895 | 6 | 11.1 | 90.1 | 2.0X |
| Aggregate w multiple keys | codegen = T, vectorized hashmap = T | 1739 | 1766 | 38 | 12.1 | 82.9 | 2.2X |
| max func bytecode size | codegen = F | 315 | 338 | 24 | 2.1 | 480.7 | 1.0X |
| max func bytecode size | codegen = T, hugeMethodLimit = 10000 | 178 | 200 | 13 | 3.7 | 272.3 | 1.8X |
| max func bytecode size | codegen = T, hugeMethodLimit = 1500 | 174 | 188 | 22 | 3.8 | 264.8 | 1.8X |
| cube | wholestage off | 1864 | 1867 | 5 | 2.8 | 355.5 | 1.0X |
| cube | wholestage on | 1060 | 1075 | 16 | 4.9 | 202.2 | 1.8X |
| BytesToBytesMap | UnsafeRowhash | 204 | 204 | 0 | 103.0 | 9.7 | 1.0X |
| BytesToBytesMap | murmur3 hash | 69 | 69 | 0 | 304.1 | 3.3 | 3.0X |
| BytesToBytesMap | fast hash | 41 | 42 | 1 | 517.4 | 1.9 | 5.0X |
| BytesToBytesMap | arrayEqual | 142 | 142 | 0 | 148.0 | 6.8 | 1.4X |
| BytesToBytesMap | Java HashMap (Long) | 65 | 72 | 5 | 323.6 | 3.1 | 3.1X |
| BytesToBytesMap | Java HashMap (two ints) | 89 | 93 | 2 | 235.4 | 4.2 | 2.3X |
| BytesToBytesMap | Java HashMap (UnsafeRow) | 544 | 546 | 2 | 38.5 | 26.0 | 0.4X |
| BytesToBytesMap | LongToUnsafeRowMap (opt=false) | 352 | 355 | 1 | 59.5 | 16.8 | 0.6X |
| BytesToBytesMap | LongToUnsafeRowMap (opt=true) | 74 | 75 | 1 | 284.6 | 3.5 | 2.8X |
| BytesToBytesMap | BytesToBytesMap (off Heap) | 623 | 628 | 7 | 33.7 | 29.7 | 0.3X |
| BytesToBytesMap | BytesToBytesMap (on Heap) | 624 | 627 | 3 | 33.6 | 29.8 | 0.3X |
| BytesToBytesMap | Aggregate HashMap | 31 | 31 | 0 | 680.7 | 1.5 | 6.6X |
Results from the earlier run on the c4a-standard-4 (4 vCPU, 16 GB memory) Arm64 VM in GCP (RHEL 9):
| agg w/o group | wholestage off | 32967 | 33442 | 672 | 63.6 | 15.7 | 1.0X |
| agg w/o group | wholestage on | 856 | 857 | 1 | 2451.2 | 0.4 | 38.5X |
| stddev | wholestage off | 3765 | 3769 | 5 | 27.8 | 35.9 | 1.0X |
| stddev | wholestage on | 870 | 872 | 2 | 120.6 | 8.3 | 4.3X |
| kurtosis | wholestage off | 19114 | 19155 | 58 | 5.5 | 182.3 | 1.0X |
| kurtosis | wholestage on | 943 | 946 | 3 | 111.2 | 9.0 | 20.3X |
| Aggregate w/ keys | codegen = F | 5401 | 5509 | 154 | 15.5 | 64.4 | 1.0X |
| Aggregate w/ keys | codegen = T, hashmap = F | 3103 | 3110 | 7 | 27.0 | 37.0 | 1.7X |
| Aggregate w/ keys | row-based hashmap = T | 1004 | 1017 | 11 | 83.5 | 12.0 | 5.4X |
| Aggregate w/ keys | vectorized hashmap = T | 707 | 711 | 3 | 118.7 | 8.4 | 7.6X |
| Aggregate w/ string key | codegen = F | 1938 | 1941 | 4 | 10.8 | 92.4 | 1.0X |
| Aggregate w/ string key | codegen = T, hashmap = F | 1208 | 1208 | 0 | 17.4 | 57.6 | 1.6X |
| Aggregate w/ string key | row-based hashmap = T | 820 | 829 | 5 | 25.6 | 39.1 | 2.4X |
| Aggregate w/ string key | vectorized hashmap = T | 756 | 756 | 0 | 27.8 | 36.0 | 2.6X |
| Aggregate w/ decimal key | codegen = F | 1878 | 1886 | 11 | 11.2 | 89.6 | 1.0X |
| Aggregate w/ decimal key | codegen = T, hashmap = F | 1116 | 1116 | 0 | 18.8 | 53.2 | 1.7X |
| Aggregate w/ decimal key | row-based hashmap = T | 411 | 423 | 11 | 51.0 | 19.6 | 4.6X |
| Aggregate w/ decimal key | vectorized hashmap = T | 278 | 280 | 2 | 75.4 | 13.3 | 6.8X |
| Aggregate w/ multiple keys | codegen = F | 3272 | 3277 | 8 | 6.4 | 156.0 | 1.0X |
| Aggregate w/ multiple keys | codegen = T, hashmap = F | 1802 | 1804 | 3 | 11.6 | 85.9 | 1.8X |
| Aggregate w/ multiple keys | row-based hashmap = T | 1461 | 1468 | 10 | 14.4 | 69.7 | 2.2X |
| Aggregate w/ multiple keys | vectorized hashmap = T | 1283 | 1285 | 3 | 16.4 | 61.2 | 2.6X |
| Max function bytecode size | codegen = F | 263 | 268 | 4 | 2.5 | 401.6 | 1.0X |
| Max function bytecode size | hugeMethodLimit = 10000 | 143 | 148 | 8 | 4.6 | 217.4 | 1.8X |
| Max function bytecode size | hugeMethodLimit = 1500 | 129 | 132 | 3 | 5.1 | 196.6 | 2.0X |
| Cube | wholestage off | 1572 | 1582 | 14 | 3.3 | 299.9 | 1.0X |
| Cube | wholestage on | 841 | 843 | 2 | 6.2 | 160.4 | 1.9X |
| BytesToBytesMap | UnsafeRowhash | 137 | 137 | 0 | 153.6 | 6.5 | 1.0X |
| BytesToBytesMap | murmur3 hash | 48 | 48 | 0 | 440.6 | 2.3 | 2.9X |
| BytesToBytesMap | fast hash | 42 | 42 | 0 | 499.2 | 2.0 | 3.3X |
| BytesToBytesMap | Aggregate HashMap | 23 | 23 | 0 | 913.0 | 1.1 | 5.9X |
When you compare the benchmarking results you will notice that on the Google Axion C4A Arm-based instances:
agg w/o group from 2728 ms to 856 ms).murmur3 and UnsafeRowhash on Arm-based instances are ~3×–5× faster, with the aggregate hashmap ~6× faster; the fast hash path is roughly on par.Overall, when whole-stage codegen and vectorized hashmap paths are used, you should see multi-fold speedups on the Google Axion C4A Arm-based instances.
