Getting started with Microsoft Azure Cobalt 100, Azure Linux 3.0, and Apache Spark
Create an Azure Cobalt 100 Arm64 virtual machine
Set up an Azure Linux 3.0 environment
Install Apache Spark on Azure Cobalt 100 processors
Validate Apache Spark on Azure Cobalt 100 Arm64 VMs
Benchmark Apache Spark
Within your running docker container image or your custom Azure Linux VM, follow the instructions to install Spark.
Start by installing Java, Python, and other essential tools:
sudo tdnf update -y
sudo tdnf install -y java-17-openjdk java-17-openjdk-devel git maven wget nano curl unzip awk tar
sudo tdnf install -y python3 python3-pip
Verify Java installation:
java -version
The output will look like:
openjdk 17.0.16 2025-07-15 LTS
OpenJDK Runtime Environment Microsoft-11926147 (build 17.0.16+8-LTS)
OpenJDK 64-Bit Server VM Microsoft-11926147 (build 17.0.16+8-LTS, mixed mode, sharing)
Verify Python installation:
python3 --version
Python 3.12.9
You can now download and configure Apache Spark on your Arm-based machine:
wget https://downloads.apache.org/spark/spark-3.5.6/spark-3.5.6-bin-hadoop3.tgz
tar -xzf spark-3.5.6-bin-hadoop3.tgz
sudo mv spark-3.5.6-bin-hadoop3 /opt/spark
Add this line to ~/.bashrc or ~/.zshrc to make the change persistent across terminal sessions.
echo 'export SPARK_HOME=/opt/spark' >> ~/.bashrc
echo 'export PATH=$PATH:$SPARK_HOME/bin:$SPARK_HOME/sbin' >> ~/.bashrc
echo 'export JAVA_HOME=/usr/lib/jvm/msopenjdk-17/' >> ~/.bashrc
Apply changes immediately in your running shell:
source ~/.bashrc
spark-submit --version
You should see output like:
Welcome to
____ __
/ __/__ ___ _____/ /__
_\ \/ _ \/ _ `/ __/ '_/
/___/ .__/\_,_/_/ /_/\_\ version 3.5.6
/_/
Using Scala version 2.12.18, OpenJDK 64-Bit Server VM, 17.0.15
Spark installation is complete. You can now proceed with the baseline testing of Spark in the next section.
