Getting started with Microsoft Azure Cobalt 100, Azure Linux 3.0, and Apache Spark
Create an Azure Cobalt 100 Arm64 virtual machine
Set up an Azure Linux 3.0 environment
Install Apache Spark on Azure Cobalt 100 processors
Validate Apache Spark on Azure Cobalt 100 Arm64 VMs
Benchmark Apache Spark
Apache Spark includes internal micro-benchmarks to evaluate the performance of core components such as SQL execution, aggregation, joins, and data source reads. These benchmarks are useful for comparing performance on Arm64 and x86_64 platforms in Azure.
This section shows you how to run Spark’s built-in SQL benchmarks using the SBT-based framework.
Clone the Apache Spark source code
git clone https://github.com/apache/spark.git
This downloads the full Spark source code, including test suites and benchmarking tools
Checkout the desired Spark version
cd spark/ && git checkout v4.0.0
Switch to the stable Spark 4.0.0 release, which supports the latest benchmarking APIs
Build Spark with the benchmarking profile
./build/sbt -Pbenchmarks clean package
This compiles Spark and its dependencies, enabling the benchmarking build profile
Run a built-in benchmark suite
./build/sbt -Pbenchmarks "sql/test:runMain org.apache.spark.sql.execution.benchmark.JoinBenchmark"
This runs the JoinBenchmark, which measures the performance of SQL join operations such as SortMergeJoin and BroadcastHashJoin. It evaluates how Spark SQL optimizes join strategies, especially with and without WholeStageCodegen
You should see output similar to the following:
[info] Running benchmark: Join w long
[info] Running case: Join w long wholestage off
[info] Stopped after 2 iterations, 5297 ms
[info] Running case: Join w long wholestage on
[info] Stopped after 5 iterations, 4238 ms
[info] OpenJDK 64-Bit Server VM 17.0.15+6-LTS on Linux 6.6.92.2-2.azl3
[info] 06:05:52.695 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] Unknown processor
[info] Join w long: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] ------------------------------------------------------------------------------------------------------------------------
[info] Join w long wholestage off 2345 2649 429 8.9 111.8 1.0X
[info] Join w long wholestage on 842 848 5 24.9 40.2 2.8X
[info] Running benchmark: Join w long duplicated
[info] Running case: Join w long duplicated wholestage off
[info] Stopped after 2 iterations, 3931 ms
[info] Running case: Join w long duplicated wholestage on
[info] Stopped after 5 iterations, 4350 ms
[info] 06:06:05.954 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] Join w long duplicated: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] Join w long duplicated wholestage off 1965 1966 1 10.7 93.7 1.0X
[info] Join w long duplicated wholestage on 865 870 4 24.2 41.3 2.3X
[info] Running benchmark: Join w 2 ints
[info] Running case: Join w 2 ints wholestage off
[info] Stopped after 2 iterations, 216362 ms
[info] Running case: Join w 2 ints wholestage on
[info] Stopped after 5 iterations, 538414 ms
[info] 06:22:16.697 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] Join w 2 ints: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] Join w 2 ints wholestage off 108110 108181 101 0.2 5155.1 1.0X
[info] Join w 2 ints wholestage on 107521 107683 109 0.2 5127.0 1.0X
[info] Running benchmark: Join w 2 longs
[info] Running case: Join w 2 longs wholestage off
[info] Stopped after 2 iterations, 7806 ms
[info] Running case: Join w 2 longs wholestage on
[info] Stopped after 5 iterations, 10771 ms
[info] 06:22:41.568 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] Join w 2 longs: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] Join w 2 longs wholestage off 3867 3903 51 5.4 184.4 1.0X
[info] Join w 2 longs wholestage on 2061 2154 113 10.2 98.3 1.9X
[info] Running benchmark: Join w 2 longs duplicated
[info] Running case: Join w 2 longs duplicated wholestage off
[info] Stopped after 2 iterations, 17850 ms
[info] Running case: Join w 2 longs duplicated wholestage on
[info] Stopped after 5 iterations, 26145 ms
[info] 06:23:40.009 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] Join w 2 longs duplicated: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] Join w 2 longs duplicated wholestage off 8923 8925 4 2.4 425.5 1.0X
[info] Join w 2 longs duplicated wholestage on 5224 5229 8 4.0 249.1 1.7X
[info] Running benchmark: outer join w long
[info] Running case: outer join w long wholestage off
[info] Stopped after 2 iterations, 3070 ms
[info] Running case: outer join w long wholestage on
[info] Stopped after 5 iterations, 4178 ms
[info] 06:23:52.993 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] outer join w long: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] outer join w long wholestage off 1531 1535 6 13.7 73.0 1.0X
[info] outer join w long wholestage on 833 836 3 25.2 39.7 1.8X
[info] Running benchmark: semi join w long
[info] Running case: semi join w long wholestage off
[info] Stopped after 2 iterations, 2152 ms
[info] Running case: semi join w long wholestage on
[info] Stopped after 5 iterations, 2569 ms
[info] 06:24:02.077 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] semi join w long: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] semi join w long wholestage off 1069 1076 10 19.6 51.0 1.0X
[info] semi join w long wholestage on 512 514 2 40.9 24.4 2.1X
[info] Running benchmark: sort merge join
[info] Running case: sort merge join wholestage off
[info] Stopped after 2 iterations, 1106 ms
[info] Running case: sort merge join wholestage on
[info] Stopped after 5 iterations, 2406 ms
[info] 06:24:10.485 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] sort merge join: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] sort merge join wholestage off 551 553 3 3.8 262.7 1.0X
[info] sort merge join wholestage on 478 481 3 4.4 227.8 1.2X
[info] Running benchmark: sort merge join with duplicates
[info] Running case: sort merge join with duplicates wholestage off
[info] Stopped after 2 iterations, 2426 ms
[info] Running case: sort merge join with duplicates wholestage on
[info] Stopped after 5 iterations, 5285 ms
[info] 06:24:23.172 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] sort merge join with duplicates: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] ------------------------------------------------------------------------------------------------------------------------------
[info] sort merge join with duplicates wholestage off 1207 1213 9 1.7 575.4 1.0X
[info] sort merge join with duplicates wholestage on 1029 1057 18 2.0 490.5 1.2X
[info] Running benchmark: shuffle hash join
[info] Running case: shuffle hash join wholestage off
[info] Stopped after 2 iterations, 1170 ms
[info] Running case: shuffle hash join wholestage on
[info] Stopped after 5 iterations, 2037 ms
[info] 06:24:31.312 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] shuffle hash join: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] shuffle hash join wholestage off 578 585 9 7.3 137.9 1.0X
[info] shuffle hash join wholestage on 385 408 13 10.9 91.8 1.5X
[info] Running benchmark: broadcast nested loop join
[info] Running case: broadcast nested loop join wholestage off
[info] Stopped after 2 iterations, 53739 ms
[info] Running case: broadcast nested loop join wholestage on
[info] Stopped after 5 iterations, 94642 ms
[info] 06:27:45.952 ERROR org.apache.spark.util.Utils: Process List(/usr/bin/grep, -m, 1, model name, /proc/cpuinfo) exited with code 1:
[info] broadcast nested loop join: Best Time(ms) Avg Time(ms) Stdev(ms) Rate(M/s) Per Row(ns) Relative
[info] broadcast nested loop join wholestage off 26847 26870 32 0.8 1280.2 1.0X
[info] broadcast nested loop join wholestage on 18857 18928 84 1.1 899.2 1.4X
[success] Total time: 1644 s (27:24), completed Jul 25, 2025, 6:27:46 AM
Benchmark results on Azure Linux 3.0 were consistent across both Docker containers and virtual machines.
For easier comparison, shown here is a summary of benchmark results collected on an Arm64 D4ps_v6 Azure virtual machine created from a custom Azure Linux 3.0 image using the AArch64 ISO.
| Benchmark | Wholestage | Best Time (ms) | Avg Time (ms) | Stdev (ms) | Rate (M/s) | Per Row (ns) | Relative |
| Join w long | Off | 2345 | 2649 | 429 | 8.9 | 111.8 | 1.0X |
| On | 842 | 848 | 5 | 24.9 | 40.2 | 2.8X | |
| Join w long duplicated | Off | 1965 | 1966 | 1 | 10.7 | 93.7 | 1.0X |
| On | 865 | 870 | 4 | 24.2 | 41.3 | 2.3X | |
| Join w 2 ints | Off | 108110 | 108181 | 101 | 0.2 | 5155.1 | 1.0X |
| On | 107521 | 107683 | 109 | 0.2 | 5127.0 | 1.0X | |
| Join w 2 longs | Off | 3867 | 3903 | 51 | 5.4 | 184.4 | 1.0X |
| On | 2061 | 2154 | 113 | 10.2 | 98.3 | 1.9X | |
| Join w 2 longs duplicated | Off | 8923 | 8925 | 4 | 2.4 | 425.5 | 1.0X |
| On | 5224 | 5229 | 8 | 4.0 | 249.1 | 1.7X | |
| Outer join w long | Off | 1531 | 1535 | 6 | 13.7 | 73.0 | 1.0X |
| On | 833 | 836 | 3 | 25.2 | 39.7 | 1.8X | |
| Semi join w long | Off | 1069 | 1076 | 10 | 19.6 | 51.0 | 1.0X |
| On | 512 | 514 | 2 | 40.9 | 24.4 | 2.1X | |
| Sort merge join | Off | 551 | 553 | 3 | 3.8 | 262.7 | 1.0X |
| On | 478 | 481 | 3 | 4.4 | 227.8 | 1.2X | |
| Sort merge join with duplicates | Off | 1207 | 1213 | 9 | 1.7 | 575.4 | 1.0X |
| On | 1029 | 1057 | 18 | 2.0 | 490.5 | 1.2X | |
| Shuffle hash join | Off | 578 | 585 | 9 | 7.3 | 137.9 | 1.0X |
| On | 385 | 408 | 13 | 10.9 | 91.8 | 1.5X | |
| Broadcast nested loop join | Off | 26847 | 26870 | 32 | 0.8 | 1280.2 | 1.0X |
| On | 18857 | 18928 | 84 | 1.1 | 899.2 | 1.4X |
Shown here is a summary of the benchmark results collected on an x86_64 D4s_v4 Azure virtual machine using the Azure Linux 3.0 image published by Ntegral Inc.
| Join w long | Off | 3168 | 3185 | 24 | 6.6 | 151.1 | 1.0X |
| On | 1509 | 1562 | 61 | 13.9 | 72.0 | 2.1X | |
| Join w long duplicated | Off | 2490 | 2504 | 20 | 8.4 | 118.7 | 1.0X |
| On | 1151 | 1181 | 27 | 18.2 | 54.9 | 2.2X | |
| Join w 2 ints | Off | 217074 | 219364 | 3239 | 0.1 | 10350.9 | 1.0X |
| On | 119692 | 119756 | 74 | 0.2 | 5707.4 | 1.8X | |
| Join w 2 longs | Off | 4367 | 4401 | 49 | 4.8 | 208.2 | 1.0X |
| On | 2952 | 3003 | 35 | 7.1 | 140.8 | 1.5X | |
| Join w 2 longs duplicated | Off | 10255 | 10286 | 45 | 2.0 | 489.0 | 1.0X |
| On | 7243 | 7300 | 36 | 2.9 | 345.4 | 1.4X | |
| Outer join w long | Off | 2401 | 2422 | 30 | 8.7 | 114.5 | 1.0X |
| On | 1544 | 1564 | 17 | 13.6 | 73.6 | 1.6X | |
| Semi join w long | Off | 1344 | 1350 | 8 | 15.6 | 64.1 | 1.0X |
| On | 673 | 685 | 12 | 31.2 | 32.1 | 2.0X | |
| Sort merge join | Off | 1144 | 1145 | 1 | 1.8 | 545.6 | 1.0X |
| On | 1177 | 1228 | 46 | 1.8 | 561.4 | 1.0X | |
| Sort merge join w/ duplicates | Off | 2075 | 2113 | 55 | 1.0 | 989.4 | 1.0X |
| On | 1704 | 1720 | 14 | 1.2 | 812.3 | 1.2X | |
| Shuffle hash join | Off | 672 | 674 | 2 | 6.2 | 160.3 | 1.0X |
| On | 524 | 525 | 1 | 8.0 | 124.9 | 1.3X | |
| Broadcast nested loop join | Off | 36060 | 36103 | 62 | 0.6 | 1719.5 | 1.0X |
| On | 31254 | 31346 | 78 | 0.7 | 1490.3 | 1.2X |
When comparing the results on Arm64 vs x86_64 virtual machines:
You have now benchmarked Apache Spark on an Azure Cobalt 100 Arm64 virtual machine and compared results with x86_64.
