Snort is an Open Source Intrusion Prevention System (IPS). Snort uses a series of rules to define malicious network activity. If malicious activity is detected, Snort generates alerts.
Snort 3 benefits from multithreading, which means that it enables the concurrent processing of multiple packet processing threads with a single Snort instance. This optimization frees up additional memory for further packet processing.
In order to enable multithreading in Snort 3, specify the quantity of threads designated for processing network traffic using either of these two options:
--max-packet-threads-zThese instructions have been tested on an AWS EC2 Graviton4 instance, based on Arm Neoverse V2. The examples work best if you have at least 16 cores in your system.
To install Snort 3, use a text editor to copy-and-paste the text below and save the script on your Arm server in a file named install-snort.sh.
#!/usr/bin/env bash
# Copyright (c) 2022-2024, Arm Limited.
# SPDX-License-Identifier: Apache-2.0
# author : PreemaMerlin.Dsouza@arm.com
# Define a list of dependency package URLs
declare -a PACKAGE_URLS=(
"https://github.com/snort3/snort3/archive/refs/tags/3.3.5.0.tar.gz"
"https://sourceforge.net/projects/pcre/files/pcre/8.45/pcre-8.45.tar.gz"
"https://github.com/VectorCamp/vectorscan/archive/refs/tags/vectorscan/5.4.11.tar.gz"
"https://github.com/snort3/libdaq/archive/refs/tags/v3.0.16.tar.gz"
"https://boostorg.jfrog.io/artifactory/main/release/1.86.0/source/boost_1_86_0.tar.gz"
"https://github.com/rurban/safeclib/releases/download/v3.8.1/safeclib-3.8.1.tar.gz"
"https://github.com/gperftools/gperftools/releases/download/gperftools-2.13/gperftools-2.13.tar.gz"
downloadPackages()
for url in "${PACKAGE_URLS[@]}"; do
# Extract the file name from the URL
fname=$(basename "$url")
fpath="${ROOT_DIR}/${fname}"
# Check if the file already exists
if [[ -f "$fpath" ]]; then
echo "File $fname already exists. Skipping download."
else
# Download the file using wget
echo "File $fname not found. Downloading..."
wget -O "$fpath" "$url"
if [[ $? -eq 0 ]]; then
echo "$fname download complete"
else
echo "ERROR:$fname download Fail."
fi
fi
done
installPackages()
echo "@@@@@@@@@@@@@@@@@@ Installing packages ... @@@@@@@@@@@@@@@@@@@@"
if [[ -r /etc/os-release ]]; then
OS_NAME=$(grep -w "NAME" /etc/os-release | cut -d= -f2 | tr -d '"')
OS_VERSION_ID=$(grep -w "VERSION_ID" /etc/os-release | cut -d= -f2 | tr -d '"')
if [[ "${OS_NAME}" == "Ubuntu" ]]; then
echo "OS: ${OS_NAME} ${OS_VERSION_ID}"
else
echo "Error: This script is only for ubuntu"
exit 1
fi
if [[ "${OS_VERSION_ID}" != "22.04" && "${OS_VERSION_ID}" != "20.04" ]];then
echo "Warning: OS: ${OS_NAME} ${OS_VERSION_ID}"
echo "Warning: Ubuntu 20.04 or 22.04 is recommended"
fi
else
echo "Error: OS information detection failed"
exit 1
fi
sudo apt-get update
sudo apt-get install -y $LIST_OF_APPS
# required to get optimized result from Snort3
downloadPackages
mkdir -p ${ROOT_DIR}/snort3
tar -xzf 3.3.5.0.tar.gz --directory ${ROOT_DIR}/snort3 --strip-components=1
echo "@@@@@@@@@@@@@@@@@@ Installing Snort3 Dependencies ... @@@@@@@@@@@@@@@@@@@@"
mkdir -p ${SNORT_DIR}
mkdir -p $SNORT_DIR/pcre
tar -xvf pcre-8.45.tar.gz --directory $SNORT_DIR/pcre --strip-components=1
#vector scan
mkdir -p $SNORT_DIR/vectorscan
tar -xzvf 5.4.11.tar.gz --directory $SNORT_DIR/vectorscan --strip-components=1
#libdaq
mkdir -p $SNORT_DIR/libdaq
tar -xvzf v3.0.16.tar.gz --directory $SNORT_DIR/libdaq --strip-components=1
#required to get optimized result from vectorscan
mkdir -p $SNORT_DIR/boost
tar -xvf boost_1_86_0.tar.gz -C $SNORT_DIR/boost --strip-components=1
#safeclib
mkdir -p $SNORT_DIR/safeclib
tar -xzvf safeclib-3.8.1.tar.gz --directory $SNORT_DIR/safeclib --strip-components=1
#gperftools
mkdir -p $SNORT_DIR/gperftools
tar -xzvf gperftools-2.13.tar.gz --directory $SNORT_DIR/gperftools --strip-components=1
echo "@@@@@@@@@@@@@@@@@@ Packages installed @@@@@@@@@@@@@@@@@@@@"
buildInstall()
echo "@@@@@@@@@@@@@@@@@@ Build & Installation ... Start @@@@@@@@@@@@@@@@@@@@"
cd $SNORT_DIR/libdaq
mkdir -p ${SNORT_DIR}/libdaq/install
./bootstrap
./configure
make -j${NUM_JOBS}
sudo make install
cd ${SNORT_DIR}/safeclib
./configure
make -j${NUM_JOBS}
sudo make -j${NUM_JOBS} install
cd $SNORT_DIR/gperftools
./configure --with-tcmalloc-pagesize=64
make -j${NUM_JOBS}
cd $SNORT_DIR/pcre
./configure
make -j${NUM_JOBS}
cd ${SNORT_DIR}/vectorscan
cmake -DBOOST_ROOT=$(SNORT_DIR)/boost -DCMAKE_BUILD_TYPE=Release .
make -j${NUM_JOBS}
cd ${ROOT_DIR}/snort3
./configure_cmake.sh --prefix=/usr/local --build-type=Release --with-daq-includes=/usr/local/include/ --with-daq-libraries=/usr/local/lib/ --enable-unit-tests --enable-tcmalloc
cd ${ROOT_DIR}/snort3/build
make -j$NUM_JOBS
sudo make -j$NUM_JOBS install
echo "@@@@@@@@@@@@@@@@@@ Build & Installation ... Done @@@@@@@@@@@@@@@@@@@@"
#------ Execution Start ----------#
# provide nproc count to the scripts , it will be used as -j for make
if [[ $# -ne 2 ]]; then
echo "Usage: $0 <current_working_directory> <nproc>"
exit 1
fi
ROOT_DIR=$(pwd)/"$1"
NUM_JOBS="$2"
SNORT_DIR=${ROOT_DIR}/snort3/dependencies
set -e
LIST_OF_APPS="sudo net-tools build-essential manpages-dev libnuma-dev python3
python3-venv cmake meson pkg-config python3-pyelftools lshw
util-linux iperf3 nginx libboost-all-dev ragel libsqlite3-dev
libpcap-dev libdumbnet-dev libluajit-5.1-dev zlib1g-dev
libhwloc-dev liblzma-dev libssl-dev libgoogle-perftools-dev
libpcre++-dev flex openssl libunwind-dev autotools-dev
libhugetlbfs-bin autoconf libmnl-dev bats wget unzip iproute2
git pkg-config cpputest libtool bison libcmocka-dev
libnetfilter-queue-dev ethtool"
# nprc should be a positive integer)
if ! [[ "$NUM_JOBS" =~ ^[0-9]+$ ]] || [[ "$NUM_JOBS" -le 0 ]]; then
echo "Error: nprc should be a positive integer."
exit 1
fi
cd ${ROOT_DIR}
installPackages
buildInstall
echo 'export LD_LIBRARY_PATH="/usr/local/lib:$LD_LIBRARY_PATH"' >> $HOME/.bashrc
echo 'make sure to source ~/.bashrc or set LD_LIBRARY_PATH using:"'
echo ' export LD_LIBRARY_PATH="/usr/local/lib:$LD_LIBRARY_PATH"'
The script takes two arguments:
To create a new directory named build which lists the number of processors in your system, run the script:
bash ./install-snort.sh build `nproc`
You do not need to run the script as root, but you do need to be running Ubuntu 20.04 or 22.04, and have sudo permission.
When the build completes, you will have the Snort 3 directory with all compiled software, and the snort executable will be located in /usr/local/bin.
To verify completed installation, run the command below and look at the version that it prints to screen:
snort -V
__output__,,_ -*> Snort++ <*-
__output__ o" )~ Version 3.3.5.0
__output__ '''' By Martin Roesch & The Snort Team
__output__ http://snort.org/contact#team
__output__ Copyright (C) 2014-2024 Cisco and/or its affiliates. All rights reserved.
__output__ Copyright (C) 1998-2013 Sourcefire, Inc., et al.
__output__ Using DAQ version 3.0.16
__output__ Using Hyperscan version 5.4.11 2024-09-12
__output__ Using libpcap version 1.10.1 (with TPACKET_V3)
__output__ Using LuaJIT version 2.1.0-beta3
__output__ Using LZMA version 5.2.5
__output__ Using OpenSSL 3.0.2 15 Mar 2022
__output__ Using PCRE version 8.45 2021-06-15
__output__ Using ZLIB version 1.2.11
Do not delete the build directory as you will use it in the next step.
Now you can move on to learn about how to test Snort 3 multithreading.
