What you've learned
You should now know how to:
  • Install Snort and dependencies.
  • Configure Snort Lua files to enable multithreading.
  • Use multithreading to process capture files and measure performance.
Knowledge Check
Which of the following is a key benefit of Snort 3's multithreading support?
Which parameter is used to enable multithreading in Snort 3?
In Snort 3, which Data Acquisition (DAQ) module is used to read capture files for packet processing?
