Deploy and integrate AWS Lambda with DynamoDB using the Serverless Framework
What you've learned
You should now know how to:
  • Create a multi-resource Serverless Framework solution.
  • Automate deployment of AWS Lambda function consuming data from DynamoDB.
Knowledge Check
How does the serverless.yml file facilitate the deployment and management of serverless applications and what are its key components?
What steps are involved in using the serverless deploy command and how does it ensure that all resources and functions are correctly provisioned and configured in AWS?
How can you configure an AWS Lambda function to interact with a DynamoDB table and what are the benefits of using ES Modules and IAM roles in this context?
