Overview
This section explains how to install and configure Rust on your GCP SUSE Arm64 VM, preparing your environment for building and benchmarking Rust applications.
Update your system
Update the system and install essential build tools required for compiling Rust programs:
sudo zypper refresh
sudo zypper update -y
sudo zypper install -y curl gcc make
This ensures your system has the latest packages and the necessary compilation tools.
Install Rust using rustup
Rust provides an official installer script via rustup that handles the setup automatically:
curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh
When prompted, select option 1 for the default installation. This installs the latest stable version of Rust along with Cargo, Rust’s package manager and build system.
Configure your environment
Activate Rust’s environment variables for your current shell session:
source $HOME/.cargo/env
This command adds the Rust toolchain to your PATH, making the rustc compiler and cargo commands available.
Verify the installation
Confirm that Rust and Cargo installed successfully by checking their versions:
rustc --version
cargo --version
The output is similar to:
        rustc 1.91.0 (f8297e351 2025-10-28)
cargo 1.91.0 (ea2d97820 2025-10-10)
Your Rust installation is now complete and ready for development on your Arm64 instance.
