Overview
This section demonstrates how to benchmark Rust performance using cargo bench and the Criterion library to measure code execution speed and performance consistency on Arm64 hardware.
Create a benchmark project
Create a new Rust project specifically for benchmarking:
cargo new rust-benchmark
cd rust-benchmark
Configure Criterion as a dependency
Criterion is the recommended benchmarking crate for Rust. Open the Cargo.toml file in your project root directory and replace the existing content with:
[dependencies]
criterion = "0.5"
[[bench]]
name = "my_benchmark"
harness = false
This configuration enables Criterion for high-precision benchmarking and disables the default test harness.
Create the benchmark directory and file
Create the benchmark structure that Cargo expects:
mkdir benches
Create a new file named my_benchmark.rs in the benches/ directory and add the following benchmark code to measure Fibonacci number calculation performance:
use criterion::{black_box, Criterion, criterion_group, criterion_main};
// Example benchmark function
fn fibonacci(n: u64) -> u64 {
    match n {
        0 => 0,
        1 => 1,
        n => fibonacci(n - 1) + fibonacci(n - 2),
fn benchmark_fibonacci(c: &mut Criterion) {
    c.bench_function("fibonacci 20", |b| b.iter(|| fibonacci(black_box(20))));
criterion_group!(benches, benchmark_fibonacci);
criterion_main!(benches);
This code implements a recursive Fibonacci function and measures how efficiently Rust computes the 20th Fibonacci number. The black_box function prevents the compiler from optimizing away the benchmark.
Run the benchmark
Execute the benchmark using Cargo:
cargo bench
Cargo compiles your code with optimizations enabled and runs the Criterion benchmarks, providing detailed performance metrics.
The output is similar to:
        Running benches/my_benchmark.rs (target/release/deps/my_benchmark-f40a307ef9cad515)
Gnuplot not found, using plotters backend
fibonacci 20            time:   [12.026 µs 12.028 µs 12.030 µs]
Found 1 outliers among 100 measurements (1.00%)
  1 (1.00%) low mild
Performance summary
The benchmark output provides several key metrics: the average time represents the mean execution time across benchmark runs, outliers identify runs that were significantly slower or faster than average, and the plotting backend indicates that plotters is being used since Gnuplot wasn’t found on the system.
The following table shows results from running the benchmark on a c4a-standard-4 (4 vCPU, 16 GB memory) Arm64 VM in GCP using SUSE:
BenchmarkAverage Time (µs)Min (µs)Max (µs)Outliers (%)Remarks
fibonacci 2012.02812.02612.0301.00%Stable performance with minimal variation
The Fibonacci benchmark demonstrates consistent performance on the Arm64 platform. The average execution time of 12.028 µs indicates efficient CPU computation, while only 1% of measurements were outliers. This low variance confirms Rust’s reliable execution speed and performance stability on Arm64 architecture.
