Now that Rust is installed, verify the installation, build functionality, and compilation performance on your Arm-based Axion C4A instance.
Create and build a simple “Hello, World” application to verify that Rust is working correctly:
mkdir rust-baseline
cd rust-baseline
cargo new hello
cd hello
cargo run
This creates a new Rust project and runs it immediately. The cargo new hello command generates a default Rust project with the necessary files including main.rs and Cargo.toml.
The output is similar to:
Compiling hello v0.1.0 (/home/gcpuser/rust-baseline/hello)
Finished `dev` profile [unoptimized + debuginfo] target(s) in 0.19s
Running `target/debug/hello`
Hello, world!
This confirms that Rust and Cargo are properly configured on your Arm64 VM.
Use the time command to measure compilation performance on the Arm64 processor:
cargo clean
time cargo build
The cargo clean command removes all build artifacts, ensuring you measure a complete compilation from scratch.
Removed 21 files, 7.7MiB total
Finished `dev` profile [unoptimized + debuginfo] target(s) in 0.14s
real 0m0.186s
user 0m0.118s
sys 0m0.071s
The timing results show that Rust compilation performs well on the Arm64 architecture, with the “real” time indicating the total elapsed time for the build process.
You’ve successfully verified your Rust installation and measured baseline compilation performance on the C4A instance. In the next section, you’ll benchmark Rust code execution using Criterion to measure runtime performance and consistency.
