Overview
In this section, you will learn how to provision a Google Axion C4A Arm virtual machine on Google Cloud Platform (GCP) using the c4a-standard-4 (4 vCPUs, 16 GB memory) machine type in Google Cloud Console.
Note
For support on GCP setup, see the Learning Path Getting started with Google Cloud Platform .
Provision a Google Axion C4A Arm VM in Google Cloud Console
To create a virtual machine based on the C4A instance type:
  • Navigate to Google Cloud Console .
  • Go to Compute Engine > VM Instances and select Create Instance.
  • Under Machine configuration:
    • Populate fields such as Instance name, Region, and Zone.
      • Set Series to C4A.
      • Select c4a-standard-4 for machine type, as shown below:
      Image Alt Text:Google Cloud Console machine configuration interface showing C4A series selected and c4a-standard-4 machine type highlighted with 4 vCPUs and 16 GB memory specifications alt-text Creating a Google Axion C4A Arm virtual machine in Google Cloud Console
  • Under OS and Storage, select Change, then select an Arm64-based OS image. For this Learning Path, use SUSE Linux Enterprise Server. Pick the preferred version for your operating system. Ensure you select the Arm image variant. Select Select.
  • Under Networking, enable Allow HTTP traffic.
  • Select Create to launch the instance.
What you’ve accomplished
You’ve successfully created a Google Axion C4A Arm virtual machine on GCP. Your Arm-based cloud environment is ready for Ruby on Rails development.
