Install micromamba to set up python 3.10 at path /opt/conda310, as required by the rtp-llm build system:
"${SHELL}" <(curl -L micro.mamba.pm/install.sh)
source ~/.bashrc
sudo ${HOME}/.local/bin/micromamba -r /opt/conda310 install python=3.10
micromamba -r /opt/conda310 shell
Install bazelisk to build rtp-llm:
wget https://github.com/bazelbuild/bazelisk/releases/download/v1.22.1/bazelisk-linux-arm64
chmod +x bazelisk-linux-arm64
sudo mv bazelisk-linux-arm64 /usr/bin/bazelisk
Install git/gcc/g++:
sudo apt install git -y
sudo apt install build-essential -y
Install the openblas development package and fix the header paths:
sudo apt install libopenblas-dev
sudo mkdir -p /usr/include/openblas
sudo ln -sf /usr/include/aarch64-linux-gnu/cblas.h /usr/include/openblas/cblas.h
You are now ready to start building rtp-llm.
Start by cloning the source repository for rtp-llm:
git clone https://github.com/alibaba/rtp-llm
cd rtp-llm
git checkout 4656265
Next, comment out lines 7-10 in deps/requirements_lock_torch_arm.txt as some hosts are not accessible from the web:
sed -i '7,10 s/^/#/' deps/requirements_lock_torch_arm.txt
By default, rtp-llm builds for GPU only on Linux. You need to provide the additional flag --config=arm to build it for the Arm CPU that you will run it on.
Configure and build:
bazelisk build --config=arm //maga_transformer:maga_transformer_aarch64
The output from your build should look like this:
INFO: 10094 processes: 8717 internal, 1377 local.
INFO: Build completed successfully, 10094 total actions
Install the built wheel package:
pip install bazel-bin/maga_transformer/maga_transformer-0.2.0-cp310-cp310-linux_aarch64.whl
Create a file named python-test.py in your /tmp directory with the contents shown below:
from maga_transformer.pipeline import Pipeline
from maga_transformer.model_factory import ModelFactory
from maga_transformer.openai.openai_endpoint import OpenaiEndopoint
from maga_transformer.openai.api_datatype import ChatCompletionRequest, ChatMessage, RoleEnum
from maga_transformer.distribute.worker_info import update_master_info
import asyncio
import json
import os
async def main():
update_master_info('127.0.0.1', 42345)
os.environ["MODEL_TYPE"] = os.environ.get("MODEL_TYPE", "qwen2")
os.environ["CHECKPOINT_PATH"] = os.environ.get("CHECKPOINT_PATH", "Qwen/Qwen2-0.5B-Instruct")
os.environ["RESERVER_RUNTIME_MEM_MB"] = "0"
os.environ["DEVICE_RESERVE_MEMORY_BYTES"] = f"{128 * 1024 ** 2}"
model_config = ModelFactory.create_normal_model_config()
model = ModelFactory.from_huggingface(model_config.ckpt_path, model_config=model_config)
pipeline = Pipeline(model, model.tokenizer)
# usual request
for res in pipeline("<|im_start|>user\nhello, what's your name<|im_end|>\n<|im_start|>assistant\n", max_new_tokens = 100):
print(res.generate_texts)
# openai request
openai_endpoint = OpenaiEndopoint(model)
messages = [
ChatMessage(**{
"role": RoleEnum.user,
"content": "Who are you?",
request = ChatCompletionRequest(messages=messages, stream=False)
response = openai_endpoint.chat_completion(request_id=0, chat_request=request, raw_request=None)
async for res in response:
pass
print((await response.gen_complete_response_once()).model_dump_json(indent=4))
pipeline.stop()
if __name__ == '__main__':
asyncio.run(main())
Now run this file:
python /tmp/python-test.py
If rtp-llm has built correctly on your machine, you will see the LLM model response for the prompt input.
A snippet of the output is shown below:
['I am a large language model created by Alibaba Cloud. My name is Qwen.']
"id": "chat-",
"object": "chat.completion",
"created": 1730272196,
"model": "AsyncModel",
"choices": [
"index": 0,
"message": {
"role": "assistant",
"content": "I am a large language model created by Alibaba Cloud. I am called Qwen.",
"function_call": null,
"tool_calls": null
"finish_reason": "stop"
"usage": {
"prompt_tokens": 23,
"total_tokens": 40,
"completion_tokens": 17,
"completion_tokens_details": null,
"prompt_tokens_details": null
"debug_info": null,
"aux_info": null
You have successfully run a LLM chatbot with Arm optimizations, running on an Arm AArch64 CPU on your server.
You can continue to experiment with the chatbot by trying out different prompts on the model.
