What you've learned
You should now know how to:
  • Build rtp-llm on an Arm-based server.
  • Download a Qwen model from Hugging Face.
  • Run a Large Language Model with rtp-llm.
Knowledge Check
Are at least four cores, 16GB of RAM, and 32GB of disk storage required to run the LLM chatbot using rtp-llm on an Arm-based server?
Does the rtp-llm project use the --config=arm option to optimize LLM inference for Arm CPUs?
Is the given Python script the only way to run the LLM chatbot on an Arm AArch64 CPU and output a response from the model?
