# Test With FVP
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-quick-start/)
- [Environment Setup](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-quick-start/environment-setup-1/)
- [Build the software stack](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-quick-start/build-2/)
- [Test With FVP](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-quick-start/test-with-fvp-3/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-quick-start/_next-steps/)
## FVP
The firmware build can be executed on the Neoverse N2 Reference Design FVP that you can download from [Arm Ecosystem FVPs](https://developer.arm.com/downloads/-/arm-ecosystem-fvps).
### Set up the FVP
Download the FVP from the previous page, or directly with:
wget https://developer.arm.com/-/cdn-downloads/permalink/FVPs-Neoverse-Infrastructure/RD-N2/FVP_RD_N2_11.25_23_Linux64.tgz
Unpack the tarball and run the install script:
tar -xf FVP_RD_N2_11.25_23_Linux64.tgz
./FVP_RD_N2.sh --i-agree-to-the-contained-eula --no-interactive
Export the path to the `FVP_RD_N2` model binary as the `MODEL` environment variable.
export MODEL=/home/ubuntu/FVP_RD_N2/models/Linux64_GCC-9.3/FVP_RD_N2
### Screen configuration for UARTs
The model will output UARTs to local ports 5000..5010. If you were running the model on a local machine, or had X11 forwarding set up, the model opens a number of xterm terminals with the UART output piped to them, one per port.
If you do not have X11 forwarding and you are executing on a remote server, you can use `screen` to spawn persistent terminals that listen on the ports and obtain the information that way.
Open a new terminal where you start a `screen` session and connect to it.
To install `screen` use:
sudo apt-get install screen
Use a text editor to create the configuration file below, which will set up `screen` windows for each UART.
#### Create screen-uart.cfg
Create a config file so that when you start a session, there are ten windows and each periodically tries to connect to one of the local ports where a UART is running. You can change the titles of the windows so that you can identify each terminal. The resulting `screen-uart.cfg` file looks like this:
# Split horizontally into two
split -v
# Start the SCP UART telnet
screen -t "SCP UART" run-one-constantly telnet localhost 5000
# Split screen and start MCP UART
split
focus
screen -t "MCP term" run-one-constantly telnet localhost 5001
# Split screen and start AP-NS UART
split
focus
screen -t "AP-NS term" run-one-constantly telnet localhost 5002
# Split screen and start AP-S UART
split
focus
screen -t "AP-S term" run-one-constantly telnet localhost 5003
# Focus on the second vertical pane
focus
# Start a second set of terminals
screen -t "IO-1" run-one-constantly telnet localhost 5004
# Split
split
focus
screen -t "IO-2" run-one-constantly telnet localhost 5005
# Split
split
focus
screen -t "S-0" run-one-constantly telnet localhost 5006
# Split
split
focus
screen -t "S-1" run-one-constantly telnet localhost 5007
# Split
split
focus
screen -t "MCP-extern" run-one-constantly telnet localhost 5008
# Split
split
focus
screen -t "term-0" run-one-constantly telnet localhost 5009
# Split
split
focus
screen -t "term-1" run-one-constantly telnet localhost 5010
# Focus back on the AP-NS UART
focus
focus
focus
Start the screen session with this configuration file:
screen -c screen-uart.cfg
The result should be similar to:
![Image Alt Text:screen terminals alt-text](/learning-paths/servers-and-cloud-computing/refinfra-quick-start/images/terminal.png)
These errors are expected as there is nothing talking to the ports. You can quit from within the screen by the getting a prompt using `Ctrl+A:` key combination, followed by the `quit` command. Alternatively, `Ctrl+A D` will detach the screen session and send it to background.
### Running the FVP
In your original terminal, launch the FVP using the supplied script:
./uefi.sh -p rdn2
Observe the platform is running successfully:
![Image Alt Text:fvp terminals alt-text](/learning-paths/servers-and-cloud-computing/refinfra-quick-start/images/uefi.png)
*Figure 2. FVP Terminals*
You can also boot into `busy-box`, using the command:
./boot.sh -p rdn2
![Image Alt Text:docker terminal alt-text](/learning-paths/servers-and-cloud-computing/refinfra-quick-start/images/docker-run.png)
*Figure 3. Docker Terminal*
You have successfully booted the reference software stack you built in the previous step onto the FVP.
