Arm has developed a suite of
Neoverse Reference Designs
compute sub-systems.
They are supported by free-of-charge
Arm Ecosystem FVPs
, and complete
software stacks
to illustrate how these systems boot to Linux.
This learning path is based on the Neoverse N2 Reference Design (RD-N2).
You can use either an AArch64 or x86_64 host machine running Ubuntu Linux 22.04. 64GB of free disk space and 32GB of RAM is minimum requirement to sync and build the platform software stack. 48GB of RAM is recommended.
Follow the instructions to set up your environment using the information found at the Neoverse RD-N2 documentation site .
Install docker on your machine.
Start by obtaining the repo tool to simplify the checkout of source code that spans multiple repositories.
First, refresh the list of available packages and install repo:
sudo apt-get update
sudo apt-get install repo
Verify your installation:
repo version
The output looks like this:
/usr/bin/repo:681: DeprecationWarning: datetime.datetime.utcnow() is deprecated and scheduled for removal in a future version. Use timezone-aware objects to represent datetimes in UTC: datetime.datetime.now(datetime.UTC).
now = datetime.datetime.utcnow()
<repo not installed>
repo launcher version 2.36
(from /usr/bin/repo)
git 2.43.0
Python 3.12.3 (main, Jun 18 2025, 17:59:45) [GCC 13.3.0]
OS Linux 6.8.0-1031-aws (#33-Ubuntu SMP Fri Jun 20 17:58:11 UTC 2025)
CPU aarch64 (aarch64)
Bug reports: https://issues.gerritcodereview.com/issues/new?component=1370071
Create a new directory in to which you can download the source code, build the stack, and then obtain the manifest file.
To obtain the manifest, choose a tag of the platform reference firmware. RD-INFRA-2025.07.03 is used here, although it is recommended to use the latest version available. See the release notes for more information.
Specify the platform you would like with the manifest. In the
manifest repo
there are a number of available platforms. In this case, select pinned-rdn2.xml.
mkdir rd-infra
cd rd-infra/
repo init -u https://git.gitlab.arm.com/infra-solutions/reference-design/infra-refdesign-manifests.git -m pinned-rdn2.xml -b refs/tags/RD-INFRA-2025.07.03
Now look at what the configured manifest contains:
cat .repo/manifest.xml
The file content should look like:
<?xml version="1.0" encoding="UTF-8"?>
DO NOT EDIT THIS FILE! It is generated by repo and changes will be discarded.
If you want to use a different manifest, use `repo init -m <file>` instead.
If you want to customize your checkout by overriding manifest settings, use
the local_manifests/ directory instead.
For more information on repo manifests, check out:
https://gerrit.googlesource.com/git-repo/+/HEAD/docs/manifest-format.md
<manifest>
<include name="pinned-rdn2.xml" />
</manifest>
The manifest.xml file points to pinned-rdn2.xml so let us examine that one next:
cat .repo/manifests/pinned-rdn2.xml
The contents of pinned-rdn2.xml are shown below:
<manifest>
<remote fetch="https://git.gitlab.arm.com/infra-solutions/reference-design/" name="arm"/>
<remote fetch="https://github.com/" name="github"/>
<remote fetch="https://git.savannah.gnu.org" name="gnugit"/>
<remote fetch="https://git.kernel.org" name="kernel"/>
<remote fetch="https://git.trustedfirmware.org" name="tforg"/>
<project remote="arm" name="platsw/scp-firmware" path="scp" revision="refs/tags/RD-INFRA-2024.12.20"/>
<project remote="arm" name="platsw/trusted-firmware-a" path="tf-a" revision="refs/tags/RD-INFRA-2024.12.20"/>
<project remote="arm" name="platsw/edk2" path="uefi/edk2" revision="refs/tags/RD-INFRA-2024.12.20"/>
<project remote="arm" name="platsw/edk2-platforms" path="uefi/edk2/edk2-platforms" revision="refs/tags/RD-INFRA-2024.12.20"/>
<project remote="arm" name="platsw/linux" path="linux" revision="refs/tags/RD-INFRA-2024.12.20"/>
<project remote="arm" name="scripts/build-scripts" path="build-scripts" revision="refs/tags/RD-INFRA-2024.12.20"/>
<project remote="arm" name="scripts/model-scripts" path="model-scripts" revision="refs/tags/RD-INFRA-2024.12.20"/>
<project remote="arm" name="scripts/container-scripts" path="container-scripts" revision="refs/tags/RD-INFRA-2024.12.20"/>
<project remote="arm" name="valsw/kvm-unit-tests" path="validation/sys-test/kvm-unit-tests" revision="refs/tags/RD-INFRA-2024.12.20"/>
<project remote="arm" name="platsw/buildroot" path="buildroot" revision="refs/tags/RD-INFRA-2024.12.20"/>
<project remote="tforg" name="TF-A/tf-a-tests.git" path="validation/comp-test/trusted-firmware-tf" revision="6f9e14a0e3a9e14051cf6235a49b06bae32823d9"/>
<project remote="github" name="acpica/acpica" path="tools/acpica" revision="refs/tags/G20240322"/>
<project remote="github" name="ARMmbed/mbedtls.git" path="mbedtls" revision="refs/tags/mbedtls-3.6.2"/>
<project remote="github" name="mirror/busybox" path="busybox" revision="refs/tags/1_36_1"/>
<project remote="gnugit" name="git/grub.git" path="grub" revision="refs/tags/grub-2.04"/>
<project remote="kernel" name="pub/scm/linux/kernel/git/jejb/efitools" path="tools/efitools" revision="refs/tags/v1.9.2"/>
<project remote="kernel" name="pub/scm/linux/kernel/git/will/kvmtool" path="kvmtool" revision="da4cfc3e540341b84c4bbad705b5a15865bc1f80"/>
</manifest>
The manifest defines repositories of firmware sources, build and model scripts, linux, and tooling.
Fetch the sources with the repo sync command. This will take a few minutes to complete.
repo sync -c -j $(nproc) --fetch-submodules --force-sync --no-clone-bundle
The output from running this command looks like:
... A new version of repo (2.54) is available.
... New version is available at: /home/ubuntu/rdn2-infra/.repo/repo/repo
... The launcher is run from: /usr/bin/repo
!!! The launcher is not writable. Please talk to your sysadmin or distro
!!! to get an update installed.
Fetching: 100% (17/17), done in 8m16.653s
Fetching: 100% (17/17), done in 17.218s
Fetching: 100% (17/17), done in 14.719s
Fetching: 100% (7/7), done in 12.526s
Fetching: 100% (1/1), done in 0.385s
Updating files: 100% (84978/84978), done.ting files: 17% (14646/84978)
Checking out: 27% (16/59), done in 8.804s
Checking out: 28% (17/59), done in 0.779s
Updating files: 100% (18459/18459), done.ptoPkg/Library/OpensslLib/openssl/pyca-cryptographyUpdating files: 42% (10441/24326)
Updating files: 100% (24326/24326), done.ptoPkg/Library/OpensslLib/openssl/fuzz/corporaUpdating files: 54% (13137/24326)
Checking out: 30% (18/59), done in 1.675s
Checking out: 11% (7/59), done in 0.874s
Checking out: 1% (1/59), done in 0.004s
repo sync has finished successfully.
Now you should have all the code.
Set up a docker container in which to perform the build. A container execution script is provided. See the help for more information.
cd container-scripts/
./container.sh -h
The output from help should look like:
Usage: ./container.sh [OPTIONS] [COMMAND]
If no options are provided the script uses the default values
defined in the 'Defaults' section.
Available options are:
-v <path> absolute path to mount into the container;
-f <file> docker file name;
-i <name> docker image name;
-o overwrites a previously-built image;
-h displays this help message and exits;
Available commands are:
build builds the docker image;
run runs the container in interactive mode;
Build the default configuration:
./container.sh build
Verify that the container has been built:
docker image list
The output from this command looks like:
REPOSITORY TAG IMAGE ID CREATED SIZE
rdinfra-builder latest e11c8e27a4c6 7 days ago 8.12GB
ubuntu jammy-20230624 5a81c4b8502e 6 months ago 77.8MB
The appearance of the output is like a standard ubuntu container based on the latest release with the rdinfra-builder container built on top. Let’s run and enter the container:
docker run --rm \
-v /home/ubuntu/rd-infra/:/home/ubuntu/rd-infra/ \
-w /home/ubuntu/rd-infra/ \
-e ARCADE_USER=$(id -un) \
-e ARCADE_UID=$(id -u) \
-e ARCADE_GID=$(id -g) \
-it rdinfra-builder bash
This command puts you in the running container where you can run ls to list the contents:
ubuntu@923218f076f5:/$ ls
bin boot dev etc home lib lib32 lib64 libx32 media mnt opt proc root run sbin srv sys tmp usr var
You can exit the container like any login shell.
exit
You can use the container script to run and enter the container. Mount the source checkout into the container so you can do a build without having to copy the source in and build the targets out:
./container.sh -v /home/ubuntu/rd-infra/ run
If you do choose to build this on the host, you need to obtain all the pre-requisites that would otherwise be installed in the container during its creation.
The build system provides a script for this that you must run as root:
sudo ./build-scripts/rdinfra/install_prerequisites.sh
