# Set up your development environment
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-debug/)
- [Set up your development environment](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-debug/setup-1/)
- [Debugging SCP/LCP/RSE](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-debug/debugging-scp-lcp-rse-2/)
- [Debugging BL1](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-debug/debugging-bl1-3/)
- [Debugging BL31](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-debug/debugging-bl31-4/)
- [Debugging BL33 / UEFI](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-debug/debugging-bl33-uefi-5/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-debug/_next-steps/)
To debug the Neoverse N2 reference firmware, you need Arm Development Studio installed, and an appropriate license. See the [Arm Development Studio Install Guide](https://learn.arm.com/install-guides/armds/) for instructions. Screenshots are from Arm Development Studio 2023.0.
You also need the Neoverse RD-N2 Reference Design Software Stack set up, and an associated FVP (Fixed Virtual Platform). You should be familiar with [Get started with the Neoverse Reference Design Software Stack](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-quick-start/) before you start debugging.
## SCP/LCP/RSE debug
If you want to debug SCP/LCP/RSE, you need to modify the run script:
```bash
rdinfra/model-scripts/rdinfra/platforms/rdn2/run_model.sh
To prepare for debugging, remove the `–R` parameter from the `PARAMS=` section.
When `-R` is used, the FVP continues execution and does not wait for the debug connection.
![Image Alt Text:modify parameters alt-text](https://learn.arm.com/learning-paths/servers-and-cloud-computing/refinfra-debug/images/modify_params.webp)
*Figure 1. Modify run_model.sh*
**Debug server**
To start a `CADI` debug server, use the `-S` option. For an `Iris` debug server, change this to `-I` instead.
Run the script to launch the model:
```bash
./run_model.sh
## AP debug
To debug the AP, you do not want to remove the `-R` flag.
If you remove the `-R` flag, RSE CPU waits and the APs will be powered off. You will have to kick-off the run, then it starts booting from RSE to AP cores.
This will be explained further in BL1, BL31, and BL33 chapters.
**FVP Accuracy**
FVPs do not model the `IMP DEF` behavior with the same level of detail included in the RTL design.
FVPs do not model cycles, performance, or `AXI/ACE/AHB/CHI` level transactions.
