SCP firmware debug uses the -Og argument. This optimizes some variables that make debugging difficult. To replace -Og with -O0, do the following:
rd-infra/scp/cmake/Toolchain.<compiler>-Baremetal.cmake file for your toolchain.For example, change GNU-Baremetal.cmake:
string(APPEND CMAKE_${language}_FLAGS_DEBUG_INIT "-Og")
to
string(APPEND CMAKE_${language}_FLAGS_DEBUG_INIT "-O0")
After starting the model, click New Debug Connection… from the Debug Control panel.
Figure 1. New debug connection
Create a connection name. This can be whatever you prefer.
Figure 2. Debug connection name
Next, click on Add a new model….
Figure 3. Add new model
Select the appropriate Model Interface, for example CADI.
Click Browse for model running on local host.
Select the correct model, and click Finish.
Figure 4. Connect model
In the Edit configuration and launch panel, in the Connection tab, select the correct target.
For the SCP code, select ARM_Cortex-M7_1.
For different platforms (e.g., RD-N2, RD-V3, etc.), you will see a list of numbered M7 and M55 cores. Typically, even-numbered M7 cores correspond to the MCP, while odd-numbered cores are assigned to the SCP. Additionally:
ARM_Cortex-M55_0 to ARM_Cortex-M55_(N-1) represent LCP cores.ARM_Cortex-M55_N represents the RSE.To verify core assignments, you can set up alerts (e.g., print statements or store variables), connect to a debugger, and test the configuration.
Figure 5. Select target
In the Files panel, select Load Symbols from file, File System, and select the SCP RAMFW ELF file, located at:
rd-infra/scp/output/rdn2/0/scp_ramfw/bin/rdn2-bl2.elf.
RSE debug symbol file location:
rd-infra/tf-m/cmake_build/<plat>/<cfg>/bin/bl1_1.elf
rd-infra/tf-m/cmake_build/<plat>/<cfg>/bin/bl1_2.elf
rd-infra/tf-m/cmake_build/<plat>/<cfg>/bin/bl2.elf
LCP debug symbol file location:
rd-infra/scp/output/<plat>/<cfg>/lcp_ramfw/rdv3-lcp-bl2.elf
Figure 6. Load SCP symbols
Select Apply then Debug. The debugger now connects to the model.
Once connected, you can set breakpoints in the source code. This can be done by searching for the function in the Functions tab, double-clicking next to the line number, or in the Command view.
Set a breakpoint at cmn700_discovery(). Continue execution and the code stops at the breakpoint you specify.
break cmn700_discovery
continue
Figure 7. cmn700_discovery() breakpoint
Set another breakpoint at a debug print statement.
Figure 8. SCP breakpoint 2
Observe the output in the SCP UART window.
Disconnect from the FVP.
