Deploy Redis as a cache for MySQL on an AWS Arm based Instance
Deploy Redis as a cache for MySQL on an Azure Arm based Instance
Deploy Redis as a cache for MySQL on a GCP Arm based Instance
Deploy Redis as a cache for Postgres on an AWS Arm based Instance
Deploy Redis as a cache for Postgres on an Azure Arm based Instance
Deploy Redis as a cache for Postgres on a Google Cloud Arm based Instance
You can deploy Redis as a cache for MySQL on an AWS Arm based Instance using Terraform and Ansible.
In this section, you will deploy Redis as a cache for MySQL on an AWS Instance.
If you are new to Terraform, you should look at Automate AWS EC2 instance creation using Terraform before starting this Learning Path.
You should have the prerequisite tools installed before starting the Learning Path.
Any computer which has the required tools installed can be used for this section. The computer can be your desktop or laptop computer or a virtual machine with the required tools.
You will need an AWS account to complete this Learning Path. Create an account if you don’t have one.
Before you begin, you will also need:
The instructions to create the keys are below.
Generate an SSH key-pair (public key, private key) using ssh-keygen to use for AWS EC2 access. To generate the key-pair, follow this
guide
If you already have an SSH key-pair present in the ~/.ssh directory, you can skip this step.
The installation of Terraform on your desktop or laptop needs to communicate with AWS. Thus, Terraform needs to be able to authenticate with AWS. For authentication, generate access keys (access key ID and secret access key). These access keys are used by Terraform for making programmatic calls to AWS via the AWS CLI.
To generate and configure the Access key ID and Secret access key, follow this guide .
Using a text editor, save the code below in a file called main.tf:
provider "aws" {
region = "us-east-2"
resource "aws_instance" "MYSQL_TEST" {
count = "2"
ami = "ami-0000456e99b2b6a9d"
instance_type = "t4g.small"
security_groups = [aws_security_group.Terraformsecurity1.name]
key_name = aws_key_pair.deployer.key_name
tags = {
Name = "MYSQL_TEST"
resource "aws_default_vpc" "main" {
tags = {
Name = "main"
resource "aws_security_group" "Terraformsecurity1" {
name = "Terraformsecurity1"
description = "Allow TLS inbound traffic"
vpc_id = aws_default_vpc.main.id
ingress {
description = "TLS from VPC"
from_port = 3306
to_port = 3306
protocol = "tcp"
cidr_blocks = ["0.0.0.0/0"]
ingress {
from_port = 22
to_port = 22
protocol = "tcp"
egress {
from_port = 0
to_port = 0
protocol = "-1"
tags = {
Name = "Terraformsecurity1"
resource "local_file" "inventory" {
depends_on = [aws_instance.MYSQL_TEST]
filename = "/tmp/inventory"
content = <<EOF
[mysql1]
${aws_instance.MYSQL_TEST[0].public_ip}
[mysql2]
${aws_instance.MYSQL_TEST[1].public_ip}
[all:vars]
ansible_connection=ssh
ansible_user=ubuntu
EOF
resource "aws_key_pair" "deployer" {
key_name = "id_rsa"
public_key = file("~/.ssh/id_rsa.pub")
Make the changes listed below in main.tf to match your account settings.
In the provider section, update value to use your preferred AWS region.
(optional) In the aws_instance section, change the ami value to your preferred Linux distribution. The AMI ID for Ubuntu 22.04 on Arm is ami-0000456e99b2b6a9d. No change is needed if you want to use Ubuntu AMI.
The instance type is t4g.small. This is an Arm-based instance and requires an Arm Linux distribution.
The inventory file is automatically generated and does not need to be changed.
Use Terraform to deploy the main.tf file.
Run terraform init to initialize the Terraform deployment. This command downloads the dependencies required for AWS.
terraform init
The output should be similar to:
Initializing the backend...
Initializing provider plugins...
- Reusing previous version of hashicorp/aws from the dependency lock file
- Reusing previous version of hashicorp/local from the dependency lock file
- Using previously-installed hashicorp/aws v4.52.0
- Using previously-installed hashicorp/local v2.3.0
Terraform has been successfully initialized!
You may now begin working with Terraform. Try running "terraform plan" to see
any changes that are required for your infrastructure. All Terraform commands
should now work.
If you ever set or change modules or backend configuration for Terraform,
rerun this command to reinitialize your working directory. If you forget, other
commands will detect it and remind you to do so if necessary.
Run terraform plan to create an execution plan.
terraform plan
A long output of resources to be created will be printed to the console.
Run terraform apply to apply the execution plan and create all AWS resources.
terraform apply
Answer yes to the prompt to confirm you want to create AWS resources.
Apply complete! Resources: 6 added, 0 changed, 0 destroyed.
Install MySQL and the required dependencies.
Using a text editor, save the code below in a file called playbook.yaml. This Playbook installs & enables MySQL in the instances and creates databases inside them.
- hosts: mysql1, mysql2
remote_user: root
become: true
tasks:
- name: Update the Machine and Install dependencies
shell: |
apt-get update -y
apt-get -y install mysql-server
apt -y install python3-pip
pip3 install PyMySQL
- name: start and enable mysql service
service:
state: started
enabled: yes
- name: Change Root Password
shell: sudo mysql -u root -e "ALTER USER 'root'@'localhost' IDENTIFIED WITH mysql_native_password BY '{{Your_mysql_password}}'"
- name: Create database user with password and all database privileges and 'WITH GRANT OPTION'
mysql_user:
login_user: root
login_password: {{Your_mysql_password}}
login_host: localhost
host: '%'
password: {{Give_any_password}}
priv: '*.*:ALL,GRANT'
state: present
- name: Create a new database with name 'arm_test1'
when: "'mysql1' in group_names"
community.mysql.mysql_db:
login_user: root
state: present
login_unix_socket: /run/mysqld/mysqld.sock
- name: Create a new database with name 'arm_test2'
when: "'mysql2' in group_names"
login_user: root
state: present
- name: MySQL secure installation
become: yes
expect:
command: mysql_secure_installation
responses:
'Enter current password for root': '{{Your_mysql_password}}'
'Set root password': 'n'
'Remove anonymous users': 'y'
'Disallow root login remotely': 'n'
'Remove test database': 'y'
'Reload privilege tables now': 'y'
timeout: 1
register: secure_mysql
failed_when: "'... Failed!' in secure_mysql.stdout_lines"
- name: Enable remote login by changing bind-address
lineinfile:
path: /etc/mysql/mysql.conf.d/mysqld.cnf
regexp: '^bind-address'
line: 'bind-address = 0.0.0.0'
backup: yes
notify:
- Restart mysql
handlers:
- name: Restart mysql
service:
state: restarted
Replace {{Your_mysql_password}} and {{Give_any_password}} in this file with your own password.
Run the playbook using the ansible-playbook command:
ansible-playbook playbook.yaml -i /tmp/inventory
Answer yes when prompted for the SSH connection.
Deployment may take a few minutes.
PLAY [mysql1, mysql2] ******************************************************************************************************************************************
TASK [Gathering Facts] *****************************************************************************************************************************************
The authenticity of host '18.188.123.253 (18.188.123.253)' can't be established.
ED25519 key fingerprint is SHA256:xtVtL9RoEV61xPEnSpiCVf2Up78+L4+uOmGN6kYKqGA.
This key is not known by any other names
The authenticity of host '3.142.152.108 (3.142.152.108)' can't be established.
ED25519 key fingerprint is SHA256:LtdJlI6dJULcrKxaOQaDlbBiFQnNPKN6+3quotP7am4.
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
ok: [18.188.123.253]
yes
ok: [3.142.152.108]
TASK [Update the Machine and Install dependencies] *************************************************************************************************************
changed: [18.188.123.253]
changed: [3.142.152.108]
TASK [start and enable mysql service] **************************************************************************************************************************
ok: [3.142.152.108]
TASK [Change Root Password] ************************************************************************************************************************************
TASK [Create database user with password and all database privileges and 'WITH GRANT OPTION'] ******************************************************************
TASK [Create a new database with name 'arm_test1'] *************************************************************************************************************
skipping: [3.142.152.108]
TASK [Create a new database with name 'arm_test2'] *************************************************************************************************************
skipping: [18.188.123.253]
TASK [MySQL secure installation] *******************************************************************************************************************************
TASK [Enable remote login by changing bind-address] ************************************************************************************************************
RUNNING HANDLER [Restart mysql] ********************************************************************************************************************************
PLAY RECAP *****************************************************************************************************************************************************
18.188.123.253 : ok=9 changed=7 unreachable=0 failed=0 skipped=1 rescued=0 ignored=0
3.142.152.108 : ok=9 changed=7 unreachable=0 failed=0 skipped=1 rescued=0 ignored=0
To connect to the database, you need the public-ip of the instance where MySQL is deployed. You also need to use the MySQL Client to interact with the MySQL database. Run the commands as shown:
apt install mysql-client
mysql -h {public_ip of instance where Mysql deployed} -P3306 -u {user of database} -p{password of database}
Replace {public_ip of instance where Mysql deployed}, {user of database} and {password of database} with your values. In this example, user= Local_user, which is getting created in the playbook.yaml file.
The output will be:
ubuntu@ip-172-31-38-39:~/mysql$ mysql -h 18.188.123.253 -P3306 -u Local_user -p
Enter password:
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 8
Server version: 8.0.32-0ubuntu0.22.04.2 (Ubuntu)
Copyright (c) 2000, 2023, Oracle and/or its affiliates.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql>
show databases;
use {your_database};
The output will be:
mysql> show databases;
| Database |
| arm_test1 |
| information_schema |
| mysql |
| performance_schema |
| sys |
5 rows in set (0.00 sec)
mysql> use arm_test1;
Database changed
create table book(name char(10),id varchar(10));
insert into book(name,id) values ('Abook','10'),('Bbook','20'),('Cbook','20'),('Dbook','30'),('Ebook','45'),('Fbook','40'),('Gbook
','69');
The output will be:
mysql> create table book(name char(10),id varchar(10));
Query OK, 0 rows affected (0.03 sec)
mysql> insert into book(name,id) values ('Abook','10'),('Bbook','20'),('Cbook','20'),('Dbook','30'),('Ebook','45'),('Fbook','40'),('Gbook
'> ','69');
Query OK, 7 rows affected (0.01 sec)
Records: 7 Duplicates: 0 Warnings: 0
select * from {{your_table_name}};
The output will be:
mysql> select * from book;
| name | id |
| Abook | 10 |
| Bbook | 20 |
| Cbook | 20 |
| Dbook | 30 |
| Ebook | 45 |
| Fbook | 40 |
| Gbook
| 69 |
7 rows in set (0.00 sec)
The output will be:
| Database |
| arm_test2 |
| mysql |
| sys |
mysql> use arm_test2;
Database changed
mysql> create table movie(name char(10),id varchar(10));
Query OK, 0 rows affected (0.02 sec)
mysql> insert into movie(name,id) values ('Amovie','1'), ('Bmovie','2'), ('Cmovie','3'), ('Dmovie','4'), ('Emovie','5'), ('Fmovie','6'), ('Gmovie','7');
mysql> select * from movie;
| name | id |
| Amovie | 1 |
| Bmovie | 2 |
| Cmovie | 3 |
| Dmovie | 4 |
| Emovie | 5 |
| Fmovie | 6 |
| Gmovie | 7 |
You will create two .py files on the host machine to deploy Redis as a MySQL cache using Python: values.py and redis_cache.py.
Using a text editor of your choice, create the file values.py with the content below:
MYSQL_TEST=[["{{public_ip of MYSQL_TEST[0]}}", "arm_test1"],
["{{public_ip of MYSQL_TEST[1]}}", "arm_test2"]]
Replace {{public_ip of MYSQL_TEST[0]}} & {{public_ip of MYSQL_TEST[1]}} with the public IPs generated in the /tmp/inventory file after running the Terraform commands.
values.py is used to store the IP addresses of the instances and the databases created in them.
Now create the file redis_cache.py with the content below:
import sys
import MySQLdb
import redis
from values import *
import argparse
parser = argparse.ArgumentParser()
parser.add_argument("-db", "--database", help="Database")
parser.add_argument("-k", "--key", help="Key")
parser.add_argument("-q", "--query", help="Query")
args = parser.parse_args()
R_SERVER = redis.Redis(
host='localhost',
port='6379')
for i in range(0,2):
if (MYSQL_TEST[i][1]==args.database):
try:
conn = MySQLdb.connect (host = MYSQL_TEST[i][0],
user = "{{Your_database_user}}",
passwd = "{{Your_database_password}}",
db = MYSQL_TEST[i][1])
except MySQLdb.Error as e:
print ("Error %d: %s" % (e.args[0], e.args[1]))
sys.exit (1)
sqldata = R_SERVER.get(args.key)
if not sqldata:
cursor = conn.cursor()
cursor.execute(args.query)
rows = cursor.fetchall()
mystr = ' '.join(map(str,rows))
R_SERVER.set(args.key,mystr,120)
print ("Updated redis with MySQL data")
print (rows)
else:
print ("Loaded data from redis")
print (sqldata)
break
else:
print("this database doesn't exist")
Replace {{Your_database_user}} & {{Your_database_password}} with the database user and password created through Ansible-Playbook. Also change the range in for loop according to the number of instances created.
redis_cache.py is used to access data from Redis Cache and, if not present, store it in the Redis Cache.
Install the required Python modules using pip and other required dependencies:
apt-get install redis libmysqlclient-dev
pip install redis mysqlclient
To execute the redis_cache.py script, run the following command:
python3 redis_cache.py -db {database_name} -k {key} -q {query}
Replace {database_name} with the database you want to access, {query} with the query you want to run in the database, and {key} with a variable to store the result of the query in Redis cache.
When the script is executed for the first time, the data is loaded from the MySQL database and stored in the Redis cache.
The output will be similar to:
ubuntu@ip-172-31-38-39:~/mysql$ python3 redis_cache.py -db arm_test1 -k AA -q "select * from book limit 3"
(('Abook', '10'), ('Bbook', '20'), ('Cbook', '20'))
ubuntu@ip-172-31-38-39:~/mysql$ python3 redis_cache.py -db arm_test2 -k BB -q "select * from movie limit 3"
(('Amovie', '1'), ('Bmovie', '2'), ('Cmovie', '3'))
When executed after that, it loads the data from Redis cache. In the example above, the information stored in Redis cache is in the form of string. When accessing the information (within the 120-second expiry time), the data is loaded from Redis cache and dumped.
The output will be:
b"('Abook', '10') ('Bbook', '20') ('Cbook', '20')"
b"('Amovie', '1') ('Bmovie', '2') ('Cmovie', '3')"
Execute the steps below to verify that the MySQL query is getting stored in Redis cache.
apt install redis-tools
redis-cli -p 6379
get <key>
Key is the variable in which you store the data. In the above command, you are storing the data from the tables book and movie in AA and BB respectively.
The output will be:
ubuntu@ip-172-31-38-39:~/mysql$ redis-cli -p 6379
127.0.0.1:6379> get AA
127.0.0.1:6379> get BB
127.0.0.1:6379>
You have successfully deployed Redis as a cache for MySQL on an AWS Arm based Instance.
Run terraform destroy to delete all resources created.
terraform destroy
Continue the Learning Path to deploy Redis as a cache for MySQL on an Azure Arm based Instance.
