Benchmark Redis using redis-benchmark
The redis-benchmark tool is an official performance testing utility for Redis. It measures throughput (requests per second) and latency (response delay) across different workloads.
Prerequisites
Before running benchmarks, verify that Redis is running and accessible:
redis-cli ping
If you don’t see a PONG response, start Redis:
redis-server &
redis-cli ping
Benchmark SET (write performance)
Benchmark data insertion performance:
redis-benchmark -t set -n 100000 -c 50
This command:
  • Runs the benchmark for SET operations only (-t set)
  • Performs 100,000 total requests (-n 100000)
  • Simulates 50 concurrent clients (-c 50)
The output is similar to:
        ====== SET ======
  100000 requests completed in 0.67 seconds
  50 parallel clients
  3 bytes payload
  keep alive: 1
  host configuration "save": 3600 1 300 100 60 10000
  host configuration "appendonly": no
  multi-thread: no
Latency by percentile distribution:
0.000% <= 0.063 milliseconds (cumulative count 1)
50.000% <= 0.167 milliseconds (cumulative count 54147)
75.000% <= 0.175 milliseconds (cumulative count 94619)
96.875% <= 0.183 milliseconds (cumulative count 98788)
99.219% <= 0.231 milliseconds (cumulative count 99222)
99.609% <= 0.415 milliseconds (cumulative count 99617)
99.805% <= 0.543 milliseconds (cumulative count 99817)
99.902% <= 0.671 milliseconds (cumulative count 99909)
99.951% <= 0.775 milliseconds (cumulative count 99965)
99.976% <= 0.983 milliseconds (cumulative count 99978)
99.988% <= 1.087 milliseconds (cumulative count 99993)
99.994% <= 1.095 milliseconds (cumulative count 100000)
100.000% <= 1.095 milliseconds (cumulative count 100000)
Cumulative distribution of latencies:
0.035% <= 0.103 milliseconds (cumulative count 35)
99.166% <= 0.207 milliseconds (cumulative count 99166)
99.465% <= 0.303 milliseconds (cumulative count 99465)
99.577% <= 0.407 milliseconds (cumulative count 99577)
99.743% <= 0.503 milliseconds (cumulative count 99743)
99.869% <= 0.607 milliseconds (cumulative count 99869)
99.932% <= 0.703 milliseconds (cumulative count 99932)
99.968% <= 0.807 milliseconds (cumulative count 99968)
99.975% <= 0.903 milliseconds (cumulative count 99975)
99.983% <= 1.007 milliseconds (cumulative count 99983)
100.000% <= 1.103 milliseconds (cumulative count 100000)
Summary:
  throughput summary: 149700.61 requests per second
  latency summary (msec):
          avg       min       p50       p95       p99       max
        0.170     0.056     0.167     0.183     0.191     1.095
Benchmark GET (read performance)
Test data retrieval performance:
redis-benchmark -t get -n 100000 -c 50
Parameters:
- `-t get`: Runs the benchmark only for GET operations.
- `-n 100000`: Executes 100,000 total requests.
- `-c 50`: Simulates 50 concurrent clients performing reads.
```output
====== GET ======
  50 parallel clients
  3 bytes payload
  keep alive: 1
  multi-thread: no
0.000% <= 0.055 milliseconds (cumulative count 2)
50.000% <= 0.167 milliseconds (cumulative count 55781)
75.000% <= 0.175 milliseconds (cumulative count 94250)
96.875% <= 0.183 milliseconds (cumulative count 98794)
99.219% <= 0.239 milliseconds (cumulative count 99222)
99.609% <= 0.431 milliseconds (cumulative count 99618)
99.805% <= 0.575 milliseconds (cumulative count 99822)
99.902% <= 0.663 milliseconds (cumulative count 99906)
99.951% <= 0.759 milliseconds (cumulative count 99953)
99.976% <= 0.783 milliseconds (cumulative count 99976)
99.988% <= 0.799 milliseconds (cumulative count 99995)
99.997% <= 0.807 milliseconds (cumulative count 100000)
100.000% <= 0.807 milliseconds (cumulative count 100000)
0.034% <= 0.103 milliseconds (cumulative count 34)
99.141% <= 0.207 milliseconds (cumulative count 99141)
99.478% <= 0.303 milliseconds (cumulative count 99478)
99.558% <= 0.407 milliseconds (cumulative count 99558)
99.718% <= 0.503 milliseconds (cumulative count 99718)
99.866% <= 0.607 milliseconds (cumulative count 99866)
99.951% <= 0.703 milliseconds (cumulative count 99951)
Summary:
  throughput summary: 150375.94 requests per second
        0.169     0.048     0.167     0.183     0.191     0.807
Interpret the benchmark metrics
The following table summarizes the benchmark results from the earlier run on the c4a-standard-4 (4 vCPU, 16 GB memory) Arm64 VM in GCP (SUSE Enterprise Server):
OperationTotal RequestsConcurrent ClientsAvg Latency (ms)Min (ms)P50 (ms)P95 (ms)P99 (ms)Max (ms)Throughput (req/sec)Description
SET100,000500.1700.0560.1670.1830.1911.095149,700.61Measures Redis write performance using SET command
GET100,000500.1690.0480.1670.1830.1910.807150,375.94Measures Redis read performance using GET command
Redis demonstrated excellent performance on the Arm64-based C4A VM, achieving over 150K operations per second for both read and write workloads with an average latency of approximately 0.17 ms. Both SET and GET operations showed nearly identical performance characteristics, indicating efficient CPU and memory optimization on the Arm architecture. The Arm-based C4A VM delivers competitive performance-per-watt efficiency, making it ideal for scalable, sustainable Redis deployments.
In this section, you:
  • Benchmarked Redis SET operations, achieving over 149K requests per second with 0.170 ms average latency
  • Benchmarked Redis GET operations, achieving over 150K requests per second with 0.169 ms average latency
  • Verified that Redis performs efficiently on Google Axion C4A Arm instances
You’ve successfully benchmarked Redis on Google Cloud’s C4A Arm-based virtual machines, demonstrating strong performance for in-memory data operations.
For next steps, consider exploring Redis Cluster for distributed deployments, implementing persistence strategies for production workloads, or testing more advanced data structures like sorted sets and streams. You can also compare performance across different C4A machine types to optimize cost and performance for your specific use case.
