Validate Redis for production workloads
In this section you implement production-grade event processing using Redis Streams consumer groups, simulate real workloads using Python, and benchmark Redis performance on an Azure Cobalt 100 Arm-based virtual machine.
You will validate Redis for high-throughput, low-latency workloads on Arm infrastructure.
Create a consumer group
Consumer groups enable scalable and reliable message processing by distributing work across multiple consumers.
Terminal 1 is still running the Redis server. Use Terminal 2 or Terminal 3 from the previous section, which already has the Redis CLI open. If you closed those sessions, open a new terminal and start the CLI:
cd /tmp/redis-stable
src/redis-cli
At the 127.0.0.1:6379> prompt, create a consumer group on the existing stream:
XGROUP CREATE mystream mygroup 0 MKSTREAM
The output is similar to:
        OK
Consume messages using a consumer group
At the 127.0.0.1:6379> prompt, read messages from the stream as part of the consumer group:
XREADGROUP GROUP mygroup consumer1 COUNT 1 STREAMS mystream >
        1) 1) "mystream"
   2) 1) 1) "1774931844279-0"
         2) 1) "user"
            2) "jack"
            3) "action"
            4) "login"
Acknowledge processed messages
Acknowledge messages after processing to prevent re-delivery. Use the message ID returned in the XREADGROUP output above — for example 1774931844279-0:
XACK mystream mygroup 1774931844279-0
        (integer) 1
A return value of 1 confirms the message was acknowledged successfully.
Exit the Redis CLI before continuing:
QUIT
Install Python Redis client
Install the Python venv module and create a virtual environment, then install the Redis client library:
sudo apt install -y python3-venv
python3 -m venv ~/redis-venv
source ~/redis-venv/bin/activate
pip install redis
The virtual environment remains active for the rest of this section. Your prompt will show (redis-venv) to confirm it is active.
Create a Python producer
Create a producer script to send events to the Redis stream. Save the following code in a file named producer.py:
import redis
r = redis.Redis(host='localhost', port=6379)
for i in range(10):
    r.xadd("mystream", {"event": f"msg-{i}"})
    print(f"Produced msg-{i}")
Run the producer:
python producer.py
        Produced msg-0
Produced msg-1
Produced msg-9
Create a Python consumer
Create a consumer script to read and process messages. Save the following code in a file named consumer.py:
import redis
r = redis.Redis(host='localhost', port=6379, decode_responses=True)
while True:
    messages = r.xreadgroup("mygroup", "consumer1", {"mystream": ">"}, count=1, block=5000)
    for stream, msgs in messages:
        for msg_id, data in msgs:
            print(f"Consumed {msg_id}: {data}")
            r.xack("mystream", "mygroup", msg_id)
Run the consumer
python consumer.py
        Consumed 1774931858864-0: {'user': 'yan', 'action': 'purchase'}
Consumed 1774935598721-0: {'event': 'msg-0'}
Consumed 1774935598721-1: {'event': 'msg-1'}
Consumed 1774935598721-2: {'event': 'msg-2'}
Consumed 1774935598721-3: {'event': 'msg-3'}
Consumed 1774935598722-0: {'event': 'msg-4'}
Consumed 1774935598722-1: {'event': 'msg-5'}
Consumed 1774935598722-2: {'event': 'msg-6'}
Consumed 1774935598722-3: {'event': 'msg-7'}
Consumed 1774935598722-4: {'event': 'msg-8'}
Consumed 1774935598722-5: {'event': 'msg-9'}
The consumer blocks for 5 seconds when no new messages arrive and then checks again. Press Ctrl+C to stop it when you’re done.
Benchmark Redis performance
Run the Redis benchmark tool to measure throughput and latency:
src/redis-benchmark -q -n 100000 -c 50
        PING_INLINE: 132978.73 requests per second, p50=0.191 msec
PING_MBULK: 131752.31 requests per second, p50=0.191 msec
SET: 132802.12 requests per second, p50=0.191 msec
GET: 133689.83 requests per second, p50=0.191 msec
INCR: 131926.12 requests per second, p50=0.191 msec
LPUSH: 131406.05 requests per second, p50=0.191 msec
RPUSH: 130548.30 requests per second, p50=0.199 msec
LPOP: 131061.59 requests per second, p50=0.191 msec
RPOP: 135685.22 requests per second, p50=0.191 msec
SADD: 135869.56 requests per second, p50=0.191 msec
HSET: 136612.02 requests per second, p50=0.191 msec
SPOP: 134952.77 requests per second, p50=0.191 msec
ZADD: 136798.91 requests per second, p50=0.191 msec
ZPOPMIN: 134952.77 requests per second, p50=0.191 msec
LPUSH (needed to benchmark LRANGE): 136425.66 requests per second, p50=0.191 msec
LRANGE_100 (first 100 elements): 75357.95 requests per second, p50=0.335 msec
LRANGE_300 (first 300 elements): 31645.57 requests per second, p50=0.791 msec
LRANGE_500 (first 500 elements): 22036.14 requests per second, p50=1.127 msec
LRANGE_600 (first 600 elements): 19109.50 requests per second, p50=1.295 msec
MSET (10 keys): 137931.03 requests per second, p50=0.215 msec
XADD: 136425.66 requests per second, p50=0.191 msec
These results demonstrate high throughput and efficient performance on the Arm architecture.
Arm64 performance analysis
The benchmark results highlight the strong performance characteristics of Redis on Azure Cobalt 100 Arm64 infrastructure:
  • High throughput: Redis consistently achieves 130K–136K operations per second across multiple commands.
  • Low latency: Median latency remains around ~0.19 ms, ensuring near real-time responsiveness.
  • Efficient stream ingestion: XADD operations reach ~136K ops/sec, making Redis Streams suitable for high-ingestion event pipelines.
  • Stable performance across workloads: Consistent performance across SET, GET, HASH, and STREAM operations demonstrates efficient CPU and memory utilization on Arm.
These results validate that Arm-based infrastructure can handle high-performance, low-latency data workloads effectively.
Benchmark Pub/Sub performance
Run a publish benchmark to evaluate messaging throughput:
src/redis-benchmark -t publish -n 100000
Note
The Redis benchmark tool does not display detailed output for Pub/Sub operations. To validate Pub/Sub behavior, use a subscriber or monitor Redis metrics using the INFO command.
Monitor Redis metrics
Open a new terminal and use the Redis INFO command to inspect runtime statistics:
src/redis-cli info stats
        # Stats
total_connections_received:1058
total_commands_processed:2300074
instantaneous_ops_per_sec:0
total_net_input_bytes:129526426
total_net_output_bytes:1373991650
total_net_repl_input_bytes:0
total_net_repl_output_bytes:0
instantaneous_input_kbps:0.00
instantaneous_output_kbps:0.00
instantaneous_input_repl_kbps:0.00
instantaneous_output_repl_kbps:0.00
rejected_connections:0
sync_full:0
sync_partial_ok:0
sync_partial_err:0
expired_subkeys:0
expired_subkeys_active:0
expired_keys:0
expired_keys_active:0
expired_stale_perc:0.00
expired_time_cap_reached_count:0
expire_cycle_cpu_milliseconds:65
evicted_keys:0
evicted_clients:0
evicted_scripts:0
total_eviction_exceeded_time:0
current_eviction_exceeded_time:0
keyspace_hits:800087
keyspace_misses:0
pubsub_channels:0
pubsub_patterns:0
pubsubshard_channels:0
latest_fork_usec:430
total_forks:3
migrate_cached_sockets:0
slave_expires_tracked_keys:0
active_defrag_hits:0
active_defrag_misses:0
active_defrag_key_hits:0
active_defrag_key_misses:0
total_active_defrag_time:0
current_active_defrag_time:0
tracking_total_keys:0
tracking_total_items:0
tracking_total_prefixes:0
unexpected_error_replies:0
total_error_replies:0
dump_payload_sanitizations:0
total_reads_processed:2301131
total_writes_processed:2300077
io_threaded_reads_processed:0
io_threaded_writes_processed:0
io_threaded_total_prefetch_batches:0
io_threaded_total_prefetch_entries:0
client_query_buffer_limit_disconnections:0
client_output_buffer_limit_disconnections:0
reply_buffer_shrinks:167
reply_buffer_expands:0
eventloop_cycles:1973082
eventloop_duration_sum:24187445
eventloop_duration_cmd_sum:4769476
instantaneous_eventloop_cycles_per_sec:9
instantaneous_eventloop_duration_usec:142
acl_access_denied_auth:0
acl_access_denied_cmd:0
acl_access_denied_key:0
acl_access_denied_channel:0
Key observations
  • Redis achieves ~130K+ ops/sec on Arm64
  • Latency remains under 1 millisecond
  • No rejected connections during load
  • Streams provide reliable and scalable messaging
  • System remains stable under high throughput
What you’ve learned
You have successfully:
  • Implemented consumer groups for scalable processing
  • Built Python-based producer and consumer applications
  • Benchmarked Redis performance on Cobalt 100
  • Validated Redis for high-throughput workloads
