In this section you install Redis on an Azure Cobalt 100 Arm-based virtual machine and build a real-time messaging and event processing system using Redis Pub/Sub and Streams.
You will implement low-latency messaging and event-driven pipelines optimized for Arm-based infrastructure.
Update your operating system packages to the latest versions:
sudo apt update && sudo apt upgrade -y
Install build tools and utilities required to compile and run Redis:
sudo apt install -y build-essential tcl git curl python3-pip
Download the latest Redis source code and compile it:
cd /tmp
curl -O http://download.redis.io/redis-stable.tar.gz
tar xzf redis-stable.tar.gz
cd redis-stable
make -j$(nproc)
Start the Redis server in a new terminal.
Terminal 1:
cd /tmp/redis-stable
src/redis-server
The output shows Redis starting successfully and listening on port 6379:
103702:M 07 Apr 2026 18:49:07.446 * monotonic clock: ARM CNTVCT @ 1000 ticks/us
_._
_.-``__ ''-._
_.-`` `. `_. ''-._ Redis Open Source
.-`` .-```. ```\/ _.,_ ''-._ 8.6.2 (00000000/1) 64 bit
( ' , .-` | `, ) Running in standalone mode
|`-._`-...-` __...-.``-._|'` _.-'| Port: 6379
| `-._ `._ / _.-' | PID: 103702
`-._ `-._ `-./ _.-' _.-'
|`-._`-._ `-.__.-' _.-'_.-'|
| `-._`-._ _.-'_.-' | https://redis.io
`-._ `-._`-.__.-'_.-' _.-'
`-._ `-.__.-' _.-'
`-._ _.-'
`-.__.-'
103702:M 07 Apr 2026 18:49:07.446 * Server initialized
103702:M 07 Apr 2026 18:49:07.446 * Ready to accept connections tcp
Open another terminal and connect using the Redis CLI.
Terminal 2:
src/redis-cli
At the Redis CLI prompt, run:
PING
The output is similar to:
PONG
The output confirms that Redis is running and accepting connections.
Redis Pub/Sub enables real-time communication between producers and consumers.
Terminal 2 (Subscriber):
Terminal 2 is still connected to the Redis CLI from the previous step. At the 127.0.0.1:6379> prompt, run:
SUBSCRIBE chat_channel
127.0.0.1:6379(subscribed mode)> SUBSCRIBE chat_channel
1) "subscribe"
2) "chat_channel"
3) (integer) 1
Terminal 2 is now blocked waiting for messages on chat_channel.
Terminal 3 (Publisher):
Open a third terminal and start the Redis CLI:
src/redis-cli
PUBLISH chat_channel "Hello from Cobalt Arm!"
After publishing the message, switch back to the subscriber terminal.
1) "subscribe"
2) "chat_channel"
3) (integer) 1
1) "message"
2) "chat_channel"
3) "Hello from Cobalt Arm!"
The output demonstrates real-time message delivery.
Redis Streams provide persistent messaging with replay capability.
Terminal 3 (Producer):
At the 127.0.0.1:6379> prompt in Terminal 3, run:
XADD mystream * user jack action login
XADD mystream * user yan action purchase
127.0.0.1:6379> XADD mystream * user jack action login
"1774931844279-0"
127.0.0.1:6379> XADD mystream * user yan action purchase
"1774931858864-0"
Terminal 2 (Consumer):
Terminal 2 is still in subscribed mode. Run RESET to return to normal mode:
RESET
Then read from the stream:
XREAD COUNT 2 STREAMS mystream 0
1) 1) "mystream"
2) 1) 1) "1774931844279-0"
2) 1) "user"
2) "jack"
3) "action"
4) "login"
2) 1) "1774931858864-0"
2) 1) "user"
2) "yan"
3) "action"
4) "purchase"
The output confirms that events are stored and can be read reliably.
You have successfully:
You are now ready to extend this setup with consumer groups, application integration, and performance benchmarking.
