Hyperparameter tuning, serving, and benchmarking
This section demonstrates hyperparameter tuning, model serving, and performance benchmarking using Ray.
Hyperparameter tuning with Ray Tune
Create the tuning script:
vi ray_tune.py
from ray import tune
from ray.air import session
import random
def trainable(config):
    score = 0
    for _ in range(10):
        score += random.random() * config["lr"]
    session.report({"score": score})
tuner = tune.Tuner(
    trainable,
    param_space={
        "lr": tune.grid_search([0.001, 0.01, 0.1])
results = tuner.fit()
print("Best result:", results.get_best_result(metric="score", mode="max"))
Code explanation
  • tune.grid_search() → tries multiple hyperparameter values
  • Each value runs as a separate parallel trial
  • session.report() → sends metrics back to Ray
  • Tuner.fit() → executes all trials
Run hyperparameter tuning
python3 ray_tune.py
The output is similar to:
        Configuration for experiment trainable...
Number of trials: 3
Trial status: 3 TERMINATED
Current time: 2026-04-13 13:21:47. Total running time: 1s
Logical resource usage: 1.0/4 CPUs, 0/0 GPUs
│ Trial name              status          lr     iter     total time (s)       score │
│ trainable_b83d8_00000   TERMINATED   0.001        1        0.000396013   0.0053353 │
│ trainable_b83d8_00001   TERMINATED   0.01         1        0.000548363   0.0366355 │
│ trainable_b83d8_00002   TERMINATED   0.1          1        0.000375986   0.363394  │
Best result: Result(
  metrics={'score': 0.36339389194042176},
  path='/home/pareena_verma_arm_com/ray_results/trainable_2026-04-13_13-21-45/trainable_b83d8_00002_2_lr=0.1000_2026-04-13_13-21-46',
  filesystem='local',
  checkpoint=None
Understanding the output
  • Ray created 3 parallel trials using different learning rates
  • Each trial executed independently on available CPU cores
  • Scores represent the performance of each configuration
Learning RateScore
0.0010.005
0.010.036
0.10.363
Best configuration = learning rate 0.1
  • Total runtime ≈ 1 second (parallel execution)
  • Results stored in:
$HOME/ray_results/
Deploy model using Ray Serve
Create the serving script:
vi ray_serve.py
import ray
from ray import serve
ray.init()
serve.start(detached=True)
@serve.deployment
class Model:
    def __call__(self, request):
        return {"message": "Hello from Ray Serve on ARM VM!"}
app = Model.bind()
serve.run(app)
Code explanation
  • serve.start() → initializes serving system
  • @serve.deployment → defines deployable service
  • serve.run() → launches API
Run the service
python3 ray_serve.py
Test the API:
curl http://127.0.0.1:8000/
        {"message":"Hello from Ray Serve on Arm VM!"}
Ray Tune execution in Ray Dashboard
Image Alt Text:Ray Dashboard Jobs tab showing ray_tune.py trials with SUCCEEDED statusRay Tune trials executed successfully with different configurations
The Ray Dashboard shows all jobs executed successfully, confirming correct Ray cluster operation.
Benchmark distributed execution
Create benchmark script:
vi ray_benchmark.py
import ray
import time
ray.init()
@ray.remote
def work(x):
    time.sleep(1)
    return x
start = time.time()
ray.get([work.remote(i) for i in range(20)])
end = time.time()
print("Execution Time:", end - start)
Run the benchmark
ray stop
ray start --head --num-cpus=4
python3 ray_benchmark.py
        Execution Time: 5.171869277954102
Understanding the benchmark
  • 20 tasks executed in parallel
  • Each task takes approximately 1 second
  • With 4 CPUs → total time ≈ 5 seconds
Sequential execution would take approximately 20 seconds
  • Confirms Ray parallel execution
What you’ve learned
You have successfully:
  • Performed hyperparameter tuning
  • Identified the best configuration automatically
  • Deployed a model using Ray Serve
  • Validated parallel performance with benchmarking
You can now extend this setup to multi-node clusters, real ML pipelines, and production deployments.
