Run distributed workloads with Ray
This section demonstrates how to execute parallel tasks and distributed training workloads using Ray on Arm.
You’ll run distributed functions and then scale to multi-worker training using Ray.
Run distributed tasks
Create a Python script to execute parallel tasks:
vi ray_test.py
import ray
ray.init()
@ray.remote
def square(x):
    return x * x
results = ray.get([square.remote(i) for i in range(10)])
print("Results:", results)
Code explanation
  • ray.init() → connects to the running Ray cluster
  • @ray.remote → converts a function into a distributed task
  • square.remote(i) → submits tasks asynchronously
  • ray.get() → collects results from all workers
Execute the script
python3 ray_test.py
The output is similar to:
        Results: [0, 1, 4, 9, 16, 25, 36, 49, 64, 81]
This confirms parallel execution across CPU cores.
Run distributed training
Create a script for distributed model training:
vi ray_train.py
import ray
from ray.train.torch import TorchTrainer
from ray.train import ScalingConfig
import torch
def train_func():
    x = torch.randn(100, 10)
    y = torch.randn(100, 1)
    model = torch.nn.Linear(10, 1)
    loss_fn = torch.nn.MSELoss()
    optimizer = torch.optim.Adam(model.parameters(), lr=0.01)
    for epoch in range(5):
        optimizer.zero_grad()
        loss = loss_fn(model(x), y)
        loss.backward()
        optimizer.step()
        print(f"Loss: {loss.item()}")
trainer = TorchTrainer(
    train_func,
    scaling_config=ScalingConfig(
        num_workers=2,
        use_gpu=False
trainer.fit()
Run the training script
python3 ray_train.py
        (TrainController pid=5522) Attempting to start training worker group of size 2 with the following resources: [{'CPU': 1}] * 2
(TrainController pid=5522) Started training worker group of size 2:
(TrainController pid=5522) - (ip=10.0.0.19, pid=5563) world_rank=0, local_rank=0, node_rank=0
(TrainController pid=5522) - (ip=10.0.0.19, pid=5564) world_rank=1, local_rank=1, node_rank=0
(RayTrainWorker pid=5563) Setting up process group for: env:// [rank=0, world_size=2]
(RayTrainWorker pid=5563) Loss: 0.9711737036705017
(RayTrainWorker pid=5563) Loss: 0.9491967558860779
(RayTrainWorker pid=5563) Loss: 0.9295402765274048
(RayTrainWorker pid=5563) Loss: 0.911673903465271
(RayTrainWorker pid=5563) Loss: 0.895072340965271
(RayTrainWorker pid=5564) Loss: 1.635019063949585 [repeated 5x across cluster] (Ray deduplicates logs by default. Set RAY_DEDUP_LOGS=0 to disable log deduplication, or see https://docs.ray.io/en/master/ray-observability/user-guides/configure-logging.html#log-deduplication for more options.)
This confirms distributed training across multiple workers.
Training code explanation
  • TorchTrainer → handles distributed training execution
  • ScalingConfig(num_workers=2) → runs training on 2 workers
  • Each worker executes training in parallel
  • Logs can appear from multiple processes
Ray Jobs view (tasks and training)
Image Alt Text:Ray Dashboard Jobs tab showing successful execution of ray_test.py and ray_train.pyRay Jobs tab showing distributed tasks and training execution status
  • Each script execution appears as a job
  • Status shows SUCCEEDED
  • Confirms correct distributed execution
You have successfully:
  • Executed parallel tasks using Ray Core
  • Converted functions into distributed workloads
  • Performed distributed training using multiple workers
  • Observed execution in the Ray Dashboard
Next, you’ll perform hyperparameter tuning, deploy models, and benchmark performance.
