In this section, you provision a Google Axion C4A Arm virtual machine on Google Cloud Platform (GCP) using the c4a-standard-4 (4 vCPUs, 16 GB memory) machine type in the Google Cloud Console.
For support on GCP setup, see the Learning Path Getting started with Google Cloud Platform .
To create a virtual machine based on the C4A instance type, navigate to the Google Cloud Console and go to Compute Engine > VM Instances. Select Create Instance.
Under Machine configuration, populate fields such as Instance name, Region, and Zone. Set Series to C4A and select c4a-standard-4 for machine type.
Creating a Google Axion C4A Arm virtual machine in Google Cloud Console
Under OS and Storage, select Change, then choose an Arm64-based OS image. For this Learning Path, use SUSE Linux Enterprise Server. Select “Pay As You Go” for the license type and press Select.
Under Networking, enable Allow HTTP traffic and add “allow-tcp-15672” as a network tag in the Network tags text field.
Adding the TCP/15672 firewall rule to the VM
Select Create to launch the instance. Once created, you see an SSH option and the public IP address for your VM in the list of VM instances. Save the public IP address as you need it in the next step. Select the SSH option to launch an SSH shell into your VM instance.
Invoke an SSH session into your running VM instance
A window opens from your browser and you see a shell into your VM instance.
Terminal shell in your VM instance
You’ve successfully provisioned a Google Axion C4A Arm virtual machine on Google Cloud Platform with the appropriate firewall rules and network configuration. The VM is running SUSE Linux Enterprise Server and is accessible via SSH. Next, you’ll install and configure RabbitMQ on this instance.
