Overview
In this section you’ll implement a real-world asynchronous messaging pattern where RabbitMQ processes WhatsApp notifications reliably using a worker-based architecture.
Why use RabbitMQ for WhatsApp notification
In production systems, sending WhatsApp notifications must be:
  • Reliable
  • Asynchronous
  • Independent of the main application flow
RabbitMQ acts as a message broker to decouple message production from message consumption.
The architecture follows this flow:
  • Application publishes a message to RabbitMQ
  • RabbitMQ routes the message to a queue
  • A Python worker consumes the message
  • The worker simulates sending a WhatsApp notification
Prerequisites
  • GCP SUSE Arm64 virtual machine
  • RabbitMQ installed and running
  • RabbitMQ Management Plugin enabled
  • Python 3.8 or later
  • pika Python client library installed
Install Python dependencies
Install Python and the RabbitMQ Python client needed to build a consumer.
sudo zypper install -y python3 python3-pip
pip3 install pika
Understand the RabbitMQ topology
This use case uses a direct exchange topology for exact-match routing.
Exchanges:
  • notifications (direct): Routes WhatsApp notification messages based on an exact routing key match.
Queue:
  • whatsapp.notifications (durable): Stores WhatsApp messages persistently until they are consumed by a worker.
Binding:
  • Exchange: notifications
  • Routing key: whatsapp
  • Queue: whatsapp.notifications
This ensures only WhatsApp-related messages are routed to the final destination for processing.
Declare RabbitMQ resources
Create the required exchange, queue, and binding for WhatsApp notifications.
./rabbitmqadmin declare exchange \
  name=notifications \
  type=direct \
  durable=true
./rabbitmqadmin declare queue \
  name=whatsapp.notifications \
  durable=true
./rabbitmqadmin declare binding \
  source=notifications \
  destination=whatsapp.notifications \
  routing_key=whatsapp
Each command confirms successful creation.
Validate the setup
Verify that RabbitMQ resources exist and are correctly connected.
./rabbitmqadmin list queues name messages
./rabbitmqadmin list exchanges name type
./rabbitmqadmin list bindings
  • list queues displays all queues along with the number of messages currently stored in each queue.
  • list exchanges lists all exchanges and their types, allowing verification of correct exchange configuration.
  • list bindings shows how exchanges, queues, and routing keys are connected.
The output shows you the following:
  • notifications exchange of type direct
  • whatsapp.notifications durable queue
  • Correct routing key binding (whatsapp)
  • Zero or more queued messages
This confirms topology correctness before consuming messages.
|          name          | messages |
| jobs                   | 0        |
| order.events           | 1        |
| testqueue              | 1        |
| whatsapp.notifications | 0        |
|        name        |  type   |
|                    | direct  |
| amq.direct         | direct  |
| amq.fanout         | fanout  |
| amq.headers        | headers |
| amq.match          | headers |
| amq.rabbitmq.trace | topic   |
| amq.topic          | topic   |
| events             | topic   |
| notifications      | direct  |
|    source     |      destination       |      routing_key       |
|               | jobs                   | jobs                   |
|               | order.events           | order.events           |
|               | testqueue              | testqueue              |
|               | whatsapp.notifications | whatsapp.notifications |
| events        | order.events           | order.*                |
| notifications | whatsapp.notifications | whatsapp               |
Implement the WhatsApp worker
Create a Python consumer (worker) that processes WhatsApp notification messages from the queue.
Create a file named whatsapp_worker.py with the following code:
import pika
import json
import time
RABBITMQ_HOST = "localhost"
RABBITMQ_VHOST = "/"
RABBITMQ_USER = "guest"
RABBITMQ_PASS = "guest"
QUEUE_NAME = "whatsapp.notifications"
credentials = pika.PlainCredentials(RABBITMQ_USER, RABBITMQ_PASS)
parameters = pika.ConnectionParameters(
    host=RABBITMQ_HOST,
    virtual_host=RABBITMQ_VHOST,
    credentials=credentials,
    heartbeat=60
print("[DEBUG] Connecting to RabbitMQ...")
connection = pika.BlockingConnection(parameters)
channel = connection.channel()
print("[DEBUG] Declaring queue...")
channel.queue_declare(queue=QUEUE_NAME, durable=True)
print("[DEBUG] Setting QoS...")
channel.basic_qos(prefetch_count=1)
print("WhatsApp Worker started. Waiting for messages...")
def send_whatsapp(ch, method, properties, body):
    data = json.loads(body.decode())
    print(f"[Worker] Sending WhatsApp message to {data['phone']}")
    print(f"[Worker] Message content: {data['message']}")
    # Simulate external WhatsApp API call
    time.sleep(1)
    print("[Worker] Message sent successfully")
    ch.basic_ack(delivery_tag=method.delivery_tag)
channel.basic_consume(
    queue=QUEUE_NAME,
    on_message_callback=send_whatsapp,
    auto_ack=False
print("[DEBUG] Starting consumer loop (this should block)...")
channel.start_consuming()
Start the worker
Run the worker in a dedicated terminal session:
python3 whatsapp_worker.py
The worker runs correctly and waits for messages without exiting.
The output is similar to:
The process blocks without returning to the shell prompt.
Publish a test message
Open another SSH terminal and publish a WhatsApp notification message to RabbitMQ.
./rabbitmqadmin publish \
  exchange=notifications \
  routing_key=whatsapp \
  payload='{"phone":"+911234567890","message":"Hello from RabbitMQ"}'
The output appears in the first terminal running whatsapp_worker.py:
        [Worker] Sending WhatsApp message to +911234567890
[Worker] Message content: Hello from RabbitMQ
Validate message consumption
The worker terminal displays the complete log:
This confirms:
  • Message routing works correctly
  • Queue consumption is successful
  • Manual acknowledgments are applied
This validates the end-to-end message flow.
Verify queue state
./rabbitmqadmin list queues name messages consumers
|          name          | messages | consumers |
| jobs                   | 0        | 0         |
| order.events           | 2        | 0         |
| testqueue              | 1        | 0         |
| whatsapp.notifications | 0        | 1         |
This confirms:
  • Messages were consumed successfully
  • One active consumer is connected
  • No backlog remains in the queue
What you’ve accomplished
In this use case, you:
  • Configured a direct exchange topology for exact-match routing
  • Created durable queues and bindings for WhatsApp notifications
  • Implemented a Python worker using the pika library
  • Published test messages and validated end-to-end message flow
  • Confirmed reliable message consumption with manual acknowledgments
This pattern demonstrates how RabbitMQ enables asynchronous, decoupled communication for notification systems on Arm-based cloud platforms.
