RabbitMQ Use Case – Event Processing with Python Workers
This use case demonstrates how RabbitMQ enables event-driven architectures using topic exchanges, durable queues, and Python-based worker consumers. It focuses on reliable, asynchronous event processing, which is a common production pattern.
  • Topic exchange–based routing
  • Durable queues and bindings
  • A Python-based worker using the pika client
  • Message publishing and consumption validation
The use case models an event-driven system, where order-related events are published and processed asynchronously by workers.
Use case overview
Scenario:
An application publishes order-related events (order.created, order.updated, etc.) to RabbitMQ. A background worker consumes these events from a queue and processes them independently.
The goal of this use case is to showcase how order-related events can be published to RabbitMQ and processed asynchronously by background workers without tightly coupling producers and consumers.
Typical events include:
  • order.created
  • order.updated
  • order.completed
This architecture improves scalability, fault tolerance, and system decoupling.
Prerequisites
  • RabbitMQ installed and running
  • RabbitMQ management plugin enabled
  • Python 3 installed
  • Network access to RabbitMQ broker
Declare a topic exchange
Create a durable topic exchange to route events based on routing keys.
./rabbitmqadmin declare exchange name=events type=topic durable=true
  • Creates a durable topic exchange named events.
  • Routes messages using wildcard-based routing keys (for example, order.*).
  • Ensures the exchange survives broker restarts.
Declare a durable queue
Create a durable queue to store order-related events.
./rabbitmqadmin declare queue name=order.events durable=true
  • Create a durable queue for order events.
  • Guarantee that messages are persisted until consumed.
  • Ensure reliability in case of worker or broker restarts.
You should see an output similar to:
        queue declared
Bind queue to exchange
Bind the queue to the exchange using a topic routing pattern.
./rabbitmqadmin declare binding source=events destination=order.events routing_key="order.*"
  • Connects the queue to the exchange.
  • Ensures all order-related routing keys match the queue.
  • Enables flexible event expansion without changing consumers.
        binding declared
This binding ensures the queue receives all messages with routing keys such as:
  • order.created
  • order.updated
  • order.completed
Publish an event message
Publish a sample order event to the exchange.
./rabbitmqadmin publish exchange=events routing_key="order.created" payload='{"order_id":123}'
  • Publishes an event to the events exchange.
  • Uses a routing key that matches the binding filter.
  • Payload is structured JSON to simulate real event data.
        Message published
Install Python dependencies
Install pip and the pika RabbitMQ client library.
sudo zypper install -y python3-pip
pip install pika
Create the worker script
Create a Python worker file to process messages from a queue.
A Python worker was created to process messages from a RabbitMQ queue (jobs) using the pika library. The queue is durable, ensuring message persistence. The worker implements fair dispatch (prefetch_count=1) and manual acknowledgments to reliably process each job without loss. Messages were successfully published to the queue using rabbitmqadmin, and the worker consumed them as expected.
Using your favorite editor (the example uses “edit”) create your “worker.py” file:
edit worker.py
worker.py:
import pika
import time
import json
# RabbitMQ broker address
RABBITMQ_IP = "localhost"
connection = pika.BlockingConnection(
    pika.ConnectionParameters(host=RABBITMQ_IP)
channel = connection.channel()
# Ensure queue exists
channel.queue_declare(queue='jobs', durable=True)
print("Worker started. Waiting for jobs...")
def process_job(ch, method, properties, body):
    job = json.loads(body.decode())
    print(f"[Worker] Received job: {job}")
    # Simulate processing
    time.sleep(2)
    # Acknowledge message
    ch.basic_ack(delivery_tag=method.delivery_tag)
# Fair dispatch configuration
channel.basic_qos(prefetch_count=1)
channel.basic_consume(
    queue='jobs',
    on_message_callback=process_job
channel.start_consuming()
Start the worker
Run the worker process.
python3 worker.py
        The worker started. Waiting for jobs...
Publish job messages
From another SSH terminal, publish a job message.
./rabbitmqadmin publish routing_key=jobs payload='{"job":"test1"}'
Worker output:
[Worker] Received job: {'job': 'test1'}
Publish another job:
./rabbitmqadmin publish routing_key=jobs payload='{"job":"hello1"}'
Worker output:
[Worker] Received job: {'job': 'hello1'}
Press “CTRL-C” to exit the worker application.
Use case validation
  • Event routing via topic exchanges functions correctly
  • Durable queues and acknowledgments ensure reliable message processing
  • Worker-based consumption supports safe and controlled job execution
This use case demonstrates how RabbitMQ enables reliable, decoupled, and scalable event processing using topic-based routing and Python workers. The setup provides a strong foundation for production-grade, message-driven architectures on GCP SUSE Arm64 virtual machines.
