Learn about Arm-based cloud platforms for RabbitMQ
Create an Azure Cobalt 100 virtual machine
Install RabbitMQ on Azure Cobalt 100
Validate RabbitMQ on Azure
Create a firewall rule for RabbitMQ
Create a Google Axion C4A virtual machine
Install RabbitMQ on Google Cloud SUSE VM
Validate RabbitMQ on Google Cloud
RabbitMQ use Case 1 - event processing with Python Workers
RabbitMQ use case 2 - WhatsApp Notification
Install RabbitMQ on a Google Cloud Platform SUSE Linux Arm64 virtual machine using RPM packages for both Erlang and RabbitMQ Server.
RabbitMQ requires Erlang to be installed first.
You need:
Update the system’s package list so the operating system recognizes the latest software available from its repositories.
sudo zypper refresh
Install the basic tools needed to download and manage packages.
sudo zypper install -y curl wget gnupg tar socat logrotate
RabbitMQ depends on Erlang. Download the Erlang RPM compatible with the Arm64 architecture.
wget https://github.com/rabbitmq/erlang-rpm/releases/download/v26.2.5/erlang-26.2.5-1.el8.aarch64.rpm
sudo rpm -Uvh erlang-26.2.5-1.el8.aarch64.rpm
Confirm that Erlang is installed correctly.
erl -eval 'io:format("~s~n", [erlang:system_info(system_version)]), halt().' -noshell
You should see an output similar to:
Erlang/OTP 26 [erts-14.2.5] [source] [64-bit] [smp:4:4] [ds:4:4:10] [async-threads:1] [jit]
Download the RabbitMQ Server RPM package.
wget https://github.com/rabbitmq/rabbitmq-server/releases/download/v4.2.0/rabbitmq-server-4.2.0-1.el8.noarch.rpm
sudo rpm -Uvh rabbitmq-server-4.2.0-1.el8.noarch.rpm
RabbitMQ version 3.11.0 introduced significant performance enhancements for Arm-based architectures. This version needs Erlang 25.0 or later, which brings Just-In-Time (JIT) compilation and modern flame graph profiling tooling to both x86 and Arm64 CPUs. These features result in improved performance on Arm64 architectures. You can view this release note
The Arm Ecosystem Dashboard recommends RabbitMQ version 3.11.0, the minimum recommended on Arm platforms.
Enable RabbitMQ to start automatically on boot and start the service immediately.
sudo systemctl enable rabbitmq-server --now
Check the status of the RabbitMQ service.
sudo systemctl status rabbitmq-server
The service should be in an active (running) state.
Enable the RabbitMQ management plugin to access the web-based dashboard.
sudo rabbitmq-plugins enable rabbitmq_management
Restart RabbitMQ to apply plugin changes.
sudo systemctl restart rabbitmq-server
Confirm the installed RabbitMQ version.
sudo rabbitmqctl version
4.2.0
Create a new RabbitMQ user for remote access.
Create a new admin user by running these commands on the VM:
sudo rabbitmqctl add_user admin StrongPassword123
sudo rabbitmqctl set_user_tags admin administrator
sudo rabbitmqctl set_permissions -p / admin ".*" ".*" ".*"
Log in to Management UI
Now, test it from outside the VM. Open a web browser on your local machine (Chrome, Firefox, Edge, etc.) and enter the following URL and credentials in the address bar:
Replace <VM_IP> with the public IP of your GCP VM.
If everything is configured correctly, you see a RabbitMQ login page in your browser that looks like this:
Figure 1: RabbitMQ Login page
This confirms that your RabbitMQ management dashboard is operational.
