Validate your RabbitMQ installation on the Google Cloud SUSE Linux Arm64 virtual machine. This baseline confirms:
  • RabbitMQ service health
  • Management plugin availability
  • Queue operations (create, publish, consume)
  • CLI tooling functionality (rabbitmqctl and rabbitmqadmin)
Check RabbitMQ node status
Verify that the RabbitMQ node is operational and healthy.
sudo rabbitmqctl status
  • Node status reports RabbitMQ is running
  • No active alarms
  • Listeners are active on ports 5672 and 15672
  • Memory and disk space are within safe limits
Verify enabled plugins
Confirm that the RabbitMQ management plugins are enabled.
sudo rabbitmq-plugins list | grep management
You should see an output similar to:
        [  ] rabbitmq_federation_management          4.2.0
[E*] rabbitmq_management                     4.2.0
[e*] rabbitmq_management_agent               4.2.0
[  ] rabbitmq_shovel_management              4.2.0
[  ] rabbitmq_stream_management              4.2.0
Validate RabbitMQ listeners
Ensure RabbitMQ is listening on the required ports.
sudo rabbitmqctl status | grep -A5 Listeners
        Listeners
Interface: [::], port: 15672, protocol: http, purpose: HTTP API
Interface: [::], port: 25672, protocol: clustering, purpose: inter-node and CLI tool communication
Interface: [::], port: 5672, protocol: amqp, purpose: AMQP 0-9-1 and AMQP 1.0
Download RabbitMQ Admin CLI tool
Download the rabbitmqadmin CLI tool from the local management endpoint.
curl -u guest:guest http://localhost:15672/cli/rabbitmqadmin -o rabbitmqadmin
Make the tool executable:
chmod +x rabbitmqadmin
Validate queue creation
Create a test queue to validate write operations.
./rabbitmqadmin declare queue name=testqueue durable=false
        queue declared
Publish a test message
Send a test message to the queue.
./rabbitmqadmin publish exchange=amq.default routing_key=testqueue payload="hello world"
        Message published
Consume message from queue
Retrieve messages from the queue to verify read functionality.
./rabbitmqadmin get queue=testqueue
| routing_key | exchange | message_count |   payload   | payload_bytes | payload_encoding | properties | redelivered |
| testqueue   |          | 0             | hello world | 11            | string           |            | False       |
Verify queue state
Confirm that the queue is empty after consumption.
./rabbitmqadmin list queues name messages
|     name     | messages |
| jobs         | 0        |
| order.events | 1        |
| testqueue    | 1        |
Baseline validation summary
  • RabbitMQ node is running and healthy
  • The management plugin is enabled and accessible
  • Queue creation is successful
  • Message publishing works as expected
  • Message consumption functions correctly
  • CLI tools operate without error
This confirms a successful baseline validation of RabbitMQ on a GCP SUSE Arm64 virtual machine.
