RabbitMQ baseline validation on GCP SUSE Arm64 VM
In this section you’ll validate your RabbitMQ installation on the Google Cloud SUSE Linux Arm64 virtual machine by confirming:
  • RabbitMQ service health
  • Management plugin availability
  • Queue operations (create, publish, consume)
  • CLI tooling functionality (rabbitmqctl and rabbitmqadmin)
Check RabbitMQ node status
Verify that the RabbitMQ node is operational and healthy.
sudo rabbitmqctl status
The command returns detailed status information. Verify that:
  • Node status reports RabbitMQ is running
  • No active alarms
  • Listeners are active on ports 5672 and 15672
  • Memory and disk space are within safe limits
Verify enabled plugins
Confirm that the RabbitMQ management plugins are enabled:
sudo rabbitmq-plugins list | grep management
The output is similar to:
        [  ] rabbitmq_federation_management          4.2.0
[E*] rabbitmq_management                     4.2.0
[e*] rabbitmq_management_agent               4.2.0
[  ] rabbitmq_shovel_management              4.2.0
[  ] rabbitmq_stream_management              4.2.0
Validate RabbitMQ listeners
Ensure RabbitMQ is listening on the required ports:
sudo rabbitmqctl status | grep -A5 Listeners
        Listeners
Interface: [::], port: 15672, protocol: http, purpose: HTTP API
Interface: [::], port: 25672, protocol: clustering, purpose: inter-node and CLI tool communication
Interface: [::], port: 5672, protocol: amqp, purpose: AMQP 0-9-1 and AMQP 1.0
Download RabbitMQ admin CLI tool
The rabbitmqadmin command is a Python script to manage and monitor RabbitMQ.
Download the CLI tool from the local management endpoint to the virtual machine. You can also download and run rabbitmqadmin on your local computer, but you need to have python3 installed, including pip3.
curl -u guest:guest http://localhost:15672/cli/rabbitmqadmin -o rabbitmqadmin
Make the tool executable:
chmod +x rabbitmqadmin
Validate queue creation
Create a test queue to validate write operations:
./rabbitmqadmin declare queue name=testqueue durable=false
        queue declared
Publish a test message
Send a test message to the queue:
./rabbitmqadmin publish exchange=amq.default routing_key=testqueue payload="hello world"
        Message published
Consume message from queue
Retrieve messages from the queue to verify read functionality:
./rabbitmqadmin get queue=testqueue
| routing_key | exchange | message_count |   payload   | payload_bytes | payload_encoding | properties | redelivered |
| testqueue   |          | 0             | hello world | 11            | string           |            | False       |
Verify queue state
Confirm that the queue is empty after consumption:
./rabbitmqadmin list queues name messages
|   name    | messages |
| testqueue | 1        |
You’ve successfully validated RabbitMQ on your Google Cloud SUSE Arm64 virtual machine. The node is running and healthy, the management plugin is enabled and accessible, and queue operations (creation, publishing, consumption) work correctly. Next, you’ll explore practical use cases that demonstrate RabbitMQ’s capabilities for event-driven architectures and notification systems.
