Understand vector search with Qdrant on Google Axion
Create a Google Axion C4A Arm virtual machine
Install and run Qdrant on Axion
Generate and index vector embeddings
Query vector embeddings with semantic search
Build a chatbot with Qdrant on Axion
Understand the vector search architecture
In this section, you prepare a SUSE Linux Enterprise Server (SLES) arm64 virtual machine and deploy Qdrant, an open-source vector database designed for efficient similarity search and vector indexing.
Qdrant enables applications to store and retrieve embeddings — numerical vector representations of data such as text, images, and audio. These embeddings allow applications to perform semantic search and AI-powered retrieval.
Running Qdrant on Google Axion Arm-based infrastructure enables efficient execution of modern AI workloads including semantic search, recommendation systems, and chatbot retrieval pipelines.
The deployment creates a simple vector search system where embeddings are generated and stored in Qdrant, enabling fast semantic similarity queries.
SUSE Linux Enterprise Server (arm64)
v
Docker Container Runtime
v
Qdrant Vector Database
v
Vector Embeddings Storage
v
Semantic Similarity Search
Update package repositories and installed packages.
sudo zypper refresh
sudo zypper update -y
Install Docker and Python dependencies.
sudo zypper install -y docker python3 python3-pip git
sudo zypper install -y python311 python311-pip
Create and activate a virtual environment to isolate Python dependencies and avoid system-level package conflicts.
python3.11 -m venv qdrant-env
source qdrant-env/bin/activate
pip install --upgrade pip
Your prompt changes to show (qdrant-env) when the environment is active. Use this environment for all subsequent Python commands in this Learning Path.
Verify Python installation:
python3.11 --version
The output is similar to:
Python 3.11.10
Why this matters:
Start and enable the Docker service.
sudo systemctl enable docker
sudo systemctl start docker
sudo usermod -aG docker $USER ; newgrp docker
The newgrp command avoids the need to logout and back in for the docker group permissions to take effect.
docker --version
Docker version 28.5.1-ce, build f8215cc26
Docker runs Qdrant in an isolated container environment.
Start the Qdrant container.
docker run -d \
-p 6333:6333 \
-p 6334:6334 \
-v $(pwd)/qdrant_storage:/qdrant/storage \
qdrant/qdrant
This command:
latest: Pulling from qdrant/qdrant
3ea009573b47: Pull complete
4f4fb700ef54: Pull complete
ea8055cf6833: Pull complete
9d7bb093ff98: Pull complete
13053c6d0c21: Pull complete
c017fa517b2b: Pull complete
3e2c95baf78f: Pull complete
b940a5cd37f5: Pull complete
Digest: sha256:f1c7272cdac52b38c1a0e89313922d940ba50afd90d593a1605dbbc214e66ffb
Status: Downloaded newer image for qdrant/qdrant:latest
1af9f6ac9cef017016837667f68aeed22a74f0f6352effd568dfa188337820c0
Check running containers.
docker ps
1af9f6ac9cef qdrant/qdrant "./entrypoint.sh" 13 seconds ago Up 11 seconds 0.0.0.0:6333-6334->6333-6334/tcp, [::]:6333-6334>6333-6334/tcp inspiring_dijkstra
This confirms the Qdrant container is running successfully.
Verify the Qdrant service by calling the REST API.
curl http://localhost:6333
You should see an output similar to:
{"title":"qdrant - vector search engine","version":"1.17.0","commit":"4ab6d2ee0f6c718667e553b1055f3e944fef025f"}gcpuser@qdrant-arm64~>
This confirms the vector database service is reachable and ready for use.
In this section, you learned how to:
In the next section, you will generate vector embeddings using a transformer model and store them in Qdrant, enabling semantic search and AI-powered retrieval.
