Understand vector search with Qdrant on Google Axion
Create a Google Axion C4A Arm virtual machine
Install and run Qdrant on Axion
Generate and index vector embeddings
Query vector embeddings with semantic search
Build a chatbot with Qdrant on Axion
Understand the vector search architecture
In this section, you generate vector embeddings from sample text data and store them in the Qdrant vector database.
Embeddings are numerical vector representations of data such as text, images, or audio. These vectors capture semantic meaning, allowing applications to perform similarity search and retrieve the most relevant results.
Using Sentence Transformers, you convert text into embeddings and store them in Qdrant for efficient vector indexing and retrieval.
The workflow focuses on embedding generation and vector storage.
Text Documents
v
Sentence Transformer Model
v
Vector Embeddings
v
Qdrant Vector Database
v
Indexed Vectors Ready for Search
Make sure the qdrant-env virtual environment is active before installing libraries. If you opened a new terminal, reactivate it:
source ~/qdrant-env/bin/activate
Install the Python libraries required for embedding generation and communication with the Qdrant API.
pip install qdrant-client sentence-transformers
These libraries provide:
Create a working directory for the vector ingestion scripts.
mkdir qdrant-rag-demo
cd qdrant-rag-demo
The directory will contain the Python scripts used to generate embeddings and query the vector database.
Create the Python file:
vi ingest.py
Add the following code:
from qdrant_client import QdrantClient
from qdrant_client.models import VectorParams, Distance, PointStruct
from sentence_transformers import SentenceTransformer
client = QdrantClient(url="http://localhost:6333")
collection_name = "axion_demo"
client.recreate_collection(
collection_name=collection_name,
vectors_config=VectorParams(size=384, distance=Distance.COSINE),
model = SentenceTransformer("sentence-transformers/all-MiniLM-L6-v2")
documents = [
"Axion processors provide Arm based cloud compute.",
"Vector databases enable semantic search.",
"Qdrant is optimized for vector similarity search.",
"RAG pipelines combine retrieval with LLMs."
vectors = model.encode(documents)
points = [
PointStruct(id=i, vector=vectors[i].tolist(), payload={"text": documents[i]})
for i in range(len(documents))
client.upsert(collection_name=collection_name, points=points)
print("Documents indexed successfully in Qdrant")
The script performs several important operations:
Execute the script to generate embeddings and store them in Qdrant.
python ingest.py
The output is similar to:
Documents indexed successfully in Qdrant!
The output confirms that the vectors have been successfully inserted into the database.
Check that the vector collection exists in Qdrant.
curl http://localhost:6333/collections
{"result":{"collections":[{"name":"axion_demo"}]},"status":"ok","time":4.01e-6}
In this section, you learned how to:
In the next section, you will query the vector database and perform semantic similarity search, enabling AI-powered retrieval and chatbot-style knowledge queries.
