This section outlines some common problems that can be encountered when you are deploying the tools, and their solutions.
Data size can be very large when capturing with -I poll. This occurs
because the polling mode is provided as a fallback for systems without the
kernel patches. To capture data for function-attribution without the patches,
the tool must use a very high sample rate which increases the captured data
size.
To avoid this issue, apply the kernel patch as described in the
Install guide
, and run sl-record without the -I option. The kernel patch implements strobed sampling, allowing the tool to alternate between a fast “mark” window that is captured and a slow “space” window that is skipped.
SPE uses hardware sampling that allows a high sample rate. Captured data size scales as “core count * sample rate * capture duration”, which can result in very large SPE data sets in systems with many CPU cores, using a high sample rate, or with a long application duration.
When profiling long running applications with SPE, Arm recommends increasing
the size of the SPE sample window. Use the -F option to set the number of
micro-ops between samples (default 2500000).
The application runs out of file descriptors when capturing with -I poll.
This occurs because the polling mode is provided as a fallback for systems without the kernel patches. To attach perf counter groups to a new application thread you must open a new file descriptor for each counter group for every core in the system. This operation has O(counters * cores * threads) complexity, and requires a very large number of file descriptors on Arm Neoverse systems which can have both high core count and high thread count.
To avoid this, apply the kernel patch as described in the
Install guide
, and run sl-record without the -I option, which is equivalent to -I inherit. The kernel patch allows new child threads to inherit perf counter groups, avoiding the need to open new file descriptors.
If it is not possible to install the kernel patches, you can increase the number of allowed file descriptors per process:
sudo ulimit -n -H $((64*1024*1024))
sudo ulimit -n -S $((64*1024*1024))
The Streamline GUI contains “SPE Aux data missing” markers in the Timeline view when opening the capture. This occurs because a sample buffer overflowed before
sl-record was able to store the data it contained.
There are three changes you can make to mitigate this problem:
perf sample buffer.sl-record sample buffer.To reduce SPE sample rate, use the -F option to increase the number of micro-operations between samples (default is 2500000).
To increase the size of the perf sample buffer, you can either manually increase the mlock limit (value must be a multiple of 4):
echo <num_kb> | sudo tee /proc/sys/kernel/perf_event_mlock_kb
Alternatively, you can run sl-record as root, which bypasses the mlock limit.
To increase the size of the sl-record internal sample buffer, use the -Z <num_pages> option to specify the number of 4K pages to use. A buffer of
this size is allocated per core in the system, so ensure that you leave enough memory for your application to run on systems with many CPU cores.
Application performance is impacted by running under sl-record on a high core count system.
This occurs because capturing and storing the profiling data has an overhead on the running system, especially when multiplexing counters with Perf.
To mitigate this issue, limit the running application to a subset of the CPU cores, leaving a small number of cores free for sl-record. For example, on a
64 core system Arm recommends limiting the application to 60 cores.
