The underlying storage technology and the file system format can impact performance significantly. In general, locally attached SSD storage will perform best. However, network based storage systems can perform well. As always, performance is dependent on the request profile coming from clients. You should spend some time studying and experimenting with different storage technologies and configuration options.
Aside from the storage technology, it is also worth testing different file system formats with PostgreSQL. The xfs file system is a good starting point. The ext4 file system is another good alternative.
PostgreSQL can benefit from adjustments to kernel parameters. Below is a list of kernel related settings that can have a positive impact on performance.
Linux-PAM limits can be changed in the /etc/security/limits.conf file, or by using the ulimit command.
If you want more information about how to display and modify parameters check the documentation of the ulimit command.
To display all limits:
ulimit -a
An explanation about why these Linux-PAM settings can help performance is found in the PostgreSQL documentation .
Some of the key settings that can affect performance are:
ulimit -n)ulimit -u)ulimit -d)ulimit -l)Making changes to the Linux Virtual Memory subsystem can also improve performance.
These settings can be changed in the /etc/sysctl.conf file, or by using the sysctl command.
If you want more information about how to display and modify virtual memory parameters check the documentation of the sysctl command.
Documentation on each of these parameters can be found in the admin-guide for sysctl in the Linux source code .
To list all kernel parameters available:
sudo sysctl -a
The overcommit policy is set via the sysctl `vm.overcommit_memory’ setting.
The recommended setting for vm.overcommit_memory is 2 according to the
To set the overcommit_memory parameter to 2 temporarily, run the following command:
sudo sysctl -w vm.overcommit_memory=2
To make the change permanent:
sudo sh -c 'echo "vm.overcommit_memory=2" >> /etc/sysctl.conf'
This tells Linux to never over commit memory. Setting vm.overcommit_memory to 2 is to avoid a situation where the kernel might terminate the PostgreSQL postmaster when memory is scarce.
PostgreSQL benefits from using huge memory pages. Huge pages reduce how often virtual memory pages are mapped to physical memory.
To see the current memory page configuration, run the following command on the host:
cat /proc/meminfo | grep ^Huge
The output should be similar to:
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 0 kB
Huge pages are not being used if HugePages_Total is 0 (this is the default).
Also note that Hugepagesize is 2MB which is the typical default for huge pages on Linux.
You can modify the huge page values.
The setting that enables huge pages is shown below:
vm.nr_hugepages
This parameter sets the number of huge pages you want the kernel to make available to applications.
The total amount of memory that will be used for huge pages will be this number (defaulted to 0) times the Hugepagesize.
As an example, if you want a total of 1GB of huge page space, then you should set vm.nr_hugepages to 500 (500x2MB=1GB).
sudo sysctl -w vm.nr_hugepages=500
sudo sh -c 'echo "vm.nr_hugepages=500" >> /etc/sysctl.conf'
You should set vm.nr_hugepages to a value that gives a total huge page space slightly bigger than the PostgreSQL shared buffer size (discussed later).
Make it slightly larger than the shared buffer because PostgreSQL will use additional memory for things like connection management.
More information on the different parameters that affect the configuration of huge pages can be found in the admin-guide for hugetlbpage in the Linux source code .
PostgreSQL writes data to files like any Linux process does. The behavior of the page cache can affect performance. There are two sysctl that parameters control how often the kernel flushes the page cache data to disk.
vm.dirty_background_ratio=5vm.dirty_ratio=20The vm.dirty_background_ratio sets the percentage of the page cache that needs to be dirty in order for a flush to disk to start in the background.
Setting this value to lower than the default (typically 10) helps write heavy workloads. This is because by lowering this threshold, you are spreading writes to storage over time. This reduces the probability of saturating storage performance. Setting this value to 5 can improve performance.
The vm.dirty_ratio sets the percentage of the page cache that needs to be dirty in order for threads that are writing to storage to be paused to allow flushing to catch up.
This should be set higher than vm.dirty_background_ratio. The OS default is typically around 20 which is usually good. In some cases it may be beneficial to set this value to be higher, it gives the background flusher (controlled by vm.dirty_background_ratio) more time to catch up if disk writes are very bursty. In general, you can leave this to the OS default, but it may be worth experimenting with higher values on specific workload profiles.
The easiest way to gain performance is to use the latest version of GCC. Aside from that, the flags -mcpu and -flto can be used to potentially gain additional performance. Usage of these flags is explained in the
Migrating C/C++ applications
section of the
Migrating applications to Arm servers
learning path.
PostgreSQL relies on OpenSSL for cryptographic operations. Thus, the version of OpenSSL used with PostgreSQL (and the GCC version and switches used to compile it) can impact performance. Typically using the Linux distribution default version of OpenSSL is sufficient so long as the Linux distribution used isn’t very old. That said, it is possible to use newer versions of OpenSSL which could yield performance improvements. We leave this as an exercise to the reader.
