In this section, you create database tables, load sample data, and execute analytical queries on PostgreSQL.
At the end of this section, your database is:
Connect to the PostgreSQL database as the superuser.
sudo -u postgres psql -d appdb
Create two tables to simulate a transactional application.
CREATE TABLE customers (
id SERIAL PRIMARY KEY,
name TEXT,
email TEXT,
created_at TIMESTAMP DEFAULT CURRENT_TIMESTAMP
CREATE TABLE orders (
customer_id INT REFERENCES customers(id),
amount NUMERIC,
status TEXT,
These tables represent:
customers: user informationorders: transactional records linked via foreign keyPopulate the customers table.
INSERT INTO customers (name, email)
SELECT 'user_' || i, 'user_' || i || '@example.com'
FROM generate_series(1, 100000) AS i;
Populate the orders table.
INSERT INTO orders (customer_id, amount, status)
SELECT
(floor(random() * 100000) + 1)::int,
(random() * 1000),
CASE WHEN random() > 0.5 THEN 'completed' ELSE 'pending' END
FROM generate_series(1, 500000) AS i;
This generates:
Ensure the application user owns the tables to allow schema changes and indexing.
ALTER TABLE customers OWNER TO appuser;
ALTER TABLE orders OWNER TO appuser;
The queries in this section are analytical (OLAP-style) queries running against the transactional (OLTP) dataset you just loaded. PostgreSQL handles both workload types, which makes it well suited to applications that need operational reporting without a separate data warehouse.
SELECT SUM(amount) FROM orders WHERE status = 'completed';
What this query does:
The output is similar to:
sum
125444891.15572856461471770
(1 row)
What the output means:
The following query aggregates order totals per customer across the full orders table — a typical OLAP aggregation on OLTP data.
SELECT customer_id, SUM(amount) AS total_spent
FROM orders
GROUP BY customer_id
ORDER BY total_spent DESC
LIMIT 10;
customer_id | total_spent
45136 | 9402.1803173247709
70670 | 9179.385512892869
57604 | 8936.2102913510321
3594 | 8885.8026615034014
68349 | 8817.484402872083
45974 | 8761.6822572100911
20049 | 8739.8605561353213
79794 | 8615.155198629147
67514 | 8573.093324224081
49210 | 8497.876121330483
(10 rows)
The output means:
The following query joins customers and orders, counts how many orders each customer placed, and ranks them by activity. It’s a multi-table analytical query — the join across two OLTP tables produces an OLAP-style activity report.
SELECT c.name, COUNT(o.id)
FROM customers c
JOIN orders o ON c.id = o.customer_id
GROUP BY c.name
ORDER BY COUNT(o.id) DESC
LIMIT 10;
name | count
user_24831 | 17
user_59573 | 16
user_92684 | 16
user_20049 | 16
user_99775 | 16
user_35090 | 16
user_39820 | 16
user_45879 | 15
user_18306 | 15
user_45974 | 15
(10 rows)
The output means:
Exit the current session first.
\q
Connect using the application user.
psql -h localhost -U appuser -d appdb
When prompted for a password, enter StrongPassword123.
You’ve successfully deployed a relational schema and executed analytical queries on PostgreSQL. Your setup includes:
Next, you’ll benchmark PostgreSQL performance and optimize query execution using indexing and monitoring tools.
