In this section, you benchmark PostgreSQL performance and optimize query execution using monitoring and indexing techniques.
At the end of this section, your PostgreSQL deployment is:
Use pgbench to prepare a benchmarking dataset.
sudo -u postgres pgbench -i -s 50 appdb
The command creates standard benchmarking tables and loads data for testing. The output looks similar to:
dropping old tables...
NOTICE: table "pgbench_accounts" does not exist, skipping
NOTICE: table "pgbench_branches" does not exist, skipping
NOTICE: table "pgbench_history" does not exist, skipping
NOTICE: table "pgbench_tellers" does not exist, skipping
creating tables...
generating data (client-side)...
5000000 of 5000000 tuples (100%) done (elapsed 6.32 s, remaining 0.00 s)
vacuuming...
creating primary keys...
done in 8.88 s (drop tables 0.00 s, create tables 0.02 s, client-side generate 6.36 s, vacuum 0.14 s, primary keys 2.37 s).
Execute the benchmark workload.
sudo -u postgres pgbench -c 20 -j 4 -T 60 appdb
Parameters used:
c 20 → number of clientsj 4 → worker threadsT 60 → duration (seconds)The output is similar to:
pgbench (16.13 (Ubuntu 16.13-0ubuntu0.24.04.1))
starting vacuum...end.
transaction type: <builtin: TPC-B (sort of)>
scaling factor: 50
query mode: simple
number of clients: 20
number of threads: 4
maximum number of tries: 1
duration: 60 s
number of transactions actually processed: 144162
number of failed transactions: 0 (0.000%)
latency average = 8.327 ms
initial connection time = 10.771 ms
tps = 2401.873115 (without initial connection time)
The result shows the transactional (OLTP) throughput PostgreSQL achieves on this Cobalt 100 Arm64 instance under the configured load. TPS and latency will vary with instance size, client count, and workload shape.
Edit the PostgreSQL configuration file.
sudo nano /etc/postgresql/16/main/postgresql.conf
Add the following parameter:
shared_preload_libraries = 'pg_stat_statements'
Restart PostgreSQL:
sudo systemctl restart postgresql
sudo -u postgres psql -d appdb
CREATE EXTENSION pg_stat_statements;
Retrieve the most expensive queries:
SELECT query, total_exec_time, calls
FROM pg_stat_statements
ORDER BY total_exec_time DESC
LIMIT 5;
query | total_exec_time | calls
CREATE EXTENSION pg_stat_statements | 6.995225 | 1
(1 row)
The output helps identify performance bottlenecks.
Run an execution plan for a sample query.
EXPLAIN ANALYZE
SELECT * FROM orders WHERE amount > 500;
QUERY PLAN
Seq Scan on orders (cost=0.00..10417.00 rows=248493 width=35) (actual time=0.015..60.679 rows=250660 loops=1)
Filter: (amount > '500'::numeric)
Rows Removed by Filter: 249340
Planning Time: 0.248 ms
Execution Time: 69.429 ms
(5 rows)
A sequential scan is expected because a large portion of rows match the condition. When more than roughly 10–15% of rows qualify, the planner typically prefers a sequential scan over an index scan.
PostgreSQL automatically creates indexes on primary key columns, but not on foreign key columns. The customer_id column in the orders table is a foreign key that join queries filter and group by. Without an index, those joins require a full scan of the orders table.
Connect to the database as the application user if you aren’t already.
psql -h localhost -U appuser -d appdb
Create an index on the foreign key column.
CREATE INDEX idx_orders_customer_id ON orders(customer_id);
Verify the index was created.
\d orders
Table "public.orders"
Column | Type | Collation | Nullable | Default
id | integer | | not null | nextval('orders_id_seq'::regclass)
customer_id | integer | | |
amount | numeric | | |
status | text | | |
created_at | timestamp without time zone | | | CURRENT_TIMESTAMP
Indexes:
"orders_pkey" PRIMARY KEY, btree (id)
"idx_orders_customer_id" btree (customer_id)
Foreign-key constraints:
"orders_customer_id_fkey" FOREIGN KEY (customer_id) REFERENCES customers(id)
The index idx_orders_customer_id is now listed alongside the primary key index. PostgreSQL’s query planner will use it for queries that filter or join on customer_id, reducing full table scans for those operations.
You’ve successfully benchmarked and optimized PostgreSQL on an Arm64 system. Your setup now includes:
Your PostgreSQL deployment is now ready for real-world workloads on Cobalt 100 infrastructure.
