# Download and build the PMUv3 plugin
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/pmuv3_plugin_learning_path/)
- [PMUv3 plugin features](https://learn.arm.com/learning-paths/servers-and-cloud-computing/pmuv3_plugin_learning_path/intro/)
- [Download and build the PMUv3 plugin](https://learn.arm.com/learning-paths/servers-and-cloud-computing/pmuv3_plugin_learning_path/before-you-begin/)
- [Instrument one section of code](https://learn.arm.com/learning-paths/servers-and-cloud-computing/pmuv3_plugin_learning_path/instrumentation/)
- [Plot, visualize, and analyze the results](https://learn.arm.com/learning-paths/servers-and-cloud-computing/pmuv3_plugin_learning_path/plot/)
- [Instrument multiple sections of code](https://learn.arm.com/learning-paths/servers-and-cloud-computing/pmuv3_plugin_learning_path/instrumentation2/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/pmuv3_plugin_learning_path/_next-steps/)
To get started, navigate to an empty directory on your Arm Linux computer and prepare the PMUv3 plugin.
## User space PMU access
To use the PMUv3 plugin, you need permission to access the performance counters from userspace applications.
To enable userspace access until the next reboot, run the following:
```bash
sudo sysctl kernel/perf_user_access=1
If access is allowed, the command output is as follows:
kernel.perf_user_access = 1
You can check if userspace access is enabled any time by running the following:
```bash
cat /proc/sys/kernel/perf_user_access
A value of 1 means userspace access is enabled and a value of 0 indicates that it’s disabled.
To permanently change the value, add the following line to the file `/etc/sysctl.conf`:
## Directory structure
The instructions assume you have the Linux kernel source tree, the PMUv3 plugin source code, and your test application in parallel. If you have a different directory structure, you may need to adjust the build commands to find the header files and libraries.
Here are the 3 directories you will create:
./linux
./PMUv3_plugin
./test
## Linux kernel libraries
The PMUv3 plugin requires two Linux Perf related libraries.
The easiest way to get them is to build them from the Linux source tree.
Download the Linux source using the following `git` command. Replace the branch with the major and minor number for the running kernel. This can be found with the `uname -r` command:
```bash
git clone --depth=1 --branch v6.19 git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git
The Linux kernel repository is large so it will take some time to download.
Install the GNU compiler. If you are running on Ubuntu, you can run the following:
```bash
sudo apt install build-essential -y
> **Please Note**
> If you want to instrument your own application optimized for the Arm AGI CPU, we recommend using the latest version of GCC.
> For the GNU toolchain, the `-mcpu=armagicpu` definition was added in [GCC 16.1.0](https://github.com/gcc-mirror/gcc/commit/0f5f728854d2ea93e6806a8632c04383502b0386). As of May 2026, this is the same as the `-march=neoverse-v3ae` option available from [GCC 15](https://gcc.gnu.org/gcc-15/changes.html) onwards. However, in the future there may be differences between `neoverse-v3ae` and `armagicpu`.
When the Linux source download is complete, build the Perf libraries `libperf.a` and `libapi.a`:
```bash
pushd linux/tools/lib/perf
make
popd
### Build the PMUv3 plugin
Get the PMUv3 plugin source code by running:
```bash
git clone https://github.com/ARM-software/PMUv3_plugin.git
Copy the Perf libs:
```bash
cd PMUv3_plugin
cp ../linux/tools/lib/perf/libperf.a .
cp ../linux/tools/lib/api/libapi.a .
Build the PMUv3 plugin:
```bash
gcc -c pmuv3_plugin.c -I ../linux/tools/lib/perf/include -o pmuv3_plugin.o
gcc -c pmuv3_plugin_bundle.c -I ../linux/tools/lib/perf/include -o pmuv3_plugin_bundle.o
g++ -c processing.cpp -I ../linux/tools/lib/perf/include -o processing.o
gcc -c processing.c -I ../linux/tools/lib/perf/include -o processing_c.o
ar rcs libpmuv3_plugin.a pmuv3_plugin.o
ar rcs libpmuv3_plugin_bundle.a pmuv3_plugin_bundle.o  processing_c.o
To do the static library compilation, run `./build.sh` from **/home/ubuntu/ut_integration/PMUv3_plugin/directory**. Run `./build.sh` if you are going to instrument around a C++ codebase. If it is a C codebase, comment line 19 of `build.sh`, uncomment line 20, and run `./build.sh`.
You are now ready to use the PMUv3 plugin in your software project. You will now need to add the library `-lpmuv3_plugin_bundle.a` to your C/C++ link command. You can use `-I` to point to the plugin files and `-L` to point to the library location.
Continue to the next section to see the options for instrumenting code.
