What you've learned
You should now know how to:
  • Generate a fine-grained, precise measurement of functions and other sections of code.
  • Instrument your code to analyze a single section or multiple sections using the provided instrumentation scenarios.
  • Run and collect performance metrics and raw event values for any of the 15 event groups (bundles) in a single run.
  • Use a tool to plot raw PMU event values along with KPI metric values such as MPKI, stalls, and IPC to aid performance visualization.
Knowledge Check
To permanently enable userspace access for performance monitoring, you need to add kernel.perf_user_access = 1 to the /etc/sysctl.conf file.
The PMUv3 plugin can be used to analyze performance of Python applications.
What are the advantages of using the PMUv3 plugin?
