Another way to set CPU affinity is at the source code level. This allows you to be more expressive about which thread goes where at specific points during runtime.
For example, in a hot path that repeatedly updates shared state with a read-modify-write pattern, a pinned thread can avoid excessive cache invalidations caused by other threads modifying data.
To demonstrate this, you’ll create two example programs. The first uses the default OS scheduling without thread pinning.
Copy and paste the code below into a new file named default_os_scheduling.cpp:
#include <benchmark/benchmark.h>
#include <atomic>
#include <thread>
#include <vector>
using namespace std;
// Places each atomic float on a separate 64-byte cache line
struct AlignedAtomic {
alignas(64) std::atomic<float> val = 0;
void os_scheduler() {
const int NUM_THREADS = 4;
AlignedAtomic a;
AlignedAtomic b;
// Lambda Work Function
auto task = [](AlignedAtomic &atomic){
for(int i = 0; i < (1 << 18); i++){
atomic.val = atomic.val + 1.0f;
std::vector<thread> threads;
threads.reserve(NUM_THREADS);
// Launch NUM_THREADS threads
for (int i = 0; i < NUM_THREADS; i++){
if (i%2 == 0){
threads.emplace_back(task, ref(a));
else{
threads.emplace_back(task, ref(b));
// wait for all threads to join before exiting
for (auto& thread : threads){
thread.join();
// Google Benchmark Framework
static void default_os_scheduling(benchmark::State& s) {
while (s.KeepRunning()) {
os_scheduler();
BENCHMARK(default_os_scheduling)->UseRealTime()->Unit(benchmark::kMillisecond);
BENCHMARK_MAIN();
This program has two atomic variables that are aligned on different cache lines to avoid thrashing. You spawn four threads: two threads perform a read-modify-write operation on the first atomic variable, and two threads perform the same operation on the second atomic variable.
Create a file named thread_affinity.cpp with the code below. This program uses pthread_setaffinity_np to pin threads to specific CPU cores:
#include <pthread.h>
#include <vector>
#include <atomic>
#include <cassert>
#include <thread>
void thread_affinity() {
AlignedAtomic a;
AlignedAtomic b;
// Create cpu sets
cpu_set_t cpu_set_0;
cpu_set_t cpu_set_1;
// Zero them out
CPU_ZERO(&cpu_set_0);
CPU_ZERO(&cpu_set_1);
// And set the CPU cores we want to pin the threads too
CPU_SET(0, &cpu_set_0);
CPU_SET(1, &cpu_set_1);
// Launch threads and pin variables a and b to the same CPU cores.
if (i%2 == 0){
assert(pthread_setaffinity_np(threads[i].native_handle(), sizeof(cpu_set_t), &cpu_set_0) == 0);
else{
assert(pthread_setaffinity_np(threads[i].native_handle(), sizeof(cpu_set_t), &cpu_set_1) == 0);
thread.join();
// Thread affinity benchmark
static void thread_affinity(benchmark::State& s) {
for(auto _ : s) {
thread_affinity();
BENCHMARK(thread_affinity)->UseRealTime()->Unit(benchmark::kMillisecond);
BENCHMARK_MAIN();
This program uses the pthread_setaffinity_np function from the pthread.h header file to pin threads. The two threads operating on atomic variable a are pinned to a specific CPU set, and the other threads operating on atomic variable b are pinned to a different CPU.
Compile both programs with the following commands:
g++ default_os_scheduling.cpp -O3 -march=native -lbenchmark -lpthread -o default-os-scheduling
g++ thread_affinity.cpp -O3 -march=native -lbenchmark -lpthread -o thread-affinity
Use Perf to print statistics for both programs:
perf stat -e L1-dcache-loads,L1-dcache-load-misses ./default-os-scheduling
perf stat -e L1-dcache-loads,L1-dcache-load-misses ./thread-affinity
The output shows the L1-dcache-load-misses metric reduces from approximately 7.84% to approximately 0.6% as a result of thread pinning. This metric measures how often the CPU core doesn’t have an up-to-date version of data in the L1 data cache and must perform an expensive operation to fetch data from a different location.
This results in a significant reduction in function execution time, dropping from 10.7 ms to 3.53 ms:
Running ./default-os-scheduling
Run on (16 X 2100 MHz CPU s)
CPU Caches:
L1 Data 64 KiB (x16)
L1 Instruction 64 KiB (x16)
L2 Unified 1024 KiB (x16)
L3 Unified 32768 KiB (x1)
Load Average: 0.37, 0.40, 0.20
Benchmark Time CPU Iterations
default_os_scheduling/real_time 10.7 ms 0.118 ms 64
Performance counter stats for './default-os-scheduling':
391719695 L1-dcache-loads
30726569 L1-dcache-load-misses # 7.84% of all L1-dcache accesses
0.808460086 seconds time elapsed
3.059934000 seconds user
0.030958000 seconds sys
2026-01-14T09:46:00+00:00
Running ./thread-affinity
CPU Caches:
Load Average: 0.66, 0.46, 0.22
thread_affinity/real_time 3.53 ms 0.343 ms 198
Performance counter stats for './thread-affinity':
699781841 L1-dcache-loads
3154506 L1-dcache-load-misses # 0.45% of all L1-dcache accesses
1.094879115 seconds time elapsed
2.044792000 seconds user
0.169065000 seconds sys
The results demonstrate that thread pinning can significantly improve performance when threads operate on separate data structures. By keeping threads on specific cores, you reduce cache coherency traffic and improve data locality.
In this section, you’ve:
pthread_setaffinity_np API to control CPU affinity at the source code levelYou’ve seen how controlling where threads run can reduce cache disruption in contention-heavy paths and improve runtime stability and performance. You’ve also learned about the trade-offs: pinning can boost locality and predictability, but it can hurt performance of other running processes, especially if the workload characteristics change or if you over-constrain the scheduler.
Thread pinning is most effective when you have well-understood workload patterns and clear separation between data structures accessed by different threads. Use it as a fine-tuning technique after establishing baseline performance with default OS scheduling.
