Setup
This Learning Path works on any Arm Linux system with four or more CPU cores.
For example, you can use an AWS Graviton 3 m7g.4xlarge instance running Ubuntu 24.04 LTS, based on the Arm Neoverse V1 architecture.
If you’re unfamiliar with creating a cloud instance, see Get started with Arm-based cloud instances .
The m7g.4xlarge instance has a uniform processor architecture, so there’s no difference in memory or CPU core performance across the cores.
On Linux, check this with the following command:
lscpu | grep -i numa
For the m7g.4xlarge, all 16 cores are in the same NUMA node:
        NUMA node(s):                            1
NUMA node0 CPU(s):                       0-15
You’ll first learn how to pin threads using the taskset utility available in Linux.
This utility sets or retrieves the CPU affinity of a running process or sets the affinity of a process about to be launched. This approach doesn’t require any modifications to the source code.
Install prerequisites
Run the following commands to install the required packages:
sudo apt update && sudo apt install g++ cmake python3-venv python-is-python3 -y
Install Google’s microbenchmarking support library:
git clone https://github.com/google/benchmark.git
cd benchmark
cmake -E make_directory "build"
cmake -E chdir "build" cmake -DBENCHMARK_DOWNLOAD_DEPENDENCIES=on -DCMAKE_BUILD_TYPE=Release ../
sudo cmake --build "build" --config Release --target install -j $(nproc)
If you have issues building and installing, visit the Benchmark repository .
Finally, install the Linux perf utility for measuring performance. See the Linux Perf install guide as you may need to build from source.
Create a CPU-intensive example program
To demonstrate CPU affinity, you’ll create a program that heavily utilizes all available CPU cores. This example repeatedly calculates the Leibniz equation to compute the value of Pi. This is a computationally inefficient algorithm to calculate Pi, and the work is split across many threads.
Create a file named use_all_cores.cpp with the code below. This program spawns multiple threads that calculate Pi using the Leibniz formula:
#include <vector>
#include <iostream>
#include <chrono>
#include <thread>
#include <future>
using namespace std;
double multiplethreaded_leibniz(int terms, bool use_all_cores){
    int NUM_THREADS = 2; // use 2 cores by default
    if (use_all_cores){
        NUM_THREADS = std::thread::hardware_concurrency(); // for example, 16 for a 16-core, single-threaded processor
    std::vector<double> partial_results(NUM_THREADS);
    auto calculation = [&](int thread_id){
        // Lambda function that does the calculation of the Leibniz equation
        double denominator = 0.0;
        double term = 0.0;
        for (int i = thread_id; i < terms; i += NUM_THREADS){
            if (i % 32768 == 0){
                this_thread::sleep_for(std::chrono::nanoseconds(20));
            denominator = (2*i) + 1;
            if (i%2==0){
                partial_results[thread_id] += (1/denominator);
            } else{
                partial_results[thread_id] -= (1/denominator);
    std::vector<thread> threads;
    for (int i = 0; i < NUM_THREADS; i++){
        threads.push_back(std::thread(calculation, i));
    for (auto& thread: threads){
        thread.join();
    // Accumulate and return final result
    double final_result = 0.0;
    for (auto& partial_result: partial_results){
        final_result += partial_result;
    final_result = final_result * 4;
    return final_result;
int main(){
    double result = 0.0;
    auto start = std::chrono::steady_clock::now();
    for (int i = 0; i < 5; i++){
        result = multiplethreaded_leibniz((1<<29),true);
        std::cout << "iteration\t" << i << std::endl;
    auto end = std::chrono::steady_clock::now();
    auto duration = std::chrono::duration_cast<chrono::milliseconds>(end-start);
    std::this_thread::sleep_for(chrono::seconds(5)); // Wait until Python script has finished before printing Answer
    std::cout << "Answer = " << result << "\t5 iterations took " << duration.count() << " milliseconds" << std::endl;
    return 0;
Compile the program with the following command:
g++ -O2 --std=c++11 use_all_cores.cpp -o prog
Observe CPU utilization
Observe how the compiled program utilizes CPU cores. In a separate terminal, use the top utility to view the utilization of each core:
top -d 0.1
Press the number 1 to view per-core utilization.
Then run the program in the other terminal:
./prog
Image Alt Text:Terminal output showing the top command displaying system resource usage. Sixteen CPU cores labeled CPU0 through CPU15 are shown with horizontal percentage bars. Most cores show near 100% utilization with full green bars. The display includes columns for %Cpu(s), memory usage, and process information in a dark theme terminal window alt-txtCPU utilization showing all cores being used
All cores on your system are periodically utilized up to 100% and then drop to idle until the program exits.
In this section, you’ve:
  • Set up an AWS Graviton 3 instance and installed the required tools
  • Created a multi-threaded program that heavily utilizes all available CPU cores
  • Observed how the program distributes work across cores using the top utility
In the next section, you’ll learn how to bind this program to specific CPU cores when running alongside a single-threaded Python script.
