In this section, you will learn how to benchmark PHP performance using PHPBench, a modern and extensible benchmarking framework for PHP applications. You will install PHPBench, run sample tests, and interpret key metrics such as mode time, variance, and throughput. You will then analyze the results to understand how your Google Cloud C4A (Axion Arm64) virtual machine performs on common operations like string manipulation and array processing. PHPBench is a flexible micro-benchmarking tool designed to measure PHP code performance precisely and repeatably.
With PHPBench, you can:
Before installing PHPBench, you need Composer, which is PHP’s dependency manager. Composer handles library installations, versioning, and autoloading, ensuring tools like PHPBench run consistently across environments.
Download the Composer installer script using PHP:
sudo php -r "copy('https://getcomposer.org/installer', 'composer-setup.php');"
This command downloads a PHP script called composer-setup.php, which will install Composer.
Composer requires PHP’s phar (PHP Archive) extension to run. This extension allows PHP to execute .phar archive files, self-contained PHP applications like Composer and PHPBench are distributed in this format.
Install the extension with:
sudo zypper install -y php8-phar
Now, install Composer globally so it is available for all users and can be executed from any directory:
sudo php composer-setup.php --install-dir=/usr/local/bin --filename=composer
The output should look like:
All settings correct for using Composer
Downloading...
Composer (version 2.8.12) successfully installed to: /usr/local/bin/composer
Use it: php /usr/local/bin/composer
Composer is now installed system-wide at /usr/local/bin/composer and ready to manage PHP dependencies.
After successfully installing Composer, remove the installer file to keep your environment clean:
sudo php -r "unlink('composer-setup.php');"
Since Composer is now installed system-wide, the installer file is no longer needed.
To confirm that Composer was installed correctly and is accessible globally, run:
composer --version
You should see output similar to:
Composer version 2.8.12 2025-09-19 13:41:59
PHP version 8.0.30 (/usr/bin/php)
Run the "diagnose" command to get more detailed diagnostics output.
Composer is now successfully installed and you can proceed to installing PHPBench.
PHPBench is a powerful benchmarking tool for measuring the performance of PHP code. Install it globally using Composer so you can access it from any directory:
composer global require phpbench/phpbench
This installs phpbench in your user’s global Composer directory, typically located under $HOME/.config/composer/
To make phpbench accessible from any terminal session, add Composer’s global binary path to your system’s environment PATH:
export PATH="$HOME/.config/composer/vendor/bin:$PATH"
echo 'export PATH=$HOME/.config/composer/vendor/bin:$PATH' >> ~/.bashrc
source ~/.bashrc
Once installed, verify that PHPBench is working correctly:
phpbench --version
phpbench 1.2.14
PHPBench is now installed and ready to run.
Create a new PHP benchmark file using your preferred text editor:
mkdir ~/phpbench-tests
cd ~/phpbench-tests
Create a new PHP benchmark file using your preferred editor:
vi ExampleBenchmark.php
Add the following code to define your benchmark tests:
<?php
use PhpBench\Benchmark\Metadata\Annotations\Iterations;
use PhpBench\Benchmark\Metadata\Annotations\Revs;
* @Revs(1000)
* @Iterations(5)
class ExampleBenchmark
public function benchStringConcat()
$str = '';
for ($i = 0; $i < 1000; $i++) {
$str .= 'a';
public function benchArrayPush()
$arr = [];
$arr[] = $i;
This sets up two basic benchmark tests, string concatenation and array push.
The @Revs(1000) annotation ensures each benchmark function is executed 1,000 times per iteration, while @Iterations(5) means the benchmark runs five separate iterations and averages the results for greater accuracy. The sample benchmarks, benchStringConcat and benchArrayPush, measure the performance of string concatenation and array operations, respectively.
Execute the benchmark suite you created using the phpbench run command:
phpbench run ExampleBenchmark.php
PHPBench (1.2.14) running benchmarks... #standwithukraine
with PHP version 8.0.30, xdebug ❌, opcache ❌
\ExampleBenchmark
benchStringConcat.......................I4 - Mo13.438μs (±0.82%)
benchArrayPush..........................I4 - Mo8.487μs (±0.51%)
Subjects: 2, Assertions: 0, Failures: 0, Errors: 0
PHPBench reports several key metrics to help you understand your code’s performance, as defined in the table below:
| Metric/Term | Meaning |
| benchStringConcat | Name of the benchmark function; measures string concatenation performance. |
| benchArrayPush | Name of the benchmark function; measures array push performance. |
| xdebug ❌ | Xdebug extension is disabled, which is good because Xdebug slows down execution. |
| opcache ❌ | Opcache is disabled, so you’re measuring raw execution without caching optimizations. |
| I4 | Number of iterations per measurement. I4 means 4 iterations of this benchmark were executed per run. |
| Mo13.438μs | Mode (most common) execution time for the benchmark. 13.438 μs = 13.438 microseconds per iteration. |
| (±0.82%) | Variation or coefficient of variation in the measurements. Lower percentage means more stable results. |
Results from the benchmark suite executed on a Google Cloud c4a-standard-4 (Arm64) instance with 4 vCPUs and 16 GB memory, running SUSE Linux:
| Benchmark Function | Iterations | Mode Execution Time (μs) | Variation (%) | Notes |
| benchStringConcat | I4 | 13.438 μs | ±0.82% | Measures performance of string concatenation |
| benchArrayPush | I4 | 8.487 μs | ±0.51% | Measures performance of pushing elements to an array |
For comparison, the same PHPBench test suite was executed on a Google Cloud c4-standard-4 (x86_64) instance with 4 vCPUs and 15 GB memory, running SUSE Linux:
| benchStringConcat | I4 | 13.493 | ±1.80% | Measures performance of string concatenation |
| benchArrayPush | I4 | 7.395 | ±1.07% | Measures performance of pushing elements to an array |
When comparing benchmark results between Google Cloud Axion C4A (Arm64) and x86-based C4 (x86_64) instances, you will see:
These results show that PHP performs consistently across both architectures, and that Google Cloud Axion C4A Arm64 VMs deliver competitive, reliable performance for PHP-based web and backend applications. You can confidently deploy PHP workloads on Arm64 instances, knowing that performance is stable and comparable to x86_64 systems. This benchmarking process helps you identify areas for optimization and ensures your applications run efficiently on Arm platforms. As you continue developing and scaling PHP solutions, regularly benchmarking on Arm64 will help you maintain high performance and take advantage of the cost and energy efficiency benefits offered by Arm-based cloud infrastructure.
