Explore related resources
Give feedback
AI-assisted
Close
Which benchmark option should I choose when running System Characterization?
Use the default set for a broad overview. Choose the static configuration option to gather only system details. Select individual benchmarks if you want to target specific tests.
What should I do on a first run if the target isn't ready for collection?
Select Install Tools in the Performix interface to copy the collection tools to the target. After the tools are installed, start the run again.
How do I know if the run completed, and where do I see results in Performix?
Check the Summary page and benchmark views for populated results. You can open the output directory from Performix to inspect generated files.
Where can I find the raw data and generated plots for my run?
On the Summary page, select Open Run Directory. You can inspect .png plots and .json files produced by the Arm System Characterization Tool.
What should I look for in the Idle latency view?
Use the Idle latency view to compare memory latency across NUMA nodes while the system is idle. Look for differences that can affect where you place a workload.
