# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/servers-and-cloud-computing/performix-memory-access/)
- [Understand CPU memory hierarchy and address translation](https://learn.arm.com/learning-paths/servers-and-cloud-computing/performix-memory-access/how-to-0/)
- [Set up and build the example application](https://learn.arm.com/learning-paths/servers-and-cloud-computing/performix-memory-access/how-to-1/)
- [Profile memory access behavior with Arm Performix](https://learn.arm.com/learning-paths/servers-and-cloud-computing/performix-memory-access/how-to-2/)
- [Optimize an app manually and with the Arm Performix MCP server](https://learn.arm.com/learning-paths/servers-and-cloud-computing/performix-memory-access/how-to-3/)
- [Next Steps](https://learn.arm.com/learning-paths/servers-and-cloud-computing/performix-memory-access/_next-steps/)
## Explore related resources
- [Identify and optimize code hotspots using the Arm Performix MCP server](https://learn.arm.com/learning-paths/servers-and-cloud-computing/performix-mcp-agent/)
- [Find Code Hotspots with Arm Performix](https://learn.arm.com/learning-paths/servers-and-cloud-computing/cpu_hotspot_performix/)
- [Optimize application performance using Arm Performix CPU microarchitecture analysis](https://learn.arm.com/learning-paths/servers-and-cloud-computing/performix-microarchitecture/)
- [Generate Arm Performix AI insights in Visual Studio Code with Codex](https://learn.arm.com/learning-paths/servers-and-cloud-computing/performix-agentic-dynamic-insights-codex/)
- [Arm Performix](https://developer.arm.com/servers-and-cloud-computing/arm-performix)
