Give feedback
AI-assisted
Close
How do I configure the Arm Performix MCP server?
Follow the Generate Arm Performix AI insights in Visual Studio Code with Codex Learning Path to start the installed apx executable with the mcp start arguments and verify that your AI coding assistant can list Performix recipes and configured targets.
What result should I expect after the profiling run completes?
Expect a completed run status and a run ID. Use that run ID to request an AI insight with a hotspot summary that highlights the hottest functions in the Mandelbrot application. Use this output to guide which code changes to apply first.
Should I compile the Mandelbrot example with optimizations before profiling?
No. The single-threaded, unoptimized build is intentional so the hotspot analysis produces a clear signal. The agent later proposes enabling -O3 as part of the optimization pass.
How do I know the agent is targeting the correct machine?
The agent explicitly confirms your configured Performix target name and workload before running the Code Hotspots recipe. Review this confirmation and proceed only if it matches your intended Arm target.
What should I check if the Code Hotspots run fails to start?
Confirm that Arm Performix is configured with your remote Arm target and that the target connection succeeds. Also verify that the Mandelbrot application builds on the target system. You can test the connection with apx target test --target <target-name>.
