Give feedback
AI-assisted
Close
How do I install the arm-performix skill using Git?
Clone the skills repository, then copy the arm-performix folder into your project’s skills directory.
Do I need to run the apx CLI myself, or does the skill handle it?
You don’t need to run apx CLI commands manually. The skill guides AI assistants to use the apx CLI by default. Ensure Arm Performix is installed and apx is available on the host PATH.
How do I write prompts to activate the arm-performix skill?
Use clear profiling intent, for example: “Profile this workload on Arm and find the hotspots”, “Why is this binary slow on my Arm Neoverse server?”, “Use Performix to check whether my hot loop uses vector instructions”, or “Investigate cache and translation lookaside buffer stalls on my Neoverse target”. Vague prompts are less effective.
What context should I include so the skill can profile correctly?
State the target (Arm Neoverse-based Linux instance), an absolute path to the binary to analyze, how to run the workload, and the profiling goal. Provide any run arguments the assistant needs to execute the binary.
What should I expect after the skill completes a profiling run?
Expect a structured analysis report with sections such as “Bottleneck Summary”, “Key Metrics”, “Hot Functions”, “Recommended Actions”, “Ruled Out”, and “Next Step”. Use “Recommended Actions” and “Next Step” to drive code changes, then ask the assistant to rerun the recipe to validate the result.
