Ensure the prompt shows performance and profiling intent
The skill activates on performance and profiling intent.
The following are examples of prompts that show the expected intent:
  • “Profile this workload on Arm and find the hotspots.”
  • “Why is this binary slow on my Arm Neoverse server?”
  • “Use Performix to check whether my hot loop uses vector instructions.”
  • “Investigate cache and translation lookaside buffer stalls on my Neoverse target.”
Prompts that are vague won’t activate the skill.
The following are example vague prompts:
  • “Will my code build on Arm?”
  • “Make my code faster”
Provide context up front
In addition to prompting with the right intent, you need to provide the following context:
  1. Target: a local Arm machine, or user@host for a remote Secure Shell (SSH) target
  2. Binary: the absolute path to the executable on the target
  3. Workload: the exact command and arguments, ideally repeatable
  4. Goal: hotspots, vector instruction usage, memory locality, or a regression to investigate
If the AI assistant needs anything else, such as the source tree for line-level attribution or your build flags, it’ll prompt you for it rather than making an assumption.
The following is a good starting prompt:
Profile /home/me/build/myapp --input /home/me/data/bench.dat on my Arm Neoverse target
me@neoverse-box with Performix. I want to know where the time goes.
This prompt gives the assistant the workload command and the SSH target. The skill picks Code Hotspots first, runs it, and reports back with an analysis.
Provide absolute paths
Always provide the absolute path to the binary. Use absolute paths for all files your workload reads or writes.
If the workload must run from a specific directory, include the directory in the prompt. Performix can launch the process from a different working directory, so relative paths can resolve unexpectedly.
You’ve now learned how to best structure your prompts to profile an application using the arm-performix skill.
Next, you’ll learn how to use generated reports to drive performance improvements.
