Profile Arm workloads with the arm-performix agent skill
Understand the arm-performix skill
Install and enable the arm-performix skill
Prompt AI assistants to use the arm-performix skill
Use generated Arm Performix analysis reports to guide improvements
What the skill is
Arm Performix is a desktop application for hardware-specific performance tuning. It offers curated analysis pathways for performance-critical factors in applications, libraries, runtimes, and source code.
The arm-performix skill is a set of instructions you can add to your AI assistant so that it knows how to use Performix correctly on your behalf. The skill defines which recipe to pick, how to gather context, how to read the results, and how to report findings.
Without the skill, an assistant might guess at performance problems by reading your source code.
When the skill is active, the assistant:
- Asks for the target, binary path, and workload command before profiling
- Chooses the narrowest Performix recipe that answers your question
- Runs the recipe through the Arm Performix
apxcommand-line interface (CLI) - Returns a structured analysis report with a bottleneck summary, key metrics, hot functions, ranked recommendations, and a single next step
What recipes the skill can run
Performix exposes five profiling recipes, and the skill orchestrates them as a workflow: it picks a starting recipe from your question, then follows the evidence into whichever further recipes are needed to explain and confirm the bottleneck.
Each recipe provides a different view of application performance:
| Your question | Recipe | What it shows |
| Where is my time spent? | Code Hotspots | Hottest functions, call paths, and flame graphs to identify where time is spent |
| Why is the pipeline stalling? | CPU Microarchitecture | Front-end and back-end pipeline stalls, bad speculation, retiring |
| Am I using single instruction, multiple data (SIMD), such as Neon or Scalable Vector Extension (SVE)? | Instruction Mix | Scalar versus vector instruction balance |
| Is memory the bottleneck? | Memory Access | L1 cache hit rate, latency, translation lookaside buffer (TLB) and page-walk pressure to identify whether memory is the bottleneck |
| What can the hardware do? | System Characterization | Memory bandwidth and latency baseline per non-uniform memory access (NUMA) node to identify what the hardware can do |
- The four microarchitecture-level recipes — CPU Microarchitecture, Instruction Mix, Memory Access, and System Characterization — require an Arm Neoverse target on Linux. The Code Hotspots recipe additionally runs on x86-64 Linux and on Windows 11 on Arm or x86-64.
- To use the Memory Access recipe, enable the Statistical Profiling Extension (SPE).
- The host machine can be macOS, Windows, or Linux on either arm64 or x86-64. The host can connect to the target locally or over SSH.
- The skill guides AI assistants to use the
apxCLI by default. Ifapxisn’t installed or available, it asks how you want to proceed rather than switching tools automatically.
You’ve now learned how the arm-performix skill can help an assistant use Performix correctly, and what Performix recipes the skill can run.
Next, you’ll install the skill and make it discoverable to your AI assistant.
