Create the optimized source file
The Instruction Mix analysis showed that the application processes one element per loop iteration using scalar instructions. You can reduce the number of instructions per element by rewriting the hot loop with Arm Neon intrinsics, which process four floating-point elements per instruction.
The key changes in the optimized version are:
  • Data-level parallelism: Processes four elements per instruction using Advanced SIMD
  • Fused multiply-add: Combines multiplication and addition into a single instruction (vfmaq_f32)
  • SIMD vector loads: Loads four floats at once (vld1q_f32) instead of one at a time
The memory access pattern, branch structure, and working set size remain unchanged. Any performance difference comes directly from improved instruction efficiency.
On your target, create a new C++ source file named dot_neon_optimized.cpp in the same performix-analysis directory:
#include <arm_neon.h>
#include <algorithm>
#include <chrono>
#include <cstdint>
#include <cstdlib>
#include <iostream>
#include <random>
#if defined (__GNUC__) || defined (__clang__)
#define NOINLINE __attribute__ ((noinline))
#else
#define NOINLINE
#endif
#define RESTRICT __restrict__
#else
#define RESTRICT
#endif
static void* aligned_malloc(std::size_t alignment, std::size_t size) {
#if (__cplusplus >= 201703L)
 std::size_t padded = (size + alignment - 1) / alignment * alignment;
 return std::aligned_alloc(alignment, padded);
#else
 void* p = nullptr;
  if (posix_memalign(&p, alignment, size) != 0) return nullptr;
  return p;
#endif
NOINLINE float dot_neon(const float* RESTRICT a, const float* RESTRICT b, std::size_t n) {
 float32x4_t acc = vdupq_n_f32(0.0f);
  std::size_t i = 0;
  for (; i + 4 <= n; i += 4) {
   float32x4_t va = vld1q_f32(a + i);
   float32x4_t vb = vld1q_f32(b + i);
#if defined (__aarch64__)
    acc = vfmaq_f32(acc, va, vb);
#else
   acc = vmlaq_f32(acc, va, vb);
#endif
 float sum = vaddvq_f32(acc);
#else
  float32x2_t tmp = vadd_f32(vget_low_f32(acc), vget_high_f32(acc));
  tmp = vpadd_f32(tmp, tmp);
  float sum = vget_lane_f32(tmp, 0);
#endif
  for (; i < n; ++i) sum += a[i] * b[i];
  return sum;
static NOINLINE float run_bench(const float* a, const float* b, std::size_t n, int iters) {
  volatile float sink = 0.0f;
  for (int i = 0; i < iters; ++i) {
   sink += dot_neon(a, b, n);
  return sink;
int main(int argc, char** argv) {
 std::size_t n = (argc > 1) ? std::stoull(argv[1]) : (64ull * 1024ull * 1024ull);
  int iters = (argc > 2) ? std::stoi(argv[2]) : 10;
  float* a = static_cast<float*>(aligned_malloc(64, n * sizeof(float)));
  float* b = static_cast<float*>(aligned_malloc(64, n * sizeof(float)));
  if (!a || !b) {
   std::cerr << "Allocation failed\n";
    return 1;
  std::mt19937 rng(123);
  std::uniform_real_distribution<float> dist(0.0f, 1.0f);
  for (std::size_t i = 0; i < n; ++i) {
    a[i] = dist(rng);
    b[i] = dist(rng);
  (void)run_bench(a, b, std::min<std::size_t>(n, 1ull * 1024ull * 1024ull), 2);
  auto t0 = std::chrono::high_resolution_clock::now();
  float r = run_bench(a, b, n, iters);
  auto t1 = std::chrono::high_resolution_clock::now();
  std::chrono::duration<double> dt = t1 - t0;
 std::cout << "neon time=" << dt.count() << "s (sink=" << r << ")\n";
  std::free(a);
  std::free(b);
  return 0;
Compile and verify the optimized program
Compile the optimized version without the -fno-tree-vectorize flag so that the compiler recognizes and supports the Neon intrinsics:
g++ -O3 -g -fno-omit-frame-pointer -mcpu=native -std=c++17 dot_neon_optimized.cpp -o dot_neon
Run the optimized binary to confirm it works:
./dot_neon
The output is similar to:
        neon time=0.456s (sink=1.67772e+07)
The Neon version runs significantly faster than the scalar version. The exact values depend on your hardware.
The sink value might differ slightly from the scalar version due to floating-point rounding differences when accumulating values in a different order. This is expected.
You’ve optimized the C++ dot product application using Neon intrinsics.
Next, you’ll compare the performance of the scalar and optimized versions using Arm Performix.
