Give feedback
AI-assisted
Close
Which path should I use for my binary when I run a recipe?
Enter the path on the target system relative to the target user’s home directory. For example, use a path such as performix-analysis/dot_scalar. If Performix can’t start the binary, check the relative path and file permissions on the target.
What result should I expect from the Code Hotspots recipe?
You should see a list of functions ranked by CPU time. Use this view to choose which functions to inspect or optimize first.
How do I run the CPU Microarchitecture recipe with the same parameters as before?
Specify the same binary path and arguments you used previously, for example, performix-analysis/dot_scalar 16777216 2000. Then, run the recipe to get a Topdown breakdown of pipeline usage.
How do I know from the Instruction Mix recipe that my run is scalar-only?
Look for results dominated by scalar operations with no SIMD usage reported. This indicates missed vectorization opportunities.
After I add Neon intrinsics, what should I compare between runs?
Compare total runtime, changes in hotspot rankings, and shifts in the CPU Microarchitecture breakdown. In Instruction Mix, check for increased SIMD usage relative to the scalar run.
