Choose a configuration method
Codex CLI and the Codex extension share MCP configuration on the same host. Choose one of the following methods:
  • Use the Codex extension settings
  • Run codex mcp add in a terminal
  • Edit ~/.codex/config.toml
You need to complete only one method. The MCP server is a local standard input and output (STDIO) process started by the apx executable.
Note
Configure the server on the host where Codex runs. In a local Visual Studio Code (VS Code) session, this is your development computer. In a remote development session, confirm which host runs the Codex extension and which Arm Performix data directory it uses.
Configure the MCP server in the Codex extension
To add the MCP server in VS Code:
  1. Open the Codex sidebar and select the gear icon.
  2. Select MCP servers, then select Add server.
  3. For Server name, enter arm-performix.
  4. Select STDIO as the transport.
  5. For Command, enter the full path to the Arm Performix apx executable.
    On macOS:
    /Applications/Arm Performix.app/Contents/assets/apx/apx
    On Linux:
    /opt/Arm Performix/assets/apx/apx
    On Windows with an all-users installation:
    C:\Program Files\Arm Performix\assets\apx\apx.exe
    On Windows with a single-user installation:
    C:\Users\<username>\AppData\Local\Programs\Arm Performix\assets\apx\apx.exe
  6. Add the following arguments:
    mcp
    start
  7. Select Save, then select Restart extension.
Configure the MCP server with Codex CLI
If the codex command is available in your terminal, add the same STDIO server from the command line. Replace <path-to-apx> with the full executable path for your host:
codex mcp add arm-performix -- "<path-to-apx>" mcp start
For example, on macOS:
codex mcp add arm-performix -- "/Applications/Arm Performix.app/Contents/assets/apx/apx" mcp start
Restart the Codex extension after the command completes.
Configure the server in the Codex config file
For direct configuration, open ~/.codex/config.toml and add the following:
[mcp_servers.arm-performix]
command = "/Applications/Arm Performix.app/Contents/assets/apx/apx"
args = ["mcp", "start"]
Replace command with the full path to apx on your host. Save the file and restart the Codex extension.
Note
On Windows, use a TOML literal string so backslashes in the path aren’t treated as escape characters:
command = 'C:\Program Files\Arm Performix\assets\apx\apx.exe'
Check that the MCP server is connected
If the codex command is available, confirm that Codex loaded the configuration:
codex mcp list
Find arm-performix in the server list and check that its command and mcp argument are correct. If you don’t use Codex CLI, open MCP servers from the Codex gear menu to review the same status.
Configuration alone doesn’t prove that the tools can read Performix data. In a new Codex chat, enter:
Use the Arm Performix MCP server to list the available recipes and profiling runs. For each run, include its run ID, recipe, target, workload, and creation time when those fields are available.
If Codex returns Performix recipes or runs, the end-to-end connection works. An empty run list isn’t a connection failure if recipes or targets are returned.
Next, ask Codex to identify runs that support the insight workflow:
List the Arm Performix Code Hotspots runs that can be used to generate an AI insight. Include the run ID and enough workload and target details for me to choose the correct run.
Record the run ID you want to analyze. A run name can be changed and might not be unique, so use the run ID in later prompts.
Troubleshoot the MCP connection
Use the following checks to diagnose MCP connection issues:
The Arm Performix MCP server isn’t listed
Check whether Codex loaded the server configuration:
codex mcp list
Find arm-performix in the output. Then confirm:
  • The command is the full path to the apx executable, including apx.exe on Windows.
  • The arguments are mcp and start.
  • The server is enabled.
  • You restarted the extension after changing the configuration.
  • You edited the configuration for the same user account and Codex host that runs the extension.
The MCP server fails to start
Run the executable’s built-in help from a terminal to separate an apx problem from a Codex configuration problem. Replace <path-to-apx> with the configured path:
"<path-to-apx>" mcp --help
If the help text doesn’t appear, check the executable path, file permissions, and installed Arm Performix version. If it does appear, reopen MCP servers in the Codex extension and check the server status.
In a remote development session, make sure apx is installed on the Codex host and that this installation uses the expected Performix configuration and run data.
Codex doesn’t use Arm Performix
Name the server and task explicitly:
Use the Arm Performix MCP server to list the available Arm Performix runs.
For a specific run:
Use Arm Performix to generate an AI insight for run ID "<run-id>".
If you have several MCP servers, an ambiguous prompt such as give me insights might not select Arm Performix.
Code Hotspots runs are missing
Check for the following:
  • You created at least one completed Code Hotspots run.
  • The MCP server runs as the same user who created or imported the run.
  • The GUI, CLI, and MCP server use the same Arm Performix data location.
  • The selected run contains enough samples and profile data for analysis.
  • A remote Visual Studio Code environment isn’t using a different home directory or Performix configuration.
Compare the MCP result with the CLI:
apx run list
If the CLI also returns no run, create or import a run. If the CLI returns the run but Codex doesn’t, recheck which host, user, and configuration start the MCP server.
You’ve now configured and tested the MCP connection.
Next, you’ll create a Code Hotspots run if no supported run is available. If you already have a supported run, skip to Generate Arm Performix AI insights for a Code Hotspots run .
