Generate Arm Performix AI insights in Visual Studio Code with Codex
Understand the AI-assisted Arm Performix insight workflow
Configure the Arm Performix MCP server in Codex
Create an Arm Performix Code Hotspots run
Generate Arm Performix AI insights for a Code Hotspots run
Open the run in Arm Performix for deeper inspection
Ask Codex to list Arm Performix recipes, targets, or supported Code Hotspots runs. A successful listing confirms the MCP server is configured and reachable.
You can update Codex extension settings, run the
codex mcp add command, or edit ~/.codex/config.toml. Configure the MCP on the host where Codex runs; in remote development, verify which machine hosts Codex.Choose a representative workload and specify the executable with an absolute path. Build the workload with debug symbols when possible and aim for at least 20 seconds of activity to collect enough samples.
Request the AI insight using the run ID. If you don’t know it, ask Codex to list supported Code Hotspots runs with IDs, targets, workloads, and creation times. Then, select the correct ID.
Open the same run in Arm Performix and inspect the Flame graph, Functions, Call Stack, Source, and Disassembly views. Confirm that the cited functions, call paths, and sample percentages match the evidence referenced by the insight.
