Prepare a representative workload
If you already have a supported Code Hotspots run, skip to Generate Arm Performix AI insights for a Code Hotspots run .
If you haven’t configured an Arm Linux target yet, follow Set up Arm Performix before continuing.
For a new run, choose a workload that represents the behavior that you want to optimize. Specify the executable with an absolute path because Performix doesn’t support relative workload paths. Build it with debug symbols when possible so that Performix can attribute samples to functions and source lines.
Aim for at least 20 seconds of representative activity. A very short run might not collect enough samples for useful analysis.
Before profiling, identify the following information:
  • The Performix target name
  • The executable path and arguments on the target
  • The working directory and required environment variables of the workload
  • Whether running the workload has side effects
Create a run with Claude Code
First, ask Claude Code to list the configured targets:
Use the Arm Performix MCP server to list the configured targets. Include each target's name and connection status when available.
Choose the correct target, then ask Claude Code to run Code Hotspots. Keep collection and analysis as separate requests so that you can record the run ID before requesting an insight:
Use Arm Performix to run the Code Hotspots recipe on target "<target-name>" with workload "<command>". When the run completes, return its run ID and collection status.
Replace the following placeholders:
  • <target-name> with the Performix target name returned by Claude Code
  • <command> with the command that starts your workload on the target
For example:
Use Arm Performix to run the Code Hotspots recipe on target "graviton-dev" with workload "/opt/myapp/bin/my_app --input /data/input.dat". When the run completes, return its run ID and collection status.
Claude Code uses the MCP server to start the recipe. Review any permission request before allowing the assistant to run a command on the target.
Create a run with the Arm Performix CLI
If you prefer to control collection from a terminal, first check that the recipe dependencies and workload are ready.
The following single-line commands work in bash, zsh, and PowerShell when apx is on your PATH. For host-specific PATH setup, see Use the Arm Performix CLI . Replace my-target and the example workload with your target name and workload command:
apx recipe ready code_hotspots --target my-target --workload "/opt/myapp/bin/my_app --input /data/input.dat"
Run the recipe to collect a profile. The --deploy-tools option deploys any missing or outdated target tools as part of the run:
apx recipe run code_hotspots --target my-target --deploy-tools --workload "/opt/myapp/bin/my_app --input /data/input.dat" --timeout 30
The --timeout 30 option limits profiling to 30 seconds and doesn’t make a short workload run longer. Use a duration that captures representative behavior.
Add --working-dir, --env, or --source when your workload needs a specific working directory, environment variables, or host-based source mapping. For an already-running process, replace --workload with --pid <process-id>.
When collection finishes, list the saved runs:
apx run list
Confirm that the new run completed successfully and record its run ID.
Troubleshoot remote target authentication
If remote target authentication fails, verify that the following conditions are met:
  • SSH key-based authentication works without an interactive password prompt.
  • The private key doesn’t require an interactive passphrase.
  • Passwordless sudo is configured for the target user.
  • Strict host-key checking succeeds.
  • ~/.ssh/known_hosts contains the target key and each jump-node key.
Use the Arm Performix target test to check the configured connection independently of Claude Code:
apx target test --target "<target-name>"
You now have the stable identifier that Claude Code needs to analyze the intended profile.
Next, you’ll generate AI insights from the Code Hotspots run.
